Apple TV for Zwift
Quoted: 123 Post(s)
Liked 54 Times
Apple TV for Zwift
Thinking of going this way because I dont have a laptop and my tablet is ancient.
I'm not familiar with Apple tv but it seems an easy way into zwift.
Any advice on whether to go this route and/or which version I want?
Habitual User
Quoted: 4944 Post(s)
Liked 8,084 Times
I've been using an Apple TV (4th gen, I think) to run Zwift for almost 2 years. It works great...except the remote. The Apple TV remote sucks.
Quoted: 4399 Post(s)
Liked 4,846 Times
I believe it's a good option for Zwift. I would get the latest version (2nd gen 4k) as it's relatively cheap and an impressive, versatile piece of kit.
Likes For PeteHski:
Quoted: 2952 Post(s)
Liked 3,106 Times
It also is somewhat limited in that it will only do bluetooth. This may not be an issue for you if you have a newish trainer. I used it for a season with kludgy but workable solution because I had a dumb trainer and an Ant+ powermeter on my bike.
Likes For caloso:
Quoted: 123 Post(s)
Liked 54 Times
Also, somewhat unrelatedly, is there any reason to have my garmin head unit (edge 530) looped in?
Quoted: 1461 Post(s)
Liked 1,481 Times
ATV is limited to 2 bluetooth connections, but you can connect additional devices through your smartphone running the Zwift companion app.
I've not done this, but others on the internet suggest it works fine. Not sure what happens if you're also running other apps on your phone. (I use my phone for music, etc while riding).
There's no need to use your Garmin head unit while on Zwift. Zwift will record the ride and can then upload data to whatever platform you're using (Garmin Connect, Strava, etc). Recording on your Garmin would just duplicate the info.
Liked 1,481 Times
As for which version of ATV to get, I think it mostly depends on if you want 4k or are fine with 1080p. Zwift can do 4k, but I think only newer/upgraded versions of ATV will support it.
Otherwise the older/refurbished ATV units will work fine if you don't care about that and are good with 1080p. I'd just buy the cheapest one you can find.
Habitual User
Liked 8,084 Times
Yes. This is an important point. All my sensors are BT. Keep in mind that the Apple TV has a limited number of BT channels (3), and one of those is taken up by the remote. My trainer has speed/power/cadence on one channel. My HR monitor is another channel.
Likes For Eric F:
Liked 3,106 Times
I don't think you'll have any issue. As for the Garmin, I wouldn't bother. Zwift will just upload the ride to whatever app you want.
Likes For caloso:
Habitual User
Liked 8,084 Times
Habitual User
Liked 8,084 Times
On my Saris trainer, power and cadence are combined on one BT channel, leaving another channel for HRM. I would guess your Tacx is the same.
Likes For Eric F:
Hack
Bikes: TrueNorth CX bike, 88 Bianchi Strada (currently Sturmey'd), Yess World Cup race BMX, Pure Cruiser race BMX, RSD Mayor v3 Fatbike
Quoted: 347 Post(s)
Liked 189 Times
Cons:
The Apple TV is limited to fairly basic graphics compared to a PC, and has a limited number of bluetooth connections compared to an android phone or tablet.
Zwift updates are sometimes odd and unpredictable on Apple stuff (led to ZRL premier league riders being DQ'd)
Pros:
It's the simplest setup experience.
Pros:
Likes For Viich:
Liked 4,846 Times
Cons:
Pros:
Pros:
Likes For PeteHski:
I've been using ATV for Zwift for3 years now, very solid way to go. Although, do agree the ATV remote sucks but if you use the Zwift companion app, you really don't need to use the ATV remote at all other than starting/ending the ride.
There were two ways around the BT limitation on ATV, I think now down to one.
- As other's mentioned, use the Zwift companion app and it will act as a bridge, and all works fine.
- I bought a North Pole Engineering CABLE BT bridge for $49 that solved a bunch of problems for me - I don't think they sell the CABLE unit anymore
Likes For jpescatore:
Liked 1,481 Times
On the topic of dropouts, reliability and updates, running Zwift on my Macbook has worked perfectly. In 2+ years of Zwifting I've maybe had 2 times where something went wonky and I had to restart the program. Updates happen automatically and never take more than 30 seconds.
Bikes: two blacks, a blue and a white.
Quoted: 445 Post(s)
Liked 847 Times
I do use a Garmin head unit in parallel, certain data on the unit I don't get on Zwift UI, like average watts while riding, work done. Just sayin.
Bikes: 2022 Salsa Beargrease Carbon Deore 11, 2020 Salsa Warbird GRX 600, 2020 Canyon Ultimate CF SLX disc 9.0 Di2, 2020 Catrike Eola, 2016 Masi cxgr, 2011, Felt F3 Ltd, 2010 Trek 2.1, 2009 KHS Flite 220
Quoted: 4387 Post(s)
Liked 3,016 Times
Maybe it makes more of a difference for real video images, such as Rouvy.
Habitual User
Liked 8,084 Times
Maybe I'm missing something, but I don't see anything in Zwift graphics that would make me care aout 4K. I am using an older (large) flat panel LCD screen that does 1080p and the cartoon graphics, though sometimes quite nice, wouldn't seem to have the detail or texture that would appear much different in 4k.
Liked 3,016 Times
What I wish is that Zwift (and Strava) would show L/R power distribution. For that, I'd have to run my head unit, I think.
Heft On Wheels
Quoted: 887 Post(s)
Liked 560 Times
apple tv 4K is AWESOME, I just switched to it literally days ago. Its the best set up I have ever used. Never used a PC but used my iphone, ipad and a surface at one point and the apple tv is my favorite.
ONLY negative IMO is the remote. Its....touchy, once you get used to it its fine but it could be better. But you can you the companion app on your phone instead and that is pretty straight forward too. You will love apple tv, its simple and really easy to start up. Its just great IMO.
Likes For sdmc530:
I've been using Apple TV for two seasons, after using a PC laptop.
ATV is much better. It's easier, quicker to start & quicker to update.
The remote is not good and can be frustrating to use, supposedly the newest version is better.
The limit of two BT channels isn't too bad, the companion app can be used for 3+, or if your trainer
has cadence, you only need the two (power/controllable/cadence on one channel, HR on the other).
If you use a PM, you may be able to use "Power Match" within you trainer's app (I can with my Kickr18),
so effectively my Assioma pedals are my power source & my Kickr is my controllable.
I double record with my Garmin 530 so that I get L/R balance & respiratory rate.
Zwift goes to Strava, the Garmin to GC.
Likes For Dancing Skeleton:
Quoted: 123 Post(s)
Liked 54 Times
I don’t seem to get any climbing data on the garmin 530. Is this normal or do I have a wire crossed somehow?
Do you use TrainingPeaks by any chance? If so, which feed gets sent there?
Very helpful. I thought there might be a place for the head unit but couldn’t figure what it was.
I never noticed that elevation data doesn't show up in GC or on my 530.
I could just add it in via editing.
I don't use Training Peaks.
