What's the best protection from punctures?
Old 09-23-23, 02:29 PM
roadcrankr
Not in charge of anything
roadcrankr's Avatar
Bikes: Merlin Extralight '94 & Cannondale Supersix '15
Quoted: 261 Post(s)
Liked 313 Times in 185 Posts
Originally Posted by waters60
If you don’t want your rim sliding along the pavement and out from under you consider tubular tires.I know this idea is likely a non-starter but you will not be going down so quick. As for puncture resistance I can only recommend Orange Seal Endurance. It may be that I am lucky but I get thousands of miles from my Veloflex tires.
Finally somebody here calls it a puncture.
I ride Veloflex tubulars, as well, and can vouch for their safety.
Probably results from their latex tubes. Very expensive tires, however, that wear out more quickly than clinchers.
Gatorskins do not render a pleasing ride. Using liners on a good Vittoria or Michelin likely feel better.
You could also mount those little doo-hickeys that rub against the tires.
roadcrankr is offline
Old 09-23-23, 02:42 PM
genejockey
Klaatu..Verata..Necktie?
genejockey's Avatar
Quoted: 9296 Post(s)
Liked 10,454 Times in 5,319 Posts
Well, on a different thread, the OP was asking how to build up strength for climbing when you live where there are no hills - a couple tire scrapers should add enough resistance!
genejockey is offline
Old 09-23-23, 03:49 PM
George Mann
Bikes: 2017 Raleigh RetroGlide iE
Quoted: 47 Post(s)
Liked 22 Times in 17 Posts
We seem to be missing a few key pieces of information such as the OP's wheel and tire size, and what type of riding?
George Mann is offline
Old 09-23-23, 04:52 PM
Troul
Troul's Avatar
Liked 2,780 Times in 1,796 Posts
what size are you using now? 700x28?
I'd go slightly wider, & pick out a tubeless ready tire to start out with as you might decide to go tubeless for the front in the near future.
-Oh Hey!
Troul is offline
Old 09-24-23, 12:08 AM
VegasJen
Quoted: 730 Post(s)
Liked 447 Times in 254 Posts
Originally Posted by SW84
My area has a massive amount of goathead plants. The goatheads are everywhere: streets, sidewalks, bike trails, etc. I would repair 2 or 3 holes a day. After researching I bought a pair of Tannus Armour liners and a pair of Sunlite thorn resistant tubes. They are heavier and slower than normal, but I didn't care after all the repairs I was doing. I've ridden my bike now for 400 total miles without any issues.
If you consider going this route just know that the tubes are smaller than what you would normally use because the Tannus liners take up a lot of space. Also know that they are not easy to install without the use of straps to hold the tire in place as you get the last side of the tire over the rim. The total thicknes of the tire, Liner, and tube was 11 mm.
Thanks for the input. Will check out.
Originally Posted by msu2001la
Unless you want to buy new tubeless ready wheels, I would suggest ruling out tubeless.
Attempting to convert older non-tubeless road wheels to tubeless is going to be difficult and problematic.
Certainly a concern. I suspect I might need new tubeless-ready wheels. Hence, the option of a tougher tire.
Originally Posted by Chuck M
I may not be fully understanding the OP's explanation. But with two recent events not noticing the tire had gone flat until negotiating a turn, I don't think a harsh slow ride will be the first thing she notices. Perhaps these events were at speed and at the moment the tire deflated. Nevertheless, I understand flats happen and there is a potential for accident especially on the front wheel. And I hate to say anything lest it jinx me, but I've always noticed something amiss during a ride when I've had a rapid deflation. I certainly feel it and even as hard of hearing that I am, I can usually hear the oscillating hiss as the tire rotates.
Jen, can you recall anything from the moments just before these crashes that may stand out in the future to provide more of an early warning? And since you also mentioned that you have some liners, I would suggest giving them another go. The liners should help and you already have invested in them.
I don't really recall anything immediately before. At least in the case of the ride yesterday, the front wasn't fully flat at the time of the crash, but it was soft enough for the tire to roll over and push into the corner. Part of my difficulty is I was down on my aero bars in the turn and gave up some control from that. Had I been on the drops or even up on the hoods, I may have been able to save it. But that's just speculation. I do know it wasn't flat only a mile and a half before as I had just made a left hand turn and had no stability issues then.
Originally Posted by stevel610
If Gatorskins aren't better, try Gatorskin Hardshells. If not that, Schwalbe Marathon Plus are as flatproof as you get.
A bonus is they will definitely help you with your hills, mentioned in another thread. You will get MUCH stronger after riding them for a while.
Originally Posted by asgelle
To be clear, from your own description you didn't crash because the tire went flat; you crashed because you didn't recognize you were riding on a flat tire. Also, based on how little of the thorn went through the casing, your tire didn't lose pressure all at once, but had a slow leak so pressure dropped gradually without your noticing.
Flat will always happen, I would suggest the solution to your crashing problem is to learn to recognize riding on a soft tire rather than the impossible goal of eliminating flats. Try riding a while with your tires at normal pressure then lower the pressure on one a bit and ride paying attention to how it feels, then lower the pressure a bit more and notice the difference. Keep doing this until the tire is almost flat. Do this a few times until you can tell when a tire is going flat. (You could also just look at your tires once in a while as you ride and see if one is going flat.)
You are correct. I have a very hard time telling when these tires lose pressure. I have had this difficulty ever since I started riding the Roubiax. The CF just has a different feel to it I haven't acclimated to entirely. Often times I'll feel like I'm riding a low tire, stop to check, only to find the tire is still fully inflated. Then, times like yesterday, when I have no idea I have a problem until I'm dusting myself off the asphalt.
VegasJen is offline
Old 09-24-23, 12:19 AM
VegasJen
Quoted: 730 Post(s)
Originally Posted by Iride01
Do you check your tires pressure before you ride your bike? If not, then you might actually be getting pinch flats. They don't always have the two punctures that earn them their other name as snake bites. Every flat needs to be diagnosed. Lay the tube out on the wheel rim as it was oriented in the wheel, then inflate it to find the leak. Is the hole on the tread side, rim side or sidewall? If you are on the roadside in a hurry, put in the new tube and save the old to check at home.
I am just about to wear down the GP5000 on my rear to the threads showing. I haven't flatted since putting it on over 2 years ago.
If Gatorskins didn't help you, then I'd suspect many of your flats aren't from road punctures. So getting rid of the tube and going tubeless might be helpful. So consider it if you are up for that understand the new things you'll have to do every great once in a while.
This was certainly not a pinch flat. I found and removed the offending thorn from the casing before replacing the tube. It was absolutely a single puncture.
I am considering spending the money on a decent entry level set of tubeless ready wheels. I was looking at Mavic last night but didn't find anything I was quite ready for.
Originally Posted by zandoval
Did I miss it?
What kind of tires wheels and tubes are you currently using?
This is my Xero XR-1 wheel set with Vittoria Zaffarino Pro 25c tires and Schwalbe tubes.
VegasJen is offline
Old 09-24-23, 04:20 AM
PeteHski
PeteHski's Avatar
Quoted: 3620 Post(s)
Liked 3,921 Times in 2,478 Posts
Pirelli Cinturato Velo TLR tyres had the highest puncture resistance of any reasonably fast road tyres last time I checked here:-
https://www.bicyclerollingresistance...ture-resistant
They can be run tubed or tubeless, but they offer better puncture protection tubeless. I run these tyres tubeless on my training bike and have never had a single flat or even a sign of sealant having to do its job.
You could try them tubed up on your current wheels and convert to tubeless if you get new rims.
PeteHski is offline
Old 09-24-23, 06:12 AM
spclark
Bikes: 1972 Motobecane Grand Record, 2022 Kona Dew+
Quoted: 113 Post(s)
Liked 112 Times in 79 Posts
You mean these things?
I've run 'em on my MB since forever. Local (to me after a 200 mile move a decade back) LBS crew'd never heard of 'em. But then they've said I'm prolly only cycler in the county who still rides on toobies so there's that....
BTW only 100% certain way I know to prevent punctures is to stay off the bike.
spclark is offline
Old 09-24-23, 08:28 AM
genejockey
genejockey's Avatar
You say that, but I got two flats on a bike that was just sitting in the garage. Rim strip failure.
Old 09-24-23, 09:09 AM
spclark
Quoted: 113 Post(s)
Yeahbut that's outside the OP's thread title question, innit?
Still, I understand that pressure can and will escape at pretty much every opportunity. I have a new Challenge that loses air 24/7/365. Never had a latex tube (that I know of) until this one, will make sure I look more closely at tire/tube specs going forward. Good thing my Zefal still works on the HP setting.
spclark is offline
Old 09-24-23, 12:44 PM
Mtracer
Quoted: 160 Post(s)
Liked 193 Times in 133 Posts
I'd go tubeless for two reasons. One, you're not going to get a flat from typical small thorns, or probably any thorns. You'll never know during the ride you picked one up.
The second is if you had a leak that didn't seal, you WILL know it. Assuming the OP isn't hard of hearing, you will hear the swish, swish, swish from a leak as the tire rolls. Especially coming from the front. You should have no trouble coming to a controlled stop well before the tire goes dangerously flat. Of course, nothing short of a solid tire is going to protect you from a catastrophic failure from hitting some large road debris etc.
Another option, there are tire pressure monitors you can put on the wheels that connect to your cycling computer. I would assume these have an alarm feature to warn you when pressure drops below a given threshold. That would avoid be surprised by the flat.
Mtracer is offline
Old 09-24-23, 11:33 PM
Carbonfiberboy
just another gosling
Carbonfiberboy's Avatar
Quoted: 3783 Post(s)
Liked 1,814 Times in 1,307 Posts
I tried liners once and hated the added resistance. I rather flat, personally. I once had a front tire get gashed in the middle of a fast corner and almost went down. But that's once in many 10s of thousands of miles. I've a a zillion flats which I noticed while riding, stopped and fixed them. That tire that was slashed in the corner - that's why I always carry a spare tire and a boot kit and a patch kit and 2 extra tubes. Around there there's a lot of very desirable riding out of cell range. I've considered going tubeless - I build my own wheels so that's no big deal, but the amount of futzing is a turn-off. Plus I once had to help a rider who had a tubeless tire which couldn't seal because of the size of the damage. That wasn't fun.
But yeah, become more aware of the feel of your tires. Go ahead, be a little paranoid. A quick stop for no good reason is better than crashing. Done that many times.
Results matter
Carbonfiberboy is offline
Likes For Carbonfiberboy:
Old 09-25-23, 12:01 AM
DonkeyShow
Quoted: 195 Post(s)
Liked 234 Times in 141 Posts
700x23. Less area to hit stuff.
DonkeyShow is offline
Likes For DonkeyShow:
Old 09-25-23, 02:08 AM
macattack71
Bikes: 2011 Cannondale SuperSix 3, 1987 Raleigh Technium 440
Quoted: 22 Post(s)
Liked 29 Times in 16 Posts
I'll definitely second using the Continental Gator Hardshells. I have the folding 700 x 25's on my SuperSix, which I also use for commuting to work when possible. They are better than the previous Gatorskins, which I have gotten only one flat on while riding. I don't want flats either and be late to work, or crash. Also, close tire inspection should be a regular event, as softer compound tires pick up all sorts of gravel and glass debris. My original Schwalbes were magnets for debris.
macattack71 is offline
Old 09-25-23, 10:23 AM
genejockey
genejockey's Avatar
I had a chance to do real world testing of what tires feel like at different levels of inflation. I flatted on a ride, and then the new tube got a slow leak which required pumping up again ever 4-6 miles the whole 25 miles home. BTW, it was the rear. SO:
  • Fully inflated: Pavement joints and other bumps hit both wheels the same. Corners great!
  • Down just a bit: Unbelievably smooth ride. Not bouncy yet. Can still feel pavement joints, but not as harsh. Corners okay.
  • Really low: bouncy. Every bump you bounce. Cornering feels a little squirmy
  • Flat: You not only feel every bump, you feel every tiny bit of gravel. Even riding straight feels squirmy.
BTW, this is why people riding VIttoria Corsas the first time keep looking down at their tires - they ride like "Down just a bit" even when fully inflated!
Old 09-25-23, 11:15 AM
Quoted: 17782 Post(s)
Liked 14,146 Times in 6,714 Posts
Please note that there is a difference between puncturing a tire and getting a flat tire. I removed a tubeless tire that had evidence of numerous punctures, but the tire never went flat in its lifetime.
Old 09-25-23, 11:49 AM
surak
surak's Avatar
Quoted: 840 Post(s)
Liked 708 Times in 423 Posts
Tubeless pros:
  • Will self-seal small punctures, reducing the frequency that you'll need to stop for a repair longer than waiting for the sealant to seal. With a good plug kit, can also easily deal with many larger punctures.
  • You can run lower pressure for a more comfortable ride without worrying about pinch flats.
  • There are really fast tire options that you can realistically use for training without worrying that they're too fragile.
Cons:
  • $$$: new wheelset, tires, sealant, plug kit, potentially a booster or compressor if you have trouble seating the tire
  • Need to learn techniques for seating tires as YMMV with difficulty, probably biggest frustration with tubeless
  • Sealant can make a mess, especially roadside if you have to put a tube in
More puncture-resistant tubes tires pro:
  • Don't need any new gear other than the tires
Cons:
  • More puncture resistance generally equals worse ride -- slower and harsher
  • May still puncture anyway and fixing a flat may be harder due to the tougher tire carcass.
Writing as a tubeless fan, for VegasJen the tougher tire is much simpler route to at least try first before diving into tubeless. People tour around the world on various Schwalbe Marathons, that would be a good tire choice to look into.
surak is offline
Old 09-26-23, 01:13 AM
SoSmellyAir
Method to My Madness
Bikes: Trek FX 2, Cannondale Synapse, Cannondale CAAD4, Santa Cruz Stigmata GRX
Quoted: 1670 Post(s)
Liked 1,253 Times in 876 Posts
The key question, left unanswered by VegasJen, is whether she checks the tire pressures before every ride. See post #31 above: Bike Forums - View Single Post - What's the best protection from punctures?
Doing so does not prevent punctures during rides but does provide a better reference point (i.e., how bike handles and feels at predetermined tire pressures) for detecting punctures.
Also, worn tires are more likely to puncture; how worn were the tires?
SoSmellyAir is offline
Old 09-26-23, 01:48 AM
tFUnK
Quoted: 413 Post(s)
Liked 420 Times in 287 Posts
For thorns specifically, tubeless would be the way to go but not if you run through an entire plant or field - multiple simultaneous thorns can be too much for the sealant to handle, especially in high-pressure road tires. You'll also need tubeless-specific wheels and tires.
A reasonably-performing alternative would be to run liners between the tire and the tube of your existing clincher setup. They can be finicky to set up properly but once set up right they do work. I think I would opt for this over a heavier duty tire or tube due to lower weight and better ride quality.
That said, I've never actually tried heavy duty tubes or tires (by heavy duty tire I specifically mean those marketed as puncture proof, not merely puncture resistant like Gatorskins or Marathons - I've ridden those and I do not think their "puncture protection" qualities override their poorer ride quality and weight).
tFUnK is offline
Old 09-26-23, 01:54 AM
choddo
Quoted: 301 Post(s)
Liked 168 Times in 131 Posts
I switched to tubeless 4 years ago. It’s a life changer. Worth investigating if your rims can be converted or frankly selling a kidney to get new ones. Absolutely requires Dynaplugs though. Sealant alone will let you down one day.
and yes it’s a bit more hassle in the garage and the tyres are harder to get on (I can’t do it on my rims without a tyreglider, even levers aren’t up to it, and could put clinchers on by hand no problem) but it’s a LOT less hassle out on the road.
choddo is offline
Old 09-26-23, 02:33 AM
Racing Dan
Racing Dan's Avatar
Quoted: 1306 Post(s)
Liked 311 Times in 210 Posts
Well, its obvious isn't it? Get at puncture proofed tyre and get on with it. Like a Pirelli cinturato velo or conti four seasons. Its a long standing debate and proponents of "race tyres" will often mock and flame you for suggesting such tyres for safety (and puncture proofing). I've certainly had my share of that. However I remain unfazed. Get a good strong tyre for your own safety and less hassle with flats. At the same time you virtually eliminate the "need" for TL, that doesn't work very well anyway. Running race day tyres (TL or tubed) all the time is just daft and the claims puncture proofed tyres ride like concrete is simply false. 99% its pressure determining ride feel, except maybe in the burliest tyres with thick anti flat liners like Marathon+.
Racing Dan is offline
Old 09-26-23, 05:36 AM
eduskator
eduskator's Avatar
Bikes: SL8 Pro, TCR beater
Quoted: 815 Post(s)
Liked 476 Times in 361 Posts
Avoid rolling on things that can puncture your tire!
Seriously, go tubeless. I get a flat every 10 000kms (6200mi) on an average and the tarmac I ride on is far from being perfect. There's always debris on the shoulders. I don't even carry spare tubes anymore if I'm not doing a long ride.
eduskator is offline
Old 09-26-23, 08:45 AM
Fredo76
The Wheezing Geezer
Fredo76's Avatar
Bikes: 1976 Fredo Speciale, Jamis Citizen 1, Ellis-Briggs FAVORI, Rivendell Clem Smith Jr.
Quoted: 334 Post(s)
Liked 726 Times in 352 Posts
You can put sealant in inner tubes, as long as they have removable valve cores. It works well, too.
Fredo76 is offline
Likes For Fredo76:
Old 09-26-23, 09:36 AM
zandoval
zandoval's Avatar
Quoted: 812 Post(s)
Liked 1,392 Times in 895 Posts
Sorry so late gett9ng back to this thread. Here is my choice. Its a tough tire with a fast ride and a good price...
Amazon
zandoval is offline
Old 10-04-23, 10:05 AM
jackb
Bikes: Trek Domane SL5, Trek Checkpoint SL5, Cannndale Trail SE 4, Specialized Langster
Quoted: 157 Post(s)
Liked 128 Times in 69 Posts
Tubless on my gravel bike, no flats yet for two seasons. Conti 4000 four seasons on my endurance bike, no flats since I put them on four years ago.
jackb is offline
