Pristine ‘91 Serotta Colorado 2: what to do?!
Likes For Siu Blue Wind:
Thread Killer
Bikes: 15 Kinesis Racelight 4S, 76 Motebecane Gran Jubilée, 17 Dedacciai Gladiatore2, 12 Breezer Venturi, 09 Dahon Mariner, 12 Mercier Nano, 95 DeKerf Team SL, 19 Tern Rally, 21 Breezer Doppler Cafe+, 19 T-Lab X3, 91 Serotta CII
Quoted: 2765 Post(s)
Liked 1,572 Times
Very nice bike! Campagnolo 8-speed shifts as well as any modern mechanical systems, as long as the right-hand lever G-springs and spring carrier are still fresh. If the shifting is crisp and the right-hand lever holds a gear correctly, you probably have a few '000 miles left before these two items have to be replaced.
If it was me, living in the land of hills, I would replace the cassette with a 13-28, which are still available. Miche also makes these. Longer chain of course. Need still lower gears? Then replace the crankset with a triple (Campy) and the rear derailleur with an 8/early 9-speed Campy long cage. All easily sourced on Ebay or this forum.
As far as the bars, I prefer the traditional round-profile drop bars, with the Campy cable housings taped on both the front and rear. Then, when wrapped with bar tape, this results in an oval shape, which provides more surface area and comfort for tired hands. Keep the bars, unless they are too narrow or wide.
I definitely like the idea of trying a 13-28t cassette. I’m a big guy, and gather momentum quickly, so I’ll miss the 12, but by the same token, I lose the most time on climbs, so it’s probably most advantageous for me to manage my efforts there with gearing.
Thanks for the suggestions!
Bikes: Cannondale Synapse, LeMond Victoire, Bianchi Campione d'Italia, Kona Hei Hei, Ritchey Ultra, Schwinn "Paramount" PDG, '83 Trek 640
Quoted: 226 Post(s)
Liked 267 Times
If you want to make it Eroica compliant, you can. At least for Eroica CA; I don't know about the other versions. For Eroica CA, you only need to start with a lugged frame (or fillet brazed), and you've got that.
Despite the fact that you're now in the C&V subforum, if it were me, I'd build it back up with modern black R7000 or R8000 (or 5800 or 6800 if needed). The frame and the paint job are the stars here, and I'd go with all-black otherwise to keep the attention on them. Correspondingly, I'd also swap out to a black stem and modern non-"anatomic" bars.
If you want to leave it more as it is, that's 100% fine too -- but again, if it were me, I'd swap out for a silver seatpost just to match the rest of its current aesthetic.
Enjoy it!
Enjoy it!
Likes For mhespenheide:
Quoted: 1861 Post(s)
Liked 1,785 Times
I assume your Gladiatore is your current go-fast bike? If you absolutely love that set up, AND after tuning up this Serotta with normal stuff, re-tensioning the wheels, adding new tires, and put at least a 13/25 in the back, then do all your normal Gladiatore rides for at least two weeks on it and spend time in the drops. If you go back to your Gladiatore and you immediately like it much better, move all that stuff that is on the Gladiatore onto the Serotta, put the 90s parts in a box and sell the Gladiatore frameset. That is what I would do.
Thread Killer
Liked 1,572 Times
Quoted: 638 Post(s)
Liked 421 Times
If it’s not your primary go-fast bike, I’d leave the group as is. I personally love the stem but the bars do appear to be a challenge. It appears we ride similar setups so I think a combination of different bars and slight cheating on lever placement can do the trick.
The 3ttt Prima 1999 with a 26.0 clamp gives me a little better positioning on my Serotta wannabe!
Likes For plonz:
Likes For Mr. 66:
Quoted: 281 Post(s)
Liked 302 Times
I think the main question with any bike project is do you want this particular bike to be your bike, or would you prefer a different bike? There’s no sense in trying to turn an old racing bike into, say, a gravel bike. In that case it’d be better to just sell the racer and get a proper gravel bike. Otherwise mod away.
Likes For jethin:
Thread Killer
Liked 1,572 Times
Thread Killer
Liked 1,572 Times
I didn’t realize the Colorado 2 was made with two tubing types; mine uses the Columbus Concept tubing Serotta developed with them. I knew Serotta worked with Tange tubing for a time, but did not realize that extended to C2. Thanks for the heads-up!
Making up the numbers
Quoted: 67 Post(s)
Liked 288 Times
To each their own, but what works for me is setting up each bicycle such that I could ride it for five or six hours if I choose to, and try to do that with each a few times a season. Beyond that it’s use what I already have and only replace what at least a few long rides indicates needs replacing. When it comes to buying replacement parts, I go for those I really like or always wanted, rather than what’s definitively period correct for a particular bicycle, hence the Nitto Craft steel stem below, which would be an unlikely original choice for such a Serotta.
In this case that’s also led to 53/39 and 13-30 10-speed, which is newer than the c. 1993 frame but still gets me up most hills where I am while still allowing a short cage rear changer and double crankset. 53x13 was big enough for the sprinting idol of my junior years, Guido Bontempi, who put daylight into the rest of the field in 1986/87.
I am very wary of used handlebars, and stick with NOS or new Nittos, as is the case here. Because the frame below is repainted, and I use Speedplay or Look pedals, it’ll never be truly original again anyway.
Another passing observation from another bicycle is that switching from Mavic Opens to wider H Plus Son TB14 rims gave a slightly lower tyre height and thus allowed a 28mm under the fork crown, whereas the Mavics only allowed a 25mm. Not much in it, but I do think 28s are noticeably better in all respects than the 25s most 25-35 year old steel frames were built for, probably more so on the 60-61cm frames I use.
The Serotta below is still on 25s, with seat tube clearance the limiting factor, but a rounder 28mm tubular as opposed to a taller 28mm clincher should clear, and is next in line in the incremental and continuous improvement process…
Nothing quite says wall hanger like drillium toe straps
Likes For seagrade:
Likes For bOsscO:
Rider. Wanderer. Creator.
Bikes: Bike Friday Pocket Rocket, Cinelli Hobootleg, Zizzo Liberte
Quoted: 256 Post(s)
Liked 437 Times
What a beauty! I've got a Tri-Colorado; now I wanna take it for a spin!
If you've got other bikes, maybe best leave this as is and enjoy it.
Likes For john m flores:
Likes For Steel Charlie:
Thread Killer
Liked 1,572 Times
seagrade that stem is sexxxy! And that seatpost is one I was considering, too; clean and stylee. Since I’m handing out kudos, the Campagnolo carbon bits look great and not out of place at all.
Yours does have me seriously questioning the “period correct” paradigm, though I still have to weigh the value proposition in pumping money into updating it. I enjoy riding it now; would I enjoy it so much more were it updated? I just don’t know. I do know I don’t have clear demand for this bike, so I have yo create the justification for it no matter which way I go with it.
Bikes: Two Peter Mooney customs, a 1980 Trek 510 townie, a Marin Stelvio set up for TTs.
Quoted: 211 Post(s)
Liked 264 Times
That aside, I have trouble with up-tilted stem on classic bikes. I'd probably put a 72 degree TIGged CroMo stem in place of that TI, and I agree with ljsense that it'd be black. I wound up with Salsas on my Mooneys, and I don't worry drastic failure, though I think a stem, much like a crank (I've broken one of those too, and I'm more a hill twig than the local Cippolini), should get regular inspection. Alternatively, you could hire a frame builder to make a beautiful brazed stem, but that's a very pricey solution. Small point: if that is a good saddle extension for you, then it seems a horizontal stem might not be in the works. I do find them more attractive, but they might put your bars way too low.
The only other thing I'd do is make the drive train interchangeable with my other frequently ridden bikes. Mine are all early 2000s Campy 10s, and I don't look forward to the change when things start failing assuming I don't fail first.
Likes For MooneyBloke:
Quoted: 211 Post(s)
Liked 264 Times
I wonder how well Ergo would mate up with a classic handlebar. For many years, I rode Cinelli 65s. I liked that soft bend, but I think it would put the brake levers in a very strange place.
Quoted: 821 Post(s)
Liked 1,380 Times
I used to run Campagnolo 8-speed, first with Ergos on a Bianchi Alloro and later with friction bar end or down tube shifters on my Rivendell. It worked beautifully, and I've even flirted with the idea of scoring a set of the levers and doing the Shimergo thing on my Lighthouse. My preferred cassette was 13-26, which I think was as big as Campagnolo sold in that era. It's good to hear that Miche offered a 28T option. On the Riv I wound up going from a 52/39 Chorus double to a 50/38/26T T.A. Zephyr triple, and switched the rear derailleur from a short cage (Chorus? Veloce?) to a Campagnolo Olympus mtb mech. That worked so-so with SunTour barcons but was flawless with Rivendell Silver dt friction shifters - but I bet it would have been just fine with 8-speed Ergos as well.
Quoted: 211 Post(s)
Liked 264 Times
The 65 (Cinelli criterium bend) isn't quite a traditional Maes though. The top bend was more like a track bar.
Modern bars to be look as if the hooks are a cosmetic appendage. It seems a bad idea to have your stem already so slammed that the hooks are too much of a reach.
Quoted: 276 Post(s)
Liked 350 Times
The Serotta that I have is an '85 and I have no problem changing anything on it
https://www.bikeforums.net/classic-v...otta-road.html
Quoted: 67 Post(s)
Liked 288 Times
I’ve used first, second and third-generation Ergopower levers on Nitto M176 Dream bars, which to me are a modern-day 66-44 Campione del Mondo/3ttt Merckx bend, only available and affordable, and all sit well. Third generation Ergopower also sit well on 64-44 Giro d’Italia, so I expect the earlier versions would too.
From memory Peter Sagan was the last World Tour-level racer to persevere with 65-xx Criterium-shaped handlebars, ten or so years ago, and his SRAM Red 10-speed? shifters were marginal at best…
Likes For seagrade:
Crawlin' up, flyin' down
Quoted: 907 Post(s)
Liked 2,102 Times
The first thing I would do is . . . ride it. A bunch. As is. For at least a month, maybe two. See if you like how the frame rides. If you love it (and I bet you will), then fix it up in whatever way will make it easiest to get you take if out for rides, If you don't love it (unlikely, but possible), you can move it along without the expense and effort to swap out components. A good, pragmatic approach that still lets you have fun, both riding it and imagining what to hang on it.
BTW, Campy ergo levers play very nicely with Nitto noodle bars; at least the 9/10sp levers do. It's my go-to set up. Even my Cino bike has that set up (10sp ergo levers with the shifter guts removed).
Bikes: Indeed!
Quoted: 1453 Post(s)
Liked 3,155 Times
If you don't care for the stem, there are plenty of other period correct stems out there. Then you can sell the Ibis to one of these folks who feel so passionately that you should keep it because it's super cool. Everyone wins.
Brent
Brent
"I have a tendency to meander sometimes." B.G.
Thread Killer
Liked 1,572 Times
This thing with the stem is kinda weird…
Maybe it speaks to why I love this bike so much: it’s a perfect encapsulation of the cycling zeitgeist of the ‘90s.
It’s about resurgent American innovation and leadership in cycling driven by the MTB boom. Serotta built a road frame of unique and innovative tubing and design, and the bike was finished by the owner not in a slavish dedication to road bike fashion, but rather with a smart selection of parts that drew on the best equipment available. Inis, Chris King, Thomson, and Hugi represent this well.
I think it’s all just so super cool for the story this bike tells, but at the same time— and perhaps jealously— I want to derive maximum riding enjoyment from it, and just warehouse it like a museum piece.
I’ve only ridden it once really, and my desires are still muddled. Once the nostalgic novelty of riding silly flexible wheels of 23mm tires on 13mm IW rims steered by a springy front end wears off, I’m sure things will be clearer.
