Carbon seatpost recommendation
Old 04-20-22, 12:22 PM
force10
Quoted: 94 Post(s)
Liked 20 Times in 16 Posts
As the title suggests I am looking for a recommendation to replace the aluminum post on my checkpoint alr5. Setback around 15mm.
I am primarily interested in more compliance. The Canyon Vcls s13 looks great but itís awfully expensive so any suggestions are welcome.
Thanks.
force10 is offline
Old 04-20-22, 02:13 PM
mstateglfr
Sunshine
mstateglfr's Avatar
Quoted: 8240 Post(s)
Liked 5,066 Times in 2,944 Posts
https://whiskyparts.co/cockpit/no7_carbon_seatpost#/
It comes in 0 offset or 18mm offset.
For modern seatposts I had only ever used aluminum seatposts from Ritchey and Easton. The Whisky carbon seatpost on my gravel bike definitely flexes more.
I honestly cant say how much more compliant it is as riding was never uncomfortable on the aluminum seatpost, but this Whisky carbon seatpost moves more so its for sure more compliant.
Best part it its $95, well made, and not goofy heavy or anything like that.
mstateglfr is offline
Likes For mstateglfr:
Old 04-20-22, 05:15 PM
chas58
chas58's Avatar
Bikes: too many of all kinds
Quoted: 1143 Post(s)
Liked 403 Times in 325 Posts
Thanks.
It's worth it. Its amazing. I was gonna buy one, but it came on my bike, lol. Ergon sells it too. It is a 10 out of 10. Couldn't be better.
I bought the Specialized version (CG-R). Biggest piece of crap I have ever bought for a bike. I'm still pissed about it. Rating 0 out of 10. Never bought a worse product.
you could buy a thudbuster (ST). It ain't cheap, and it ain't light, but it will "fix" any stiffness problems. Rating 7 out of 10 (heavy, more complex than above, still expensive, but works great). I bought it for my tandem, but bought another one I liked it so much.
chas58 is offline
Likes For chas58:
Old 04-20-22, 05:18 PM
Moisture
Drip, Drip.
Moisture's Avatar
Bikes: Trek Verve E bike, Felt Doctrine 4 XC, Opus Horizon Apex 1
Quoted: 1027 Post(s)
Liked 185 Times in 157 Posts
Is 15mm setback enough for you?
The uno carbon seatpost i've tried was very stiff, and merely offered slightly better road resonance/vibration dampening. If you want actual compliance, you'll have to get a suspension seatpost. I've reviewed both the Suntour SP12 NCX and Satori Animaris on my account.
Moisture is offline
Old 04-20-22, 05:29 PM
caloso
caloso's Avatar
Quoted: 2890 Post(s)
Liked 2,915 Times in 1,341 Posts
For an aluminum frame, I would recommend an aluminum seat post. Google galvanic corrosion.
caloso is offline
Old 04-20-22, 06:35 PM
force10
Quoted: 94 Post(s)
I was afraid someone would say that it it was as good as its price. To clarify, I am not looking at the split-style post that they offer.
force10 is offline
Old 04-20-22, 06:39 PM
force10
Quoted: 94 Post(s)
I am familiar with galvanic corrosion but I've not heard of there being an especial issue with aluminum frames and carbon seat posts - seems fairly common. Perhaps you have experience otherwise?
force10 is offline
Moisture
Drip, Drip.
Moisture's Avatar
chas58
What other seatposts have you tried? I stick to Suntour and Satori because they have the setback I need (24mm.)
What do you think of a suspension stem?
Moisture is offline
Old 04-20-22, 07:40 PM
zen_
zen_'s Avatar
Quoted: 90 Post(s)
Liked 87 Times in 54 Posts
I have been really happy with Satori carbon seatpost and handlebars to add compliance and save weight over alloy w/o spending a ton of money, or worrying about generic Chinese stuff. Looks like you can buy one on Amazon now for $35...no brainer when the same brand name post that Satori makes is $100+.
zen_ is offline
Old 04-21-22, 10:10 AM
msu2001la
msu2001la's Avatar
Quoted: 951 Post(s)
Liked 920 Times in 532 Posts
My carbon frame bike came with an aluminum seatpost, and my older aluminum frame came with a carbon seatpost. I've also wondered about galvanic corrosion., but have not noticed any issues so far with either combo.
That said, I like the idea of upgrading to a carbon post on my carbon bike - more compliance is better right?. I've read so many horror stories about seat posts on carbon frames slipping and creaking that I've been afraid to switch. Plus my post is an oddball size (25.4mm) so my options are more limited. FSA SL-K comes in that size and seems like a good deal for around $90. Anyone have experience with that one? Zipp and Enve both have options as well, but they are $200+.
Every time I think about this, I conclude that what I have seems to be working so I don't want to mess with it.
msu2001la is offline
Old 04-21-22, 10:32 AM
caloso
caloso's Avatar
I had a carbon frame that came with an aluminum seatpost that got so stuck that they had to put it in a bench vise and use the bike itself as a lever to twist it out. I replaced it with a carbon post and never had any problem since.
caloso is offline
Old 04-21-22, 03:51 PM
pipeliner
Quoted: 37 Post(s)
Liked 61 Times in 31 Posts
Galvanic corrosion requires dissimilar metals. Carbon fiber composites have no metal content.
pipeliner is offline
Likes For pipeliner:
Old 04-21-22, 04:18 PM
masi61
masi61's Avatar
Quoted: 922 Post(s)
Liked 277 Times in 196 Posts
Ritchey Flexlogic has compliance built in to the carbon construction AFAIK. I have the "Superlogic" post that has the :"flexlogic" tech to it on my titanium road bike. My Turbomatic Team saddle has elastomers under the seat rails but it still is a pretty stiff saddle. I can feel a softening over bumps with this setup on rough pavement.
masi61 is offline
Likes For masi61:
Old 04-21-22, 04:30 PM
caloso
caloso's Avatar
https://www.corrosionpedia.com/galva...olymers/2/1556
caloso is offline
Old 04-21-22, 09:03 PM
force10
Quoted: 94 Post(s)
That must have been hard to watch.
force10 is offline
Old 04-22-22, 06:51 AM
Jazzguitar
Quoted: 53 Post(s)
Liked 22 Times in 14 Posts
It's not cheap but I've been very happy with the Roval Terra seatpost I picked up last year.
Jazzguitar is offline
Likes For Jazzguitar:
Old 04-22-22, 07:13 AM
force10
Quoted: 94 Post(s)
That was the other one I was considering. Same price as the Canyon vcls.
You dont happen to be using it on an aluminum frame, do you?
force10 is offline
Old 04-22-22, 09:54 AM
Parkyy16
Bikes: All steel... Breadwinner, Ritchey, Soma, VO, etc.
Quoted: 56 Post(s)
Liked 36 Times in 25 Posts
I'm gonna be the odd one out; I haven't noticed significant comfort difference between aluminum and carbon seatposts on the same bike back to back with the only change being the seatpost. Granted, I haven't tried the Ergon/Canyon split seatpost nor any of the suspension seatposts.
I had the cheap Kalloy aluminum seatpost and a carbon seatpost from Easton on my Soma Smoothie(I was trying out different setback). I've gone back to the Kalloy, because of the fit. I also tried a cheaper Ebay carbon seatpost that I didn't notice any difference from either.
I do have the Easton carbon seatposts on my Ritchey and my Breadwinner. I wonder if I spent a bit too much on carbon when I could have just gotten a cheaper alloy seatpost, but they look nicer.
I think I notice tire pressure and saddle more than I feel the different rigid carbon or aluminum seatpost. I know a buddy with a thudbuster on his cargo bike that he swears by, but he's not exactly concerned with weight on the Urban Arrow.
I'll add another potential recommendation(with no personal experience) for a PNW dropper/suspension seatpost. I've read some decent review of the Coast(I think?) that comes in 27.2 externally routed dropper. Might be an interesting option.
Parkyy16 is offline
Likes For Parkyy16:
Old 04-22-22, 01:42 PM
chas58
chas58's Avatar
Originally Posted by Moisture View Post
chas58
I've had rockshock telsscoping for a mountain bike (not great for Gravel)
Thudbuster great for gravel, but kinda big and heavy
Specialized CGR - horrid
Canyon/Ergon (single piece) ideal for gravel
Not a problem. Well, you should have some seatpost paste in there or something. If you just leave any seatpost in dry for long enough, it will get stuck.
You do need to use that gritty carbon paste for a carbon seat tube. Works great with it, rather poorly without...
​​​​​​​yeah, any seat post can get stuck if left in there dry for long enough, true...
I don't use a dropper, but I've heard their biggest problem for gravel is how stiff they are.
chas58 is offline
Likes For chas58:
Old 04-22-22, 01:57 PM
chas58
chas58's Avatar
I'll summarize.
Not knowing what I had, I was gonna replace it, but was quite pleasantly surprised - amazed actually.
1) the first couple of weeks I would get off my bike 1/2 way through a ride and check my tire pressure. It road so smooth that I was convinced I had a leak in my rear tire.
2) last fall I was cruising along (20mph) some of the most horrid washboard I had ever seen, amazed at how smooth the ride was on my 32mm tires. I had totally given up on these roads 15 years ago because that washboard was such a nightmare to ride on with the equipment of the time.
Caveats -
its not a full sus bike. you are going to feel a pothole and hard hits that a mountain bike can take in stride. But it works wonders on the the chatter we get with gravel
Ya need a lot of exposed seat post - the more the better. If you only have 4-5" its not gonna be effective.
Alternative - I've heard the redshift seatpost is nice (and expensive), but it takes
chas58 is offline
Old 04-22-22, 05:40 PM
chaadster
Thread Killer
Bikes: '15 Kinesis Racelight 4S, '76 Motebecane Gran Jubilťe, '17 Dedacciai Gladiatore2, '12 Breezer Venturi, '09 Dahon Mariner, '12 Mercier Nano, '95 DeKerf Team SL, '19 Tern Rally, ‘21 Breezer Doppler Cafe+, ‘19 T-Lab X3
Quoted: 2085 Post(s)
Liked 1,143 Times in 694 Posts
Getting compliance— i.e. physical deflection, also bump response— of the seatpost is not really a thing with typical seatpost construction, but if you have enough seatpost extension out of the frame, titanium will flex/deflect more than aluminum or carbon fiber. What carbon fiber posts can deliver is vibration damping, because of the CF structure. Personally, I don’t think there’s much in different seatpost material either way, so really it’s just about weight, clamp mechanism, and looks to me. That said, if I was going for marginal comfort gains, I’d go with titanium, but only if I was running a lot of extension, otherwise CF would be the easy choice.
chaadster is offline
Likes For chaadster:
Old 04-22-22, 08:51 PM
force10
Quoted: 94 Post(s)
I'll summarize.
Caveats -
Thanks for all that. Particularly the caveat about the length of exposed seatpost. I havenít seen that mentioned before and it makes sense. I have about 5.5 inches exposed, which I guess will make for a pretty marginal improvement.
force10 is offline
Old 04-22-22, 10:09 PM
base2
Doesn't brain good.
base2's Avatar
Bikes: 5 good ones, and the occasional project.
Quoted: 1116 Post(s)
Liked 769 Times in 455 Posts
At 97 grams (actual) & 315Ä delivered to the USA I couldn't be more pleased. By far the most comfortable seat post I have ever owned.
Beware of eBay Hong Kong knock-offs. The real deal comes from Spain & requires you initiate an order via email.
My Darimo posts are mated to 91 gram AX-Lightness Leaf II Plus saddles. Better than the Brooks they replaced...& that's sayin' sumthin'! For 280Ä each they'd better.
I don't know than many people would care to drop $650-$700 USD on a 188 gram saddle & post...& not even that such a ridiculous extravagance makes sense. I'm only saying that it is super comfortable & was enough so that I did it 2x for 2 bikes & would do so again if another such windfall happened along my way.
Highly recommended...In a once in a lifetime kind of way.
base2 is offline
Old 04-23-22, 09:08 AM
Jazzguitar
Quoted: 53 Post(s)
No, I'm using it on a carbon frame. You should be fine on aluminum, just use some friction paste.
Old 04-23-22, 07:21 PM
KJ43
Dead but dreaming
KJ43's Avatar
Bikes: 2020 Santa Cruz Stigmata, 2022 Cannondale Synapse
Quoted: 130 Post(s)
Liked 258 Times in 147 Posts
I have the Superlogic Link Seatpost and it's great. Super light and just a hint of compliance to it. Pricey, but worth it. It has a 15mm setback. So does the WCS Carbon Link Flexlogic Seatpost which has the same compliance, a bit cheaper and a bit more weight.
I love Ritchey stems and seatposts and have them on both of my bikes.
KJ43 is offline
Likes For KJ43:
