Using Garmin Varia with seat bag
I have a good amount of exposed seatpost to work with, and want to mount a Varia to the seatpost while still using a small seat bag. Garmin support told me that any bag no matter how small could block the radar. I'm just wondering if anyone's gotten away with a tool roll or similarly-sized bag mounted to their saddle rails while mounting a Varia several inches below.
Bikes: GR300, Grail, Live Wire, 5010
Quoted: 189 Post(s)
Liked 241 Times
This is my set up and it works great. As long as the RADAR antenna isn’t obstructed it will work without issue.
Forum Moderator
Quoted: 3090 Post(s)
Liked 6,593 Times
Mine works fine with this set up.
Likes For cb400bill:
Quoted: 18883 Post(s)
Liked 10,646 Times
Quoted: 6193 Post(s)
Liked 4,809 Times
Just don't let the bag rub on the unit. If yours is the model with the button on top then the bag rubbing on it might wear the button off exposing the internals like it did on mine.
Just put it on and see if you get decent results.
Sometimes practical experience can do more than theoretical talk
ignominious poltroon
Quoted: 2239 Post(s)
Liked 3,434 Times
J.
Bikes: Cannondale Synapse Carbon 105 (2021) Cannondale Cujo 2 (2018) Cannondale Quick Carbon 1 (2017) Giant Sedona (2006) Cannondale R1000 (2001)
Quoted: 65 Post(s)
Liked 238 Times
I used a small tool bag with the RTL-510 but sometimes it would press on the button and turn the radar off. Switched to a tool roll. I did not have any issues with the radar with the bag or now with the tool roll.
I use the Topeak saddle bags that clip onto a bracket and are easy to remove. On the ends I added Varia mounts that through bolt to the end of the bag and allow me to adjust the angle of the Varia for maximum range. The best mounts I have found on eBay after trying a couple sold on Amazon that were not nearly as well made. They sell for around $10 and the narrower ones with 2 mounting screws work better than the wider ones with 4 screws used.
https://www.ebay.com/itm/31307166409...0AAOSwU1tikHb1
