Fixed bike repair stand ideal height?
Old 05-13-22, 09:41 AM
Enkidu1
Enkidu1's Avatar
Bikes: Bike Friday New World Tourist
I bought a repair stand that mounts on a wall recently. Can anyone suggest the ideal height to mount it at? I am 6 foot tall BTW. It is a Conquer Bicycle Wall Mount Repair Stand Bicycle Rack - Rotating Head.
I can't post a link as I have not made 10 posts on this site yet.
Thank You
Zack S
Enkidu1 is offline
Old 05-13-22, 10:06 AM
blacknbluebikes
blacknbluebikes's Avatar
Bikes: two blacks, a blue and a white.
Quoted: 318 Post(s)
Liked 508 Times in 254 Posts
hmm. funny question. haven't come across a wall-mount repair stand before. thing is, I'm always changing the height based on what I'm doing. wrapping bars versus swapping a bottom bracket, for example. looks like product comes with two wall plates, so I would consider mounting them in a high / low config to at least provide two choices.
blacknbluebikes is offline
Likes For blacknbluebikes:
Old 05-13-22, 10:24 AM
cyccommute
Mad bike riding scientist
cyccommute's Avatar
Quoted: 4916 Post(s)
Liked 2,519 Times in 1,488 Posts
Thank You
Zack S
Mine is about eye level (Im 511). Its hard to tell from these pictures but you get the idea. The stand is a little tall at times but it generally works. I use shorter stands at my local co-ops which make for a bit more stooping when working on bottom brackets. Most of those can be adjusted but we generally keep them fairly short.
If you are the only person working on the stand, Id say a little below your eye level. If you have someone else who may be working on it that is shorter, mount it a bit lower.
Stuart Black
cyccommute is offline
Likes For cyccommute:
Old 05-13-22, 10:37 AM
70sSanO
70sSanO's Avatar
Quoted: 1648 Post(s)
Liked 1,681 Times in 1,053 Posts
For me stand/bike height is pretty dependent on what I am doing. As noted, standing to wrap bars, lube brakes, and doing tasks where I am not in one place for a while.
Drive train tasks, where I might be in one place for a while I’ll use a stool and make adjustments, change chain rings, cleaning RD pulleys, etc.
My suggestion is to consider a mounted stand height that allows for both.
I’m also a proponent of supporting a front/rear wheel when removing/torquing a bottom bracket or crank. I have a folding freestanding work stand so that does influence my perspective.
John
70sSanO is offline
Likes For 70sSanO:
Old 05-13-22, 01:05 PM
Enkidu1
Enkidu1's Avatar
It did come with two steel mounting brackets so I can mount one high and one low.
Enkidu1 is offline
Old 05-13-22, 07:32 PM
veganbikes
Clark W. Griswold
Quoted: 2913 Post(s)
Liked 2,110 Times in 1,397 Posts
Never seen or heard of that brand. I wouldn't want to mount to a wall unless for some odd reason that was the absolute only way to do it. I would just return it and get a separate stand. Park Tool makes some decent stands that you can change the height on and would be way more sensible for repairs.
If you are stuck on the wall mount make sure you mount to a proper stud.
veganbikes is offline
Likes For veganbikes:
Old 05-14-22, 04:53 AM
JoeTBM
Droid on a mission
JoeTBM's Avatar
Quoted: 237 Post(s)
Liked 169 Times in 117 Posts
I agree, about eye height or just below, the stand does allow for rotation of the bike so you could work height that way. BUT........
If you really want an adjustable height. I have a solution for you
If I recall properly, that wall plate is about 4-5" wide.
Mount it to a 20"x12" piece of 3/4 plywood and then mount the plywood to two vertical pieces of Superstrut (home depot) on 16" OC studs
The two pieces of strut must be plumb & parallel to allow the plywood to slide up or down and then secured by tightening the 3/8 bolts, washers & 3/8 spring nuts.(spring are cut off nuts to allow them to slide easier)
Holes thru plywood for 3/8 bolts should be 1/2" to allow some tolerance and wiggle room..3/8 bolts should be short enough to not bottom out on the base of the strut
Working height should be adjusted before mounting bike to work stand
JoeTBM is online now
Likes For JoeTBM:
Old 05-14-22, 10:01 AM
blinky
senior member
Bikes: 2003 Litespeed Tuscany with Ultegra R-8000 components
Quoted: 126 Post(s)
Liked 32 Times in 28 Posts
Thank You
Zack S
Just bought the Park wall mount using a wooden post in the garage and have the same question and so I'll be following the comments - am also 6 foot and don't want it too low because of back issues and being too high can make mounting the bike a challenge - and lifting the bike , holding it steady in the jaws , and then tightening the jaws isn't a cake walk for one person at any height .
And as it is with so many Park products , this stand is heavy duty and rugged - I started with 5/16 x 1" lag bolts ( 1/2 inch head ) but switched to 3/8 x 1 1/2 " with 9/16 inch head for more hold .
blinky is offline
Old 05-14-22, 02:12 PM
Bike Gremlin
Mostly harmless
Bike Gremlin's Avatar
Bikes: Custom made on Scott Speedster frame, Custom made on a 1996. steel MTB frame (all but frame changed at least once in the past 20 years).
Quoted: 1017 Post(s)
Liked 91 Times in 63 Posts
If it's of any help, my height is 178 cm and these are the dimensions of my DIY repair stand.
It's not too high in case I need to use the seat tube, while it's not too low in case I'm using a seatpost for holding the bike in the stand.
This works for me and I've never bothered to try and make it have an adjustable height.
Bike Gremlin is online now
Likes For Bike Gremlin:
