pro's 15mm axle wrench
it seems i have to remove the wheels alot for various reasons.
i had a box wrench set, but lost the 15mm...so i have been using a adjustable wrench on the axle nuts. it seems to work better. the adjustable wrench is tighter fit thana box wrench. and adj wrenches have thick handles that don't hurt my hand like box wrench. so life is good. or so i thought...
i just rounded off the axle nut. i had forgotten to adjust it before using. it was not snug, and i used a lot of force.
so i guess its better to leave the adjustable wrench for fixing sink and toilet. what do pro mechs use in the shop?
Quoted: 18369 Post(s)
Liked 4,507 Times
Not a "Pro", but Craftsman makes good wrenches. For a lot of things I like a 6pt combination wrench.
Craftsman wrenches tend to be a little fatter than others, so it doesn't hurt to find a narrow 15mm that you can use on pedals. I tend not to use a "pedal wrench".
I hadn't thought much about handles on wrenches. Not a lot out here. A few by CTA.
https://www.snitelearn.com/index.php...ducts_id=95286
https://www.autobarn.net/cta-2500.html
The problem is that I'm not sure one tends to grip wrenches in the middle.
Likes For CliffordK:
Droid on a mission
Quoted: 317 Post(s)
Liked 280 Times
We like combo open/ratchet wrenches. like these from Harbor Freight (lifetime warranty also)
7 Pc Metric Ratcheting Combo Wrench set
Only drawback was that it did not include a 9mm but we purchased that separately from another vendor
Likes For JoeTBM:
Results of my preliminar research on axle specific wrench (see pics below).
(A) + wrench looks good, but it wont fit in small tool box.
(B) too thin, hurt hand. might be too short.
(C) long enough. nice handle. metal around the nut is bit too thin.
(D) a giant wrench. unnecessarily big.
(E) "peanut butter wrench". nice!
Droid on a mission
Quoted: 317 Post(s)
Liked 280 Times
The Park Tool Quad MQ1 is discontinued but most likely you can find one online. We actually have one for the nuts that were gorrilla'd on. Added a 14mm socket to the 3/8 drive end, great for crank bolts too.
Droid on a mission
Quoted: 317 Post(s)
Liked 280 Times
The middle 2 look more like pedal wrenches and the last 2, crank bolt wrenches
Likes For mtb_addict:
Likes For ARider2:
Droid on a mission
Quoted: 317 Post(s)
Liked 280 Times
Speaking of Quad wrenches, anyone know of a quad wrench with either all 4 ends having a 3/8 socket adapter or others that are bike specific (metric), a quick search did not show any other then the Park Tool MQ-1
Quoted: 836 Post(s)
Liked 1,060 Times
OP says he didn't check adjustment of the adjustable wrench which rounded off the nut. Seems to me it's easy enough to just check the adjustment when using....no? Also if your adj. wrench is low quality it will have more slop and more likely to fecker up nuts. Of course a nice quality, long/cushy handled, box end/combo, 15mm wrench will be nice to have but just sayin',
Quoted: 114 Post(s)
Liked 119 Times
I'm not a pro-mechanic but wrench on my own cars and bicycles since the 80's. I definitely prefer box and open end wrenches, over adjustable wrenches. A good quality box/open end wrench has a good, snug, and reassuring feel when torqueing on a fastener. I do have a few adjustable wrenches in my tool box, and I use them when I need. The quality of an adjustable wrench is very important - too much slop in the adjustment mechanism could allow the jaws to open when in use.
Super-duper Genius
Quoted: 768 Post(s)
Liked 984 Times
Its not just failing to make the adjustment tight that can cause the wrench to slip and round off a nut. Even in the best case, adjustable wrenches only engage the nut at two points. A box end wrench engages at six points. Therefore, even though it fits with a little play (necessary to let it get on and off the nut), the non-adjustable box end is far less likely to bugger up a nut.
Likes For Broctoon:
Quoted: 1438 Post(s)
Liked 1,092 Times
I have a 15mm "long pattern" combination wrench similar to this one https://www.amazon.com/Threaded-Quic.../dp/B01M0FYYL2 which is long enough for good leverage plus as a bonus the open end is thin enough to fit any pedals I have come across
Quoted: 1062 Post(s)
Liked 665 Times
I got a 15mm combo wrench from Home Depot and cut it in half for my two bikes with nutted axles. The short wrench is enough for the amount of torque that I need.
As a bonus the box wrench fits Sturmey Archer without damaging the nut.
Quoted: 241 Post(s)
Liked 232 Times
I use the Park MQ-1 on most axle nuts. With the cross style you can use both hands to loosen those majorly over-torqued axle nuts. Or I use an appropriate sized socket and a breaker bar. Combination, box- or open-end wrenches are some of my last choices. Those happy wrenches (ratcheting box ends) look really useful but having full sets of metric, SAE, and offset versions of them they are usually only good in certain situations, and ratcheting end should never be used to loosen or tighten anything. I've snapped a couple of the ratchet pawls in them. They'd be my last choice for a basic shop wrench
Liked 665 Times
This brings up an interesting point. It makes a difference whether you're working on your own bikes, or regularly working on bikes for others. When it's my own bikes, or ones in the family fleet, then I have already taken care of torquing them correctly in the first place, and applying a bit of grease to prevent corrosion. I'd never need a cheater or heavy duty wrench. On the other hand, if I were working on a lot of neglected bikes, or in a "time is money" atmosphere, maybe that's were "pro" tools come into play.
Likes For Gresp15C:
Guest
Quoted: 1346 Post(s)
Liked 3,270 Times
Pshhht. You guys and your fancy "wrenches" need to HTFU.
Clark W. Griswold
Quoted: 4346 Post(s)
Liked 3,981 Times
Most shops will use the Hozan Wrench shown above. A real professional would use something like this: https://shop.snapon.com/product/Reve...Wrench/SRXRM15.
I wouldn't use cheap tools and wouldn't use the wrong tools. A cheap wrench and cheap bolts may not have a precision fit but using quality stuff will help out greatly. Snap-On isn't cheap for a reason, they are quality wrenches that will last a lifetime or will at least have a lifetime warranty behind them should you have problems. They are designed for real usage.
Bikes: 2016 Fuji Tread, 1983 Trek 520
Quoted: 675 Post(s)
Liked 741 Times
I'm not sure about pro bike shops, but no pro mechanics I know in other trades will use Craftsman tools. The Craftsman warranty is attractive to hobbyists, but they break, bend and slip. Pros prefer tools that don't do that. Mac, Proto, SK and Snapon make much better tools. One critical rounded nut, or lost time due to hand injury, makes the price difference worthwhile.
I volunteer for non-profit shops and co-ops, and Harbor Freight rules there for general mechanics tools. As far as anyone cares, they're fine for bicycles.
Happy With My Bikes
Quoted: 884 Post(s)
Liked 2,307 Times
Adjustable wrenches need to be used to beat the person that invented them. And don't get me started on the nudnilks that want to use tongue and groove AKA Channellock pliers on nuts.
Long story short, buy the best tool you can afford and use the right tool for the job.
Quoted: 4197 Post(s)
Liked 3,849 Times
One of the features of Craftsman tools was there wide distribution and minimal hassle replacement policy. Of course these factors are different today when compared to other tool sources and options. I have set up dozens of mechanic stations (work benches) in a number of shops with Craftsman wrenches as the base set. I don't think I've had a broken combo wrench in the 45+ years and dozens of sets I touched. Can't say that about most all pedal wrenches and many Park tools Andy
AndrewRStewart
AndrewRStewart
Guest
Liked 3,270 Times
Quoted: 194 Post(s)
Liked 204 Times
So my big adjustable has a hole in one end that I can slip over a wrench for more leverage, on my hands and knees in the dirt it makes a good little anvil to tighten a rivet, and sometimes it even makes a usefully slim hammer.
To help someone make the right tool-buying or tool-using decision, it might help if we stopped talking about tools as if they were things independent of the world, where tool X is always good and tool Y should not exist.
Context is king.
Likes For Geepig:
Clark W. Griswold
Liked 3,981 Times
I have yet to actually use mine (I just bought it XXL) but this might actually be a solution for certain things.
https://products.wera.de/en/joker_60...e_spanner.html
Yes for many tasks an adjustable wrench is pretty poor especially one that doesn't act like the Joker which sets it selfs and stays tight if used in correct orientation, meaning it will stay tight. However I won't say they are completely without merit. Low quality adjustable spanners are garbage for sure though.
Bikes: nothing to brag about
Quoted: 130 Post(s)
Liked 206 Times
I keep one of these in my fixie bag. It has 15mm and 14mm sockets, and a pedal wrench. No extra metal and a soft rubber cover on the handle. $12.
https://www.amazon.com/gp/aw/d/B00OC...b_b_asin_title
