Recommend a chain link tool?
Quoted: 120 Post(s)
For popping chain links on or off. Any decent ones? I saw two on Amazon but I'm confused about which type I need.
I don't have a chain that uses extra snap on links for sure. Mine is popping the pin out.
I'm going to track down which type of chain I've got. It's in another post.
Administrator
Bikes: Cervelo C5, Guru Photon, Waterford, Specialized CX
Quoted: 1102 Post(s)
Liked 2,135 Times
They all pretty much work. The chief difference is the larger and more sturdy lasts much longer.
Quoted: 120 Post(s)
Should be it.
My bike.
2009 Raleigh Detour 4.5 - BikePedia
And the chain that came with it. I don't remember having it replaced before. (It will be at some point. I want to get this tool ordered soon, like today probably.)
ChainKMC HG40, 1/2 x 3/32"
My bike.
Quoted: 120 Post(s)
This is one I had on my list. I remember seeing a different model though. Maybe it doesn't really matter.
https://www.amazon.com/Park-Tool-CT-3...A1B7M9EQGNCLQA
[h=1]Park Tool Screw Type Chain Tool - CT-3.2[/h]
Quoted: 120 Post(s)
Yes. Here are some others.
https://www.amazon.com/Master-Chain-T...ark+Tool+chain
Park Tool Master Chain Tool - CT-4.3
https://www.amazon.com/Park-Tool-Mini...ark+Tool+chain
Park Tool Mini Chain Brute Chain Tool - CT-5
https://www.amazon.com/Park-Tool-Prof...ark+Tool+chain
Is a chain link tool a chain link tool then?
My criteria:
Quality. I'm not screwing around with a crappy tool. If I'm repairing my bike it means it doesn't ride and it's probably a stressful time for me because of that. It needs to work again soon if I'm repairing it. I don't want to be limited by the tool. And if I can't repair it and I can't ride it, that means I'm taking it to a shop which I don't want to do. But I'll have to pay the shop. So why not spend more on the tool in the first place?
Thanks for answers here.
My criteria:
Administrator
Liked 2,135 Times
Amazon.com : Park Chain Hand Tool : Bike Hand Tools : Sports & Outdoors
Any of those will work. The difference is the less expensive one you have won't last twenty years of use. A chain needs to be replaced every 2,000 to 5,000 miles of riding. That means you use the tool to press out a pin and push the replacement back in. So you can see unless you put lots of miles on the bike in extreme conditions with by hard riding, the tool doesn't get much use.
NB: You can Only "pop" a quick link on and off *.you cannot "Pop" a pin back in a chain , you can only remove it ,
and thus shorten a derailleur chain.
*for that Park Tool makes a Pair of Pliers.
Only the old style chains that are just for 1 speed bikes and not bent to shift can you reliably press a Pin Back in.
(& then Only if you did Not push it all the way Out!!)
Bikes: Yes
Quoted: 3228 Post(s)
Liked 3,853 Times
I've been using a Park CT-5 for years. It's not as comfortable in the hand as their bigger tools, but it does the job. It's not spec'd for 11-speed chains, but I've used it with a few successfully.
I recently picked up a used Park CT-3 on the cheap. It mangled a plate on the first chain I tried to use it with (an 11-speed SRAM chain). That may be the expected result of using a tool that isn't meant for 11-speed chains on an 11-speed chain, but I also noticed that one of the "fins" on the tool is a bit bent. The CT-5 broke the same chain without a problem. The CT-3 feels much nicer.
I like using "master links" for assembly. It's much easier than trying to push pins in and get them moving freely.
I'm considering dropping the big bucks on a CT-4.3 because I'm about to install an 11-speed Campagnolo group (which requires the "peening" feature), but I'm also considering just getting the CT-3.2 and using a non-Campy master link.
My Bikes
My Bikes
Constant tinkerer
Park CT-5 is fine for carrying on the bike or occasional light duty use.
For today's modern chains with rivets that are tough to break, get a CT-3 (or 3.2) and be done with it.
It's MY mountain
Bikes: Klein, Merckx, Trek
Quoted: 4310 Post(s)
Liked 2,953 Times
What? I remember doing this at least until 9-speed chains came along. Even a few times when I got the pin out all the way by mistake.
Likes For DiabloScott:
Goo you can go over there and help that guy out in person ..
I did close the Loop on Sedisport chains in the 80s , before any quick links were Invented ..
But I'm realistic on the capabilities of people posting stuff in this forum and shopping at Amazon .. they may not Know ,
How to do stuff old guys learned over the past 50 years ..
Quoted: 2026 Post(s)
Liked 1,095 Times
Quoted: 120 Post(s)
The last chain I replaced years ago on a different bike was the snap on kind.
It looks like chains come longer than you need so it's always removing, except at the end you'd have to push a pin in to connect the last one.
And I'm concerned about my current chain. (It's worn and should be replaced, yes.) If it breaks, I could use a chain tool to push pins back in to make it last a little longer. So maybe there are extra chain pins I can get.... (Are there?) I'm going to get a few snap on links to have on hand.
Bikes: Gilmour road, Curtlo road; both steel (of course)
Quoted: 273 Post(s)
Liked 10 Times
Use the tool to trim the chain to size but then add a connecting link for easy removal for cleaning and repairs...
Today, I believe my jurisdiction ends here...
Quoted: 120 Post(s)
Where does that connecting link come from though? The other pins? It doesn't damage them when you use a chain tool to push them out? I can reuse that link? If they sell extras I wouldn't mind having a few around.
KMC and whipperman have a special Link that uses a Key hole lock to secure it in use then when you squeeze the rollers together it will Open
Now derailleur chains are made with such design tolerances that you remove a few links to shorten it, save that section .
because if you break the chain You have to remove the damaged section making it even shorter , then with the saved length and a couple More quick links you restore the length.
side plate holes have to stretch to push the riveted pin head out the hole will always be loose ever after . so pushing the pin back in expect it to break ther again because it is loose .
and to fit more "speeds" the chains got thinner and the riveted pin is flush with the widest link of the chain so very little remains retaining it in a Loose hole.
Liked 1,095 Times
Once chains got narrower than 5/6-speed width the ability to safely push out and reuse a standard pin to rejoin the chain was lost. With newer chains (6/7/8-speed and above) you must use a special manufacturer supplied joining pin to connect them (Shimano or Campy) or a supplied master link (SRAM, KMC and Wipperman). The master links can be used to join Shimano and Campy chains if you buy them as aftermarket parts.
A chain tool is still needed to size new chain to the correct length and to install the specific Shimano and Campy joining pins. Master links can usually be installed without any tools but a special pair of pliers can be useful to remove them.
Mad bike riding scientist
Quoted: 6147 Post(s)
Liked 4,092 Times
My very favorite shop chain tool (which I don't use that often) is the Topeak ChainBOT. Mine is actually a "Droid" but LucasFilms sue Topeak over that name. It's not superior to other chain tools...just way cooler
Stuart Black
Stuart Black
Bikes: 89 Schwinn 754, 90 Trek 1100, 93 Trek 2300, 94 Trek 1400 (under construction), 94 Trek 930, 97 Trek 1400
Quoted: 29 Post(s)
Get a Park CT-3.2 for shortening new chains and removing damaged links.
And get a get of the Park Chain Pliers to make installing and removing master links much easier. Some companies make separate tools for installing and removing the master links (KMC), and some companies (like Park) have a single tool used for installing and removing links. You don't really need the tool to install/lock master links (you can position the master link on the top length of chain over the chainstay, hold the rear wheel and spin the cranks forward to lock the master link without the tool). The tool makes unlocking the master link to remove it much easier.
Sunshine
Quoted: 10897 Post(s)
Liked 7,384 Times
Maybe thats ghetto, maybe that isnt recommended, but its absolutely doable and is consistent too.
Its tough going to get a pin back in, but one can be set in too if its completely removed. The magic of patience.
FLIR Kitten to 0.05C
Quoted: 2349 Post(s)
Liked 406 Times
What? A 7speed chain can have a pin pushed out to allow the chain to come off for cleaning. Route the chain back on and push the pin back in. Wiggle it to make sure its not stuck, and go ride.
Do that on a 10s or 11spd and you'll snap the chain apart on your first hill climbed in anger.
Sunshine
Liked 7,384 Times
I agree that it shouldnt be done with high # of speed chains. But I was responding to the statement that it can only be done on single speed bikes. I have found it can safely be done on 5, 6, and 7 speed bikes without a second thought.
Constant tinkerer
Depends on the chain. Many 6/7/8 speed chains, including the ones that give you a master link to use (KMC, SRAM) are not meant to have pins pushed out and reinserted, hence the master link.
Likes For FastJake:
Bikes: '02 Kona Lava Dome, '15 Origami Crane8... the rest are top secret :)
Quoted: 7 Post(s)
