How to get rear derailleur cable house to run straight on vintage steel frame?
Quoted: 9 Post(s)
I'm trying to build up a vintage steel bike for the first time and got to installing the rear derailleur. However when I tried installing the gear cable and rear derailleur cable housing (this is for downtube shifters) the cable housing that is closest to the crank will not sit flush against the knob in the frame. You can see this in my photos that the cable housing just pushes straight up rather than running smoothly with the gear cable.
I haven't put the chain on yet, but you'll see that if the rear derailleur were in the same position without the wheel in place, the cable housing isn't sitting flush against the little knob where the housing is supposed to sit. On my other vintage bike they run fairly smoothly. I'm not sure what the issue is here and this is my first time building up a frame so help would be appreciated.
Could it be that the cable housing length is still too long? Is my cable tension not tight enough?
Droid on a mission
Quoted: 233 Post(s)
Liked 169 Times
I think you are missing something there, I believe is called a "Step Down Housing Ferrule", something like this
That should help keep your housing aligned and have the cable smoothly enter it.
Likes For JoeTBM:
Quoted: 9 Post(s)
Likes For Crankycrank:
Quoted: 146 Post(s)
Liked 164 Times
And some of them have longer "small section" length to hold the ferrule even straighter. If you buy a Campagnolo cable set, I think they still come with one.
Likes For daniell:
Quoted: 1738 Post(s)
Liked 1,365 Times
and for a bit of useless trivia the cable stop on the stay with that shape is sometimes call a divers helmet stop
if you see one it is about 99.99% that you need a stepdown ferrule
(looking for Torpado Super light 56,57 or so)
Likes For squirtdad:
Quoted: 294 Post(s)
Liked 119 Times
A zip tie an inch or so down the chain stay from the cable stop might help as well, but the ferrule, assuming it fits into the
cable stop will keep the cable from the acute angle seen in the pix with the zip tie reducing the bending pressure on the
ferrule from shifting forces. The ferrules pictured may or may not fit into the cable stop hole which looks to be not much
larger than the cable itself.
MotuekaCascadeChinook
Quoted: 4420 Post(s)
Liked 2,963 Times
That's what I did when I put 11 speed Shimano 5800 on my '91 Schwinn Paramount. And they even gave it to me free after hunting for 15 minutes or more.
Droid on a mission
Quoted: 233 Post(s)
Liked 169 Times
Likes For JoeTBM:
