First impressions of GP5000 from longtime Gatorskin user
Bikes: '23 Poseidon Redwood, '07 Specialized Roubaix Comp Triple, '12 Gravity Fixie, '21 Liv Rove 4, '06? Giant EB Spirit
Quoted: 345 Post(s)
Liked 237 Times
In short, I'm very impressed. Just did my first ride with a GP5000 in the rear and Gatorskin in the front on some hills . (The rear tire that wore out first. I only replace tires when they wear out and the front usually lasts 2x as much, thus the new GP5000 in the rear) Both are 28mm, the max that fit on my frame/rims. I feel like the GP5000 has better grip, speed and comfort than the Gatorskin. The grip in particular feels much better.
Don't know about longevity or puncture resistance, but if this tire holds up like its reputation, I may have found my new tire . Looking forward to when the front tire wears out and I can put a GP5000 there too.
The GP5000 looks skinnier but after a couple of days at high pressure it measures almost the same in width.
I really like the fact that the sidewalls are rubber and hopefully won't "thread out" like the Gatorskins do as they age.
Don't get me wrong, the Gatorskins are a great tire (I know some don't like 'em), but the GP5000 seems more fun to ride.
Likes For Symox:
Quoted: 345 Post(s)
Liked 237 Times
Originally Posted by HTupolev;[url=tel:22407060
22407060[/url]]Heh.
For spirited riding, people almost always come around after trying performance-oriented tires.
or are stalking me 😀
Expired Member
Quoted: 3657 Post(s)
Liked 5,394 Times
Likes For shelbyfv:
Bikes: Novara Safari, CAAD9, WABI Classic, WABI Thunder
Quoted: 365 Post(s)
Liked 457 Times
I had a similar experience. I have ridden the GP's on light gravel paths without flats so far. I still like the Gatorskins and still use them, but the GP's are a much better road tire so far.
I think the rear tire would demonstrate a more noticable change in rolling resistance and handling characteristics.
Thsnkfully with the shortages I have a spare set of 28c GP5000S in waiting.
Likes For stevel610:
Veteran, Pacifist
Quoted: 3897 Post(s)
Liked 4,829 Times
Personally, I find the 5000 to be less supple than my Veloflex or Vittoria or Specialized, or Challenge tubulars. I think of the 5000 as the Gatorskin of the high-end tires. But, as stated, the grip is good and it seems to wear less than those mentioned.
I have Wolfpack clinchers that seem to ride about the same as the 5000. Not too many miles on Wolfpack but on gravel they resist little cuts well.
Method to My Madness
Bikes: Trek FX 2, Cannondale Synapse, Cannondale CAAD4, Santa Cruz Stigmata GRX
Quoted: 1939 Post(s)
Liked 1,463 Times
If you can feel a noticeable difference from just the rear, imagine how well the bike will ride with both.
Likes For SoSmellyAir:
Likes For HTupolev:
Liked 1,463 Times
Bikepacking on a road bike video - Bike Forums
Quoted: 4388 Post(s)
Liked 4,828 Times
Likes For PeteHski:
Quoted: 892 Post(s)
Liked 2,053 Times
I must have a numb butt or something.
I started a 1200km brevet in new GP5000 tubeless tires, and suffered a massive sidewall cut early on day 2. Maybe 400km in. I booted and tubed the tire roadside, limped in to Astoria, OR, where the LBS installed a generic tubed 700x32 tire. Looked like an OEM tire off a hybrid. I finished the 1200, and couldn't tell a damn bit of difference. Check the rear tire.
Likes For downtube42:
Liked 1,463 Times
Likes For Symox:
Quoted: 761 Post(s)
Liked 1,724 Times
Anything, and I mean anything, will feel more supple and comfortable than the Gatorskins.
Likes For jaxgtr:
Liked 1,463 Times
just another gosling
Quoted: 3885 Post(s)
Liked 1,938 Times
When putting on a new tire, one should switch the front to the rear and put the new tiire on the front. Leaving a front on until it is worn out is a little risky as rubber does age. Put that Gatorskin on the back and wear it out.
Results matter
Results matter
Likes For Carbonfiberboy:
It surprises me how many people will put gators on sweet riding expensive carbon bikes. You lose the feeling of the great ride you paid for. It takes me 4 min (no outliers obvious cause) to change a flat.
Likes For popeye:
Bikes: Waterford R33, 2019 Infinito, Gunnar Roadie, 1999 Colnago Tecnos, '04 Cannondale Optimo 800 & '51 Rudge Sports, Colnago Tecnos, Tom Kellogg Merlin..
Quoted: 55 Post(s)
Liked 140 Times
I am very much an astetic ninny, can't take mis-matched tires!
Likes For look566 rider:
don't try this at home.
Quoted: 972 Post(s)
Liked 509 Times
The GP5000 tires are great on rough roads if you keep the pressure reasonable. Don't inflate them rock hard. Let that flexible side wall absorb the roughness.
I have GP5000 28mm, measuring 29mm on my wider rims.
At 170 pounds, I usually run 68 psi front, 80 psi rear.
I'm noticing fewer punctures in the group I ride with. Maybe two all year, with close to 5000 miles or more for each of us. Less broken glass these days. We ride on quiet country roads, usually out in the right tire track, away from debris that's kicked to the edge of the road.
Two years ago, I had a few front pinch flats at these pressures. But that was from unnoticed sharp edged small rocks that were out in the middle of otherwise smooth roads. And going faster downhill -- slower speeds wouldn't have pinch flatted on these. No pinch flats last year, so it's random luck.
Bikes: Garmin/Tacx Bike Smart
Quoted: 646 Post(s)
Liked 289 Times
I was riding GP5000s but moved to the GP 4 Season full time. Just got sick of flatting. I've never flatted a GP 4 Season. And never will since a recent bad crash has sent me to a trainer full time.
On flat ground, the proportional increase in speed from switching to a faster tire is actually higher for a slow rider than a fast rider.
Quoted: 646 Post(s)
Liked 289 Times
Lower speeds mean less power consumed from rolling resistance, but that's true about nearly all sources of resistance to a moving vehicle. As a proportion of total resistance, rolling resistance actually tends to be higher at low speeds, except if those low speeds are due to climbing (where gravitational resistance becomes dominant).
I only use gatorskin because I'm afraid of punctures, kills all the fun biking brings, gp5000 is advertised to be puncture resistant and ultra high performance so I'm really anxious to see if it'll be an replacement
Likes For Lancercool1992:
Quoted: 345 Post(s)
Liked 237 Times
ended up ordering a gp5000 for the front too.
Geesh, this site is a bad influence
Likes For Symox:
The force of rolling resistance doesn't change much with speed, so the power to overcome it is roughly linear with speed (more on this below). By contrast, aerodynamic drag force increases quadratically with the relative wind speed, which means that aerodynamic drag power increases roughly cubically with rider speed. This results in aerodynamic drag becoming very dominant at high speeds, making changes to other sources of resistance less pronounced.
