How bad is this?
How bad is this?
Old 05-04-22, 06:39 AM
juntjoo
juntjoo's Avatar
Bikes: Cannondale Bent 2, Fuji Royale, Mongoose Snare
Quoted: 103 Post(s)
Liked 8 Times in 6 Posts
How bad is this?
I'm planning on getting new tires but do I need them like yesterday?
juntjoo is offline
Old 05-04-22, 06:42 AM
thumpism
Bikes are okay, I guess.
thumpism's Avatar
Quoted: 2647 Post(s)
Don't ride farther from home than you want to walk back.
thumpism is offline
Old 05-04-22, 06:45 AM
juntjoo
juntjoo's Avatar
Quoted: 103 Post(s)
Well them to Walmart for a tire is my next stop. They got two of my size, 27'. Would you upgrade to 700c?i just learned I have a dying size.
juntjoo is offline
Old 05-04-22, 06:52 AM
ClydeClydeson
Quoted: 581 Post(s)
Liked 921 Times in 518 Posts
I generally don't mind riding cracked or weathered or repaired tires. I wouldn't ride that.
As a rule, if you can 'feel' the wobble in a tire when riding (as I am sure you can with that) then the casing is damaged and it needs replacing.
ClydeClydeson is offline
Old 05-04-22, 06:57 AM
ClydeClydeson
Quoted: 581 Post(s)
If the bike is special or high quality or you intend to keep it for a long time then an upgrade to 700C is not a bad idea. But if it is a lower cost bike just for rippin' around town, then stick with 27".
Something to keep in mind is that moving from 27" to 700 is that the smaller wheel size changes the leverage of the brakes and (in the case of 'caliper' brakes, or any brake where the pivot is above the rim) you need to apply more force at the lever to get the same braking force. It might be a minor change or it might be more significant, but it does change.
THe other advantage of 700c wheels, aside from increased tire selection, is that it gives you a few extra mm of tire clearance, so if you could only fit 1-1/4" (32mm) wide tires with 27", you can fit 35mm or 38mm tires with 700c wheels.
Old 05-04-22, 07:19 AM
Andrew R Stewart
Andrew R Stewart's Avatar
Quoted: 4201 Post(s)
Liked 3,857 Times in 2,305 Posts
"I'm planning on getting new tires but do I need them like yesterday?" juntjoo
Yes. Andy
AndrewRStewart
Andrew R Stewart is offline
Likes For Andrew R Stewart:
Old 05-04-22, 07:28 AM
pdlamb
Quoted: 2604 Post(s)
Liked 1,928 Times in 1,210 Posts
Just to clarify, to "upgrade" from 27" to 700c will require new wheels. So $40-60 for new 27" tires, and maybe $300 for new wheels + new tires, your choice.
pdlamb is offline
Old 05-04-22, 08:26 AM
alcjphil
alcjphil's Avatar
Quoted: 1819 Post(s)
Liked 1,693 Times in 974 Posts
Well then, you would also need new wheels
alcjphil is offline
Old 05-04-22, 09:37 AM
curbtender
curbtender's Avatar
Quoted: 1609 Post(s)
Liked 2,589 Times in 1,224 Posts
and longer reach brakes.
curbtender is offline
Old 05-04-22, 09:39 AM
Senior Ryder 00
Old bikes, Older guy
Senior Ryder 00's Avatar
Location: Fiscal Conservative on the Lefty Coast - Oregon
Bikes: A few modern, Several vintage, All ridden when weather allows.
Quoted: 250 Post(s)
Liked 166 Times in 115 Posts
“A disaster waiting to happen!”
Remember: Real bikes have pedals.
...and never put a yellow tail on a Red, White and Blue kite!
Senior Ryder 00 is online now
Old 05-04-22, 09:43 AM
Dan Burkhart
Senior member
Dan Burkhart's Avatar
Quoted: 943 Post(s)
Liked 658 Times in 371 Posts
That would require new wheels and possibly new brakes. There are enough options out there in 27" tires to keep you rolling.
Dan Burkhart is offline
Old 05-04-22, 10:45 AM
KerryIrons
Quoted: 506 Post(s)
Liked 638 Times in 356 Posts
Not yesterday, but today.
KerryIrons is offline
Likes For KerryIrons:
Old 05-04-22, 11:19 AM
CliffordK
CliffordK's Avatar
Quoted: 18373 Post(s)
Liked 4,508 Times in 3,351 Posts
27" has been a dying size for nearly 50 years. I wouldn't worry about them disappearing any time soon. If you can't find them at Walmart, try your local bike shop. Or buy tires online before they get as bad as the photo.
As mentioned, to go to 700c, you'll need new rims (wheels unless you choose to rebuild). Plus your brake pads are already at the lowest place, so you'll also need new brake calipers.
I wouldn't encourage doing the swap to 700c, unless you have something very specific in mind like moving to fatter tires like 700c x 35mm or 700c x 40mm.
Assuming you keep the 27" tires, make sure your brake pads are adjusted so they are parallel to the rim. It appears as if the left pad is tipped up in the front slightly. That is the quickest way to destroy a new set of tires!!!
CliffordK is offline
Likes For CliffordK:
Old 05-04-22, 11:35 AM
dedhed
SE Wis
dedhed's Avatar
Quoted: 2746 Post(s)
Liked 3,390 Times in 2,053 Posts
Maybe. filing slots or drop pads are an option if there isn't enough adjustment.
​​​​​​https://bdopcycling.com/product/bdop...rs-pair-black/
dedhed is offline
Old 05-04-22, 12:03 PM
squirtdad
squirtdad's Avatar
Quoted: 2338 Post(s)
Liked 2,822 Times in 1,541 Posts
may be worth doing on line order to get a bit better tire than what might be in stock https://www.walmart.com/ip/Panaracer...-Tire/31979003
squirtdad is offline
Old 05-04-22, 01:50 PM
rumrunn6
rumrunn6's Avatar
Quoted: 5224 Post(s)
Liked 3,581 Times in 2,342 Posts
you're fine fine until the tube starts bulging thru. they sure don't make tires like they used
rumrunn6 is offline
Old 05-04-22, 01:53 PM
rumrunn6
rumrunn6's Avatar
go for it, if you can't wait. otherwise, Amazon has lots that size, from name brands, that would probably better. just curious, what brand & model are those tires? how old are they?
rumrunn6 is offline
Likes For rumrunn6:
Old 05-04-22, 02:06 PM
juntjoo
juntjoo's Avatar
Quoted: 103 Post(s)
Just grabbed these. $20 a piece. I found some knobby ones on Amazon I liked for the terrain variety but then settled on these to keep it strict on-road. They LOOK/feel pretty good to me but what would I know. I'm happy with em. They advertise "anti-puncture tech" so that's gotta count for something!
juntjoo is offline
Likes For juntjoo:
Old 05-04-22, 02:15 PM
rumrunn6
rumrunn6's Avatar
if the tubes you have now are OK, you can save the new ones. or put the new ones in & save the old ones
rumrunn6 is offline
Likes For rumrunn6:
Old 05-04-22, 04:36 PM
Troul
Troul's Avatar
Liked 2,967 Times in 1,916 Posts
Overnight would work.
-Oh Hey!
Troul is offline
Old 05-04-22, 07:00 PM
Andrew R Stewart
and as one who is old enough to have ridden natural fiber tires (cotton, silk casing threads, some with natural rubber tread caps) I will say "thank you that current tires are different". Modern tires are vastly more durable and can be more flat resistant that those of yesteryear. We have many more options (the 630 ISO size is the exception) in the common sizes than we had years ago.
The issue with the OP's tire is not how well made they were but how old it is, how much UV it has baked under and what was its intended useful life. Andy
AndrewRStewart
Old 05-04-22, 07:16 PM
CliffordK
CliffordK's Avatar
It is worthwhile to look at the rim strips at the same time.
I've had plastic ones that disintegrated with age.
And rubber ones are frequently suboptimal, and often tear at the valve stems.
Cloth strips can probably hold up to the age, if the glue is still good.
Old 05-04-22, 08:52 PM
Gresp15C
Gresp15C's Avatar
Quoted: 1062 Post(s)
Liked 665 Times in 421 Posts
I continue to ride 2 bikes with 27" wheels. The time to abandon 27" is when I actually need new tires and can no longer get them. With luck, the OP has bought themselves a few years to think about it.
To accommodate 700c wheels, the brakes need an additional 4 mm in the slots, check both front and back. That can be investigated at leisure. But judging from the pic, either the pads are mis-aligned, or it's a bad camera angle.
Gresp15C is offline
Old 05-05-22, 03:55 AM
rumrunn6
rumrunn6's Avatar
Originally Posted by Andrew R Stewart
and as one who is old enough to have ridden natural fiber tires (cotton, silk casing threads, some with natural rubber tread caps) I will say "thank you that current tires are different". Modern tires are vastly more durable and can be more flat resistant that those of yesteryear. We have many more options (the 630 ISO size is the exception) in the common sizes than we had years ago.The issue with the OP's tire is not how well made they were but how old it is, how much UV it has baked under and what was its intended useful life. Andy
approx. 15 years ago, I needed a weekend project, drove to the next state for a $25 bike from the '70s, gave the guy $20 & he was pissed but took the deal anyway. he said he didn't know anyway thing about the flat tires. gave the bike the once-over at home, the tires appeared to be original but I pumped them up to full pressure & they held air. took it for a 34 mile round trip test commute, got about 10 miles from home when I heard threads popping, the tubes was starting to push through the sidewalls, turned around & made it home another 10 miles. so those tires were 32? years old? I'm guessing waaaay older that the OP's. anyway, I was impressed with those old tires
rumrunn6 is offline
Old 05-05-22, 05:16 AM
Chuck M
Happy With My Bikes
Chuck M's Avatar
Quoted: 884 Post(s)
Liked 2,307 Times in 1,117 Posts
I'm surprised that Wally World had 27" tires of any kind in stock. Around here I can't even find them in bike shops.
Chuck M is offline
