does 3x require more shifting than 2x?
#101
Bikes: 2016 Masi strada vita due, 2019 Kona Dew Plus
Quoted: 265 Post(s)
Liked 80 Times
For the record, the subject of this thread is worded incorrectly. Should say: does 2x require more shifting than 3x?
My argument: when I ride my triple on the flats, Im in the middle ring, middle cog, use the RD to conform to minor changes in conditions. With a double, there is no middle ring or middle cog. For minor adjustments, dont you constantly have to upshift/downshift using both FD & RD?
#102
Quoted: 3573 Post(s)
Liked 6,511 Times
#104
Klaatu..Verata..Necktie?
Quoted: 9286 Post(s)
Liked 10,429 Times
And that's just doubles.
#105
Quoted: 7454 Post(s)
Liked 3,141 Times
We would love to have the definitive answer ... to Every question ... and often imagine that we do.
However .... It Depends.
The only answer I could give you would be: buy two identical bikes and bunch of chain rings and cassettes, and set up one triple and one double, and experiment with different ring and cog choices. Only you know the routes you ride and how you like to ride.
Some burly types here ride everything in one gear. Some use every one of 27 or t0 different ratios. Some ride hills, or mountains, or both, or neither.
It took me time to figure out what worked for me ... then i got old, got tied up with life, essentially had to restart, and everything was different. The recently I got ill and am restarting again. I don't even know what is best for me right now, or where or how much I am going to be riding .... and I hope to change up my whole life anyway.
I cannot even tell you what is best for me today ... I can only imagine a week or a month from now .... and until i get a whole lot more whole-body fitness, I can't even dream of riding my MTB. In a few months, though, I will hit a season of (possibly) frequent and demanding work which will basically negate riding for a couple months ... so I will again be starting over.
Dude .... i just want to ride my bike more and better ... and do everything else in my life better ... I have no clue what is best for you.
#106
Quoted: 3015 Post(s)
Liked 2,318 Times
So, the older I get I'm starting to have an incontinence problem riding no matter how many chainrings I have up front. What's the best way I can deal with the issue?
#107
Liked 3,141 Times
That is one of the better jokes I have seen here ..... Very, very much better than most. Very well played ......
Likes For Maelochs:
#108
I’m a little Surly
Bikes: Two Cross Checks, a Karate Monkey, and a Disc Trucker
Quoted: 697 Post(s)
Liked 1,260 Times
My 2x bikes are 44/28 so basically 1x with a bailout both w/ 11-36 cassettes . My 3x is 44/34/24 w/11-34 so I get more mid range. My 1x is a 38 with 11-42 cassette and if functions fine.
#109
Quoted: 3614 Post(s)
Liked 3,901 Times
So on my last flat 100 mile ride I shifted the front only 4 times and the rear 800+.
I only shift the front for significant climbs.
#110
Liked 3,901 Times
I actually ride 3X to reduce my overall shifting. Not as much of an issue if you're not using shimano STIs with the dreaded long throw of the brake lever shift, or electronic. Still have to hold/push that button. But to answer your question, no. I'd much rather shift the FD once or twice and the RD 2-3 times than shift the FD once and the RD 7+ only to have to do it again in reverse down the road 500 yards. Not much of an issue if the terrain stays constant for a while. But if it's varying constantly like a roller coaster, I'll even take friction.
Modern electronic drivetrains are a joy to use and make shifting totally effortless. Sounds to me like you would benefit more than most.
Likes For PeteHski:
#111
1 x systems have been a boom to the bike industry, which requires something hot and fresh every few years to churn the stock.
Previously, the industry was on a 7 year cycle of adding yet another cassette cog, which obviously rendered all previous systems obsolete and useless. However, with 11-speed, even the most gullible and slavish devotee of the industry had figured out enough was enough. 22 gear combinations not enough? Actually, 9 x 2 systems were past the point of diminishing returns.
But, by removing all but one chainring, and reducing the gear range and the expanding the jumps between cogs, there actually was a need for more cassette cogs. So now we're at 13-tooth cassettes (and growing). This gives the industry a few more years of 'technological development' time, to add yet more cogs on the regular schedule.
#112
Liked 6,511 Times
#113
One more advantage of 1 x systems: cost and maintenance frequency for the industry.
Previously, on close-ratio cassettes, a rider had several adjacent cogs to choose from while riding on flat terrain. So I tend to wear out the 17-tooth cog, but also spend a lot of time in the 16 and 19.
However, with the giant pie-plate cassette required on the 1 x, I would have no other flatland choice but the 17, as the next closest cogs would be the infrequently used 15 and 20. So my $300 cassettes would wear out at double the rate of previous, a boon to component manufacturers and retailers. Add the $100 cost of a 12-speed chain, versus $30 for a decent 10-speed chain.
Add this to the benefit of customer inventory churn, and the big savings to retailers of not having to spend an extra 5 minutes per bike for setting up a triple.
#114
just another gosling
Quoted: 3783 Post(s)
Liked 1,812 Times
No. When I ride a 2x on the flats it just stays in the big ring. I have never ever shifted the front just to find a slightly different gear in between 2 adjacent gears on the same ring. Not on a 2x5 or a 2x12. Only on BF have I ever heard of people riding like that. It sounds insane to me.
Results matter
Results matter
#115
Liked 3,141 Times
Mr. Hski .... I suggest riding into a strong headwind, particularly when fully loaded, particularly after a long day in the saddle.
I might be insane but I know how to use the mechanical advantages the bicycle offers to my maximum advantage ... and sometimes it matters.
Maybe it is simply that nobody told you that being int he right gear mattered? or maybe you have never actually ridden near enough to your limit?
Sorry if that sounds demeaning but you know how we insane people can act sometimes .... I have been in situations where searching for just the right ratio really did seem to matter .... but since our entire existence is really just a construct in our head, of which we are only aware milliseconds after the external reality has changed ... who can really tell?
#116
Liked 6,511 Times
Likes For tomato coupe:
#117
Quoted: 17767 Post(s)
Liked 14,129 Times
You’ll have to pry my triple out of my cold, dead BB shell.
Likes For indyfabz:
#118
Liked 1,812 Times
I find rear shifting so quick and slick on a modern drivetrain (especially electronic) that I don’t care how many rear shifts I need. Front shifting however is still relatively slow and clunky by nature, especially going up. So I prefer less front shifting, although it doesn’t bother me much on a road bike.
Results matter
Results matter
#119
The Wheezing Geezer
Bikes: 1976 Fredo Speciale, Jamis Citizen 1, Ellis-Briggs FAVORI, Rivendell Clem Smith Jr.
Quoted: 334 Post(s)
Liked 726 Times
No.
People who want a 3x drivetrain:
- Those who are used to them because it's what they've always had, because for decades it was the only affordable way to get a really wide total gear range.
- Touring riders who understand gearing and know they need a really wide total range and will be well served to also have small steps at each shift. (These guys also are not too concerned about weight or complexity.)
- Those who think more is always better. "You only have 20 speeds? I have a 21 speed, and I'm going to upgrade to a 27 speed." They multiply number of chainrings by number of cogs, and just want the combo that will give the highest product.
- Those folks who somehow got old, and want a smaller chainring now.
To the OP: The answer to the question in your thread title is: No.
Next!
#120
Steel is real
Bikes: 1992Giant Tourer,1992MeridaAlbon,1996Scapin,1998KonaKilaueua,1993Peugeot Prestige,1991RaleighTeamZ(to be upgraded),1998 Jamis Dragon,1992CTWallis(to be built),1998VettaTeam(to be built),1995Coppi(to be built),1993Grandis(to be built)
Quoted: 566 Post(s)
Liked 779 Times
I have been using triple cranks on all my mountain bikes and my hybrid bike during more than twenty years, until the 2010's nobody really cared about double or single cranks on mountain bikes.Most of the mountain bike championships until 2010's were won with triple cranksets(often the XTR group). Randonneur bikes also use triple crankset. My race bikes are double crankset and only my city bike has a single crank
#121
Liked 3,901 Times
Likes For PeteHski:
#122
Liked 3,901 Times
So you think that I need to shift more or less than you in rolling terrain? I don't follow this argument.
#123
Liked 3,901 Times
#124
Liked 3,901 Times
Well, I am known as The Deranged. Other than that, the more I've ridden, the more I've discovered that riding in a very close range of cadences gives me a little longer period to exhaustion. That moniker is maybe because of my habit of frequently riding to exhaustion on long rides. I like to leave it on the road - seems to me that's of future benefit. Plus it's faster. Higher cadence = more oxygen/carb use. Lower cadence = more muscle damage. There's a fine balance there somewhere, which balance also varies with the ride. Nothing like a mountain 400 to take it out of you. I call it "titrating the pain." Yeah, all this cycling stuff sounds insane to most people. Probably is. It's nice that no one else gets damaged. -DD
#125
Liked 3,901 Times
