Weight of your touring bike?
Dirt Roadie
Quoted: 639 Post(s)
Liked 816 Times
My bike (Soma Saga) with front and rear racks, pedals, bottle holders, etc., but unloaded, weighs in at just over 30 lbs.
This makes me a bit worried that I may have over-done it. Is this atypically heavy, or about normal? Is it silly to even worry about weight before I start to load it up?
If it is not too personal, where does your racked but unloaded bike tip the scales?
(The main contributors in my case include robust wheels, Redshift stem and seatposts, and Tubus front and rear racks. I think the extra weight in each of these cases is more than justified, but it does add up.)
Likes For Polaris OBark:
Quoted: 2776 Post(s)
Liked 935 Times
My lightest touring bike (Lynskey Backroad) with no gear on the racks and no handlebar bag is 34.8 pounds with front and rear racks, water bottle cages, fenders, pedals, leather saddle, bracket for handlebar bag, pump, dynohub, dyno powered lights and USB charger, and touring weight tires. I do not remember if that includes a heavy lock, it is a titanium bike so the lock (Abus Bordo 6100) has to be heavy to offset the lightness of the bike.
There is light, and there is toooooo light. On touring bikes you need robust, reliable, easy to replace components, ease in repair, etc. I could have built this bike with fewer spokes, lighter rims, lighter tires, lighter saddle, etc. But I want a bike that will last and be comfortable to ride for the distance.
Photo includes handlebar bag (not included in the weight) but is missing the front rack (Tubus Tara that is included in weight total). And looking at the photo, that is not my touring wheel that has a Dyad rim and 36 spokes, a lighter wheel I sometimes use for riding around near home is on the bike in the photo.
Photo below is five years old, a few things have changed since.
My other two touring bikes are heavier. But I am going to get enough grief about saying what the bike above actually weighs, so I will stay silent on my other bikes.
Likes For Tourist in MSN:
Quoted: 15909 Post(s)
Liked 10,157 Times
I’m sure it’s over 35 lbs with the relatively heavy wheels I had built for it and the non-standard seat post. Also, it’s a 60 cm frame, and I have a platform front rack.
Likes For indyfabz:
Liked 935 Times
The bracket for the lock is hanging from the top tube, that is the bracket that came with it. The lock in the bracket vibrates a bit and make some noise, so I added the velcro strap to reduce any vibration noise.
Likes For 10 Wheels:
Quoted: 2360 Post(s)
Liked 1,173 Times
Miyata City Liner (I know it says Peckham, story behind that). Lugged steel, had it 25 years now, am finally about to start actually touring on it, having purchased Axiom and Roswheel racks and Ortleib F & R panniers. Weight with the F & R racks is a reasonable 31.1 lbs.
Likes For Steve B.:
Quoted: 347 Post(s)
Liked 413 Times
My "light weight" touring bike.
Dynamo, lights, fenders, pedals, and racks it comes to 29.5lbs.
36p wheel in back and 32p wheel in front, making the wheels a bit 'robust' maybe.
Likes For billridesbikes:
Bikes: 2016 Fuji Tread, 1983 Trek 520
Quoted: 570 Post(s)
Liked 411 Times
I think the bike should match the load. My bikes weigh a little less, in the 24-25 pound range, but I only use a rear rack and seldom pack more than thirty pounds. I weigh less than 150 pounds. I use lighter-than stock wheels and skinny tires.
Likes For andrewclaus:
Liked 935 Times
Almost everything that you have that is silver, I have in black.
Bikes: '19 Norco Bigfoot 6.1 (primary ride),'12 Motobecane Turino (killed by dog crash), '12 Trek 3700 Disc
Quoted: 121 Post(s)
Liked 97 Times
My bike (daily driver, tourer, grocery-getter, commuter, etc) with the rear rack and front cargo cages installed but no computer, panniers or even a water bottle weighs in at 43 pounds.
Likes For Bearhawker:
Likes For GhostRider62:
Bikes: Soma Saga, pre-disc
Quoted: 800 Post(s)
Liked 396 Times
I 'm not sure what size it is, either, probably a 60cm, but maybe the biggest 62cm. 🤔
The crazy thing is, it's unrideable right now, due to the rear wheel. It has XT hubs with 36-hole Velocity Dyad rims, which was one of the reasons I bought it, but the rear hub happened to be FH-M770, which was a rare Shimano "lemon", that I wasn:t aware of. 😟
I rode it from Sacramento to Seattle last year, then back to Sacramento this year, and it was fine till I came into Lincoln, a suburb on the Northern end of Folsom Lake.At least it didn't die up in the mountains. 🙄😉
Likes For stardognine:
It is kind of funny, but I am a weight weenie with my gear and don't usually weigh my bikes. I am just not inclined to mess with too much upgrading so I don't stress over the weight much once I have bought them. That said of the bikes I have toured on I do have a good idea of the weight on a couple. I think my loaded touring bike was 32# with racks, It was a 2007 Bikes Direct Windsor Touring, Essentially the same as a Fuji Touring. My light semivintage road bike about 24# with rack and cages and stuff. It was a 1990 Cannondale Crit bike. I usually include a 1# tool bag in bike weight since they live on the bike whether touring or not. I do not recall if those weights included that or not.
Pete in Tallahassee
Pete in Tallahassee
Likes For staehpj1:
Ultimately, we aren't racing, and yes if you're going to be carrying very little, a lighter bike with a lighter wheel set is fine, and will be nice to ride. You'll be faster, travel farther with same effort etc, but for typical touring, the 25 to 30ish weight is pretty much what you're looking at with a lot of bikes.
Put more effort of thought into paring down your load weight, this makes a real noticeable difference.
If I had money coming out of my ears, it would be fun having a real light bike for light touring, but at it is, my bike is what it is and with a change of tires, I can ride it pretty much anywhere, lightly loaded or heavily.
Likes For djb:
Liked 935 Times
..., it's unrideable right now, due to the rear wheel. It has XT hubs with 36-hole Velocity Dyad rims, which was one of the reasons I bought it, but the rear hub happened to be FH-M770, which was a rare Shimano "lemon", that I wasn:t aware of. 😟
When I built up my Lynskey five years ago I ordered an older style M756A.
https://www.treefortbikes.com/Shiman...-Rear-Disc-Hub
https://si.shimano.com/pdfs/ev/EV-FH-M756-A-3295.pdf
I do not think you can find 36 hole rim brake hubs anymore, you might need to get a disc one if you have a rim brake bike.
With the bike itself that is way less true. Often I think the wallet gets light faster than the bike does.
Pete in Tallahassee
Pete in Tallahassee
Likes For staehpj1:
Dirt Roadie
Quoted: 639 Post(s)
Liked 816 Times
Thanks, everyone.
Mine does seem to be slightly on the lighter side (which surprised me), but I have yet to add in fenders (CA doesn't have rain in the summer, usually, but if I go anywhere else, I will want them). I've had two previous touring bikes, and although I never weighed them, I think they might have been lighter (or maybe I was just younger.)
Liked 935 Times
Usually when the topic of weight comes up, we see lots of people with claims of super light bikes, but I never see such bikes in the campgrounds so I often wonder if they exist or not.
That said, I do trust Staehpj1 numbers, I saw a photo of his bike on Crazy Guy. And his descriptions of how light his bivy and other things are, with that much detail you have to trust it. .
This couple I did meet in a campground on a bike tour, they were from Utah, I met them during my Iceland tour. I am still amazed when looking at how light they packed, I really do not know how they did it. Both bikes were Ritchey Break Away frames, so they did not have airline oversize fees on their packed bikes. He had lost a water bottle, was looking for a replacement.
Ok, I will divulge how much much my expedition bike tips the scale at with racks, bottle cages, handlebar bag mounting bracket, pedals. I think this does not include the lock. Tips the scale at 47 pounds. But I think that includes fenders that I do not bring on tours, as the fenders do not fit in the case, so maybe drop 2 pounds?
But the frame is rated for 60kg of luggage capacity (excluding weight of rider and bike), so it has a really solid frame that won't fail. Rack bolts are M6 instead of M5. Rims are over 1.6 pounds each by themselves. Had about two weeks of food on the bike in the photo.
I used to complain about how heavy that bike is, but the bike handled that much weight so well that I no longer complain, I just acknowledge that it is a heavy bike. When I was in the interior with that bike, I met several other cyclists, three of which had a variety of mechanical problems with their bikes on such rough terrain, but mine felt right at home.
Quoted: 1598 Post(s)
Liked 1,318 Times
BeaverTerror
I've never seen a real touring bike that weighs less than 30lbs. You need certain parts to provide the mandatory capabilities. None of the weight is optional, and it all adds up. You can save some weight by using light weight components, but at the high end, parts become very expensive. Group set alone costs an extra $1000 to save about 1 lb of weight. When you add carbon fiber bars, stem, and seatpost, you'll end up spending $1500 to save less than 2 lb of weight.
Yan
Yan
Likes For Yan:
Liked 1,318 Times
