Latex tubes
Latex tubes
Does anyone have experience running latex tubes? I'm currently running standard butyl tubes and have been thinking about trying latex. Does it make a noticable difference in ride quality or speed?
Dave
Dave
Quoted: 795 Post(s)
Liked 639 Times
Lighter, smoother and loses pressure quickly. They really do have to be checked every other day. I put tubeless liquid in them and there's been no troubles with flats though, just have to be extra careful installing with new tires or really tight tires, they pinch very easily.
Beyond Bogus
Quoted: 18276 Post(s)
Liked 5,258 Times
Likes For datlas:
Dirt Roadie
Quoted: 647 Post(s)
Liked 825 Times
Sorry, I am being obscure. After spending months trying to find the right size latex tube (Vittoria or otherwise, for my 38mm Barlows), I decided instead to try them tubeless (with Latex sealant). I'm not a big tubeless fan, but it is working out ok so far. Jan/Rene Herse says it wouldn't make much of a difference in terms of rolling resistance, but my Garmin thinks it has. (Maybe because I am so slow to begin with, incremental differences matter more?)
Thread Killer
Bikes: '15 Kinesis Racelight 4S, '76 Motebecane Gran Jubilée, '17 Dedacciai Gladiatore2, '12 Breezer Venturi, '09 Dahon Mariner, '12 Mercier Nano, '95 DeKerf Team SL, '19 Tern Rally, ‘21 Breezer Doppler Cafe+, ‘19 T-Lab X3
Quoted: 2091 Post(s)
Liked 1,158 Times
I think TPU tubes are a much better option for most riders nowadays. They have none of the hassles of latex (like fragility, finicky install, and rapid leakdown), and offer lighter weight, better puncture resistance, and greater durability, with virtually the same low rolling resistance. They do cost about 2x as much, but almost certainly will last longer.
Mother Nature's Son
Quoted: 660 Post(s)
Liked 941 Times
I use latex tubes a lot. For me, it is more about the ride quality than any weight savings. Matched with quality tires, there is a very noticeable difference in the ride, more supple and smooth. One does have to be careful installing and inflating the latex tubes. I take a good look at the rim/tire around the whole circumference to make sure the tire is seated. Then, when inflating, I stop 3 or 4 times to do the same inspection. If you can find them on sale, IMO, they are worth the cost and care it takes, just my opinion.
Likes For delbiker1:
Beyond Bogus
Liked 5,258 Times
Some day we need to do a randomized trial with identical wheels/tires/pressure to see if we really can tell the difference.
Likes For datlas:
Mother Nature's Son
Quoted: 660 Post(s)
Liked 941 Times
I have done that very thing with a couple of different bikes. Both times were with the same wheels and tires, same routes at approximately the same speed, and same psi in the tubes. Certainly not a scientific trial, but my feeling is that there was a definite, quite noticeable difference it the ride quality. I did not try to go faster on one or the other, as I was not concerned with the weight/speed difference. I will say, IME, quality wheels and tires also make a difference. One stretch of road that I used has a lot of cracked tarmac that was repaired with the spray on tarry substance road crews use. It makes for a very bumpy, not drastic, ride. If riding that stretch with butyl tubes, I find myself avoiding as much of the repaired area as I can, with latex, not so much.
Beyond Bogus
Liked 5,258 Times
Bikes: Cannondale - Gary Fisher - Litespeed - Schwinn Paramount - Schwinn (lugged steel) - Trek OCLV
Quoted: 198 Post(s)
Liked 170 Times
I just got back into biking after a long hiatus - but before this I used latex tubes in almost every bike (road and off road) ; latex tubes lose air quickly but they are lighter than butyl and provide better ride / lower rolling resistance
tpu tubes retain air much better than latex tubes - possibly as well as butyl (?) - but gotta be careful with tpu tubes because they lack the 'elasticity' other tubes have ; they will expand but will not contract back to original size
also - some of the valve stems can be a little problematic
Quoted: 198 Post(s)
Liked 170 Times
if you do use latex tubes - and this process should be followed with every tube - you need a good quality rim strip and ensure it is installed properly (I use Velox or similar)
apply talc / baby powder (whatever) to inside of tire casing, rim strip, and tube when mounting tire / installing tube
inflate - check to ensure tube is seated inside tire - inflate halfway then deflate - then inflate again ... something like this to ensure the tube is seated properly inside the tire
also ensure the tire bead is seated properly on the rim - especially near the valve stem where sometimes the tire will lift slightly if the beefed-up part of the tube is not seated properly inside the tire
Likes For t2p:
I have been riding a very long time, and one thing I don't understand: What does is mean when it is said a tire/tube feels "supple?"
Beyond Bogus
Liked 5,258 Times
Softer/smoother, almost as if you dropped the PSI by 10 but still roll fast, so NOT mushy. It's rather subtle IMO but probably real. Maybe.
Likes For datlas:
Quoted: 198 Post(s)
Liked 170 Times
You've been riding a long time - you have a Lynskey and a 5200 Trek - and an old Paramount ... do you have experience with tubular tires ?
Or back in the day - experience with Michelin Super Comp HD or Vittoria Corsa Open CX (or whatever that tire was) - compared to a low cost OEM tire ?
Few upgrades will improve the feel and performance of a bike than a tire upgrade - and without knowing the price of the tire lol
Likes For t2p:
Bikes: '17 105 2x11 Sprint CF Comp / '21 GRX400 2x10 Poseidon X
Quoted: 223 Post(s)
Liked 403 Times
Latex seems noticeably better than butyl with 32-40c tires. Ride does feel slightly more supple, better puncture protection and not that expensive if you buy during sales. I haven't used latex tubes that go wider than 40c or smaller than 32c. With 30c and below tires, I do like the additional weight savings of TPU tubes while still having equal if not more benefits over latex (holds air better). TPU almost has the same responsive supple feeling as my tubeless gravel bike setup.
Another vote for TPU tubes. They are significantly lighter and, more importantly, make the tires feel like you're running them tubeless...
Likes For Caliwild:
Bikes: Subject to change at any given moment but currently is...... Colnago Mapei, Colnago C40, Wilier Triestina Carbon, Wilier Triestina Ramato, Follis 472, Peugeot PX60, Razesa, Orbea Terra, Soma Pescadero and 1/2 owner of a Santana tandem.
Quoted: 247 Post(s)
Liked 581 Times
Concerning TPU tubes, are there brands to avoid ? I’m interested in trying a set on my double century bike.
Thread Killer
Liked 1,158 Times
That said, for endurance riding, you may want to prioritize qualities other than minimal weight. Schwalbe makes claims about their Aerothan tubes outperforming other tube types, including other TPU tubes, in various categories including puncture and cut resistance, so I’d suggest looking closely at their documentation before deciding.
Sure, I don’t know if there’s any way to confirm or disprove Schwalbe’s claims, so it might get down to simply deciding to try to stack the deck in your favor, but it seems reasonable to presume that heavier TPU will be more durable than featherweights like Tubolito S or Revloop UltraRace. Certainly any advantages in weight savings or Crr reduction between regular and ultralightweight TPU will be extremely minimal and probably meaningless.
