Salt water?
Quoted: 193 Post(s)
Liked 12 Times
Salt water?
Please tell me if I'm wrong in this assumption.
If you're hydrating properly (1/2 gallon+ of water a day, every day), you're drowning out your electrolytes throughout the day (I experienced the worst of this on a ride once after drinking over a gallon the day prior and it was awful). Then, you're sweating out even more of your sodium on your ride, making the electrolyte situation worse. So, if you're a frequent water drinker AND you sweat out lots of salt, shouldn't you be dropping a decent amount of salt in your water bottles to keep the sodium levels up?
Quoted: 17590 Post(s)
Liked 9,509 Times
This is why plants crave electrolytes.
Likes For Seattle Forrest:
working on my sandal tan
Quoted: 3628 Post(s)
Liked 2,058 Times
Quoted: 1935 Post(s)
Liked 1,196 Times
Do a web search for electrolyte drink mix. (Electrolytes are mostly salt.)
Or stop for lunch and order french fries, add lots of salt and ketchup. That tastes better.
Bikes: 1996 Trek 970 ZX
Quoted: 542 Post(s)
Liked 422 Times
In short: everything in moderation ... and, increased effort and intake has effects.
One of the effects of increased efforts can be higher water consumption, sweating. That'll certainly expel some electrolytes.
One of the effects of increased fluid intake can be increased flushing through urination. Which can also expel increased levels of electrolytes.
Can either add electrolytes to water and/or can get electrolytes via food intake.
I would think it's reasonably obvious that if effort goes up then the intake of fluids, electrolytes and foods need to go up. IMO, if engaging in athletics or hard training, particularly if enough to dramatically boost one's need for fluid intake, the electrolyte intake also needs to be considered. (Can get that through foods or via electrolyte additions to fluids.)
Used to do hard distance running, back in the day. Had to be well aware of the electrolyte levels throughout training season, if I wanted to avoid cramping up or having my performance ditch me in the latter stages of runs. Particularly during hotter weather, and particularly if having to dramatically increase my water intake to deal with a tough (of hours' long) session. Standard practice was to ensure electrolytes were a solid part of food intake through the prior ~18hrs, if knowing a hard run or two were coming up, and to ensure electrolyte got added to fluids if knowing the planned run exceeded a couple of hours. On the handful of occasions I glossed over this, I tanked ... and in at least a few instances I strongly suspected lack of electrolytes despite the increased fluid intake. Should have popped a couple of tablets into the bottles, beforehand.
Doesn't necessarily mean that increased fluid intake will flush everything out to the point of being deficient. But increased consumption and efforts do provide increased opportunity for the body to get rid of fluid and electrolytes along with it. So, adjust accordingly.
MotuekaCascadeChinook
Quoted: 4463 Post(s)
Liked 2,989 Times
You drank a gallon of water the day before your ride? Over and above your normal water consumption or was that your total water consumption over the entire day and you were also working or otherwise pretty active?
I've never done any such thing in preparation for a ride. In fact other than making sure I'm not thirsty before I leave for a ride, all my hydration, electrolyte and nutrition for a ride are taken care of during the ride and briefly after the ride for recovery.
Most people are going to naturally eat more salt that the recommended daily amount. So they'll get plenty of electrolytes for normal activity. It's only when you consume large amounts of water in a short time and don't have any source of electrolyte to go along with it that you'll have a problem.
If you only consume one or two bottle of water on a ride in a 1 - 2 hour period, probably not any issue. But 5 bottles of water in a short time and nothing else might be an issue. Or even 5 bottles of just water and nothing else in any amount of time.
I don't drink salt water, but if I am going out for a longer high effort ride in hot weather, I will eat a heaping scoop of Gatorade mix powder before heading out the door. I am a super salty sweater and I find this helps me from feeling sick to my stomach after an exhausting ride.
Bikes: 2020 Salsa Warbird GRX 600, 2020 Canyon Ultimate CF SLX disc 9.0 Di2, 2020 Catrike Eola, 2016 Masi cxgr, 2011, Felt F3 Ltd, 2010 Trek 2.1, 2009 KHS Flite 220
Quoted: 3476 Post(s)
Liked 2,432 Times
There's lots of literature and there are lots of products that will help you replenish electrolytes. It's easy to figure out with a little googling.
Endurolytes are one way to go.
As to adding, "salt", um, no.
just another gosling
Quoted: 3373 Post(s)
Liked 1,327 Times
One of the tricks to getting a good electrolyte balance is eating less salt in your daily diet. It turns out that the more salt you eat, the more salt you sweat and thus have to replace. And salt isn't the only electrolyte you need. You also need calcium, magnesium, potassium, and manganese. On a hot day, I'll take about 80mg of sodium an hour and about same for the others, except for manganese, only .5mg. To make this all very easy, I take Hammer Endurolyte capsules. I carry them in a little coin purse up my shorts leg. Most rides of even 4 hours, if it's not warm, don't need them. If it's hot, maybe 2 an hour if I'm doing a lot of climbing. Anyway, that's not a lot of salt or anything else. There are 2325mg of salt in 1 tsp. So mostly, you don't need anything except water as long as you don't drink too much of it!
I don't drink to thirst, not reliable. I drink to pee, that is once every 3 hours on the bike. If I can't pee after 3 hours, I drink water and take Endurolytes until I do. Also if my HR gets higher than it should for my effort, that also means I need to drink. If it's too low, I need to eat. It's not that complicated if you follow rules like this. It helps that our bodies are really good at regulating all our electrolytes all by themselves.
Results matter
Results matter
Likes For Carbonfiberboy:
Bikes: Frequently
Quoted: 139 Post(s)
Liked 193 Times
Liked 1,327 Times
And cramping isn't due to lack of electrolytes or dehydration. It's due to insufficient training for the what's being attempted. It's not complicated.
Results matter
Results matter
I don't drink sport's drinks, even on my 3+ hour rides in the Florida heat. I only drink water and eat a very balanced meal, which replenishes all I lost while sweating. Much of the nutrients I replenish comes from my yard/garden, so I know it's healthy.
I've only taken salt in tablet form when I worked construction and would finish a 5-gallon cooler of water a day by myself. In that situation if we didn't take salt, we would quit sweating and overheat. Sometimes, I like to mix a little Himalayan salt and lemon juice in my water just to make it taste better, and it seems to sit on my stomach better. I do think that if you are ingesting salt, it is very important to make sure you are drinking enough water to flush out any excess.
The term "salt" or "salts" is general. We often associate it with "table salt" which is sodium chloride, but all of those other minerals also have salt forms, like potassium chloride, magnesium chloride, calcium chloride. But those aren't all the salts formed with these minerals. There are also the sulfates like calcium sulfate. And then there are the carbonates like calcium carbonate. These are all "salts." Just adding sodium chloride to your water could be a bad idea because not only does it fail to replenish the other necessary electrolytes, it also increases your intake of sodium which is probably the least necessary given the abundance of it in most people's diets.
Liked 2,058 Times
One inexpensive way to get sodium chloride, potassium chloride, and magnesium carbonate in a drink mix, is to use Morton Lite Salt. I think this can be effective to boost the electrolytes in an otherwise watered-down Gatorade or Tang solution when the sugar-to-electrolyte ratio of those is too high. In other words, add some Morton Lite Salt to your water so you don't have to add so much Gatorade that you gag on the sugar.
