Chain. Pin or quicklink
Quoted: 555 Post(s)
Liked 639 Times
When installing a chain, which is stronger: Pressing the pin with a chain tool or a quick link?
I had a chain break on me twice and I'm not sure if it was due to luck or my press in pin was a weak point.
Quoted: 836 Post(s)
Liked 1,061 Times
Depending on how many speeds your chain was designed for can have an effect as the fewer the speeds the easier it is to install the pin correctly and pins will usually be considered stronger as long as they are installed correctly but more opportunity for error. Current Quick Links of most brands are very reliable and easy to install correctly with not much chance of screwing it up but still gets done wrong occaisionally. .
Likes For Crankycrank:
Quoted: 555 Post(s)
Liked 639 Times
9 speed.
I had recently checked it for chain stretch, and it was still well within limits even though it has thousands of miles on it.
Getting a new chain (2 breaks is enough) and cassette too.
Likes For CrimsonEclipse:
Friendship is Magic
Bikes: old ones
Quoted: 26404 Post(s)
Liked 10,374 Times
...quick links seem to work pretty well for me. Not sure what you mean by a "press in pin" ? The newer chain pins are often peened, so when you press one in and out again, it enlarges the plate hole and can lead to failure. I know Shimano had those press in and break off pins, but you're not supposed to break the chain in the same place twice, for this same reason. I stopped using Shimano chains for this reason, so I'm not up on what they sell now.
Likes For 3alarmer:
Bikes: 1974 Masi GC, 1982 Trek 728 (aka 720), 1992 Trek Multitrack 750
Quoted: 122 Post(s)
Liked 221 Times
I'm with 3alarmer, I now only use chains with the quick-link, KMC and SRAM. It is practically idiot proof, and I should know.
Likes For HelpSingularity:
Clark W. Griswold
Quoted: 4348 Post(s)
Liked 3,985 Times
Probably either or. I really am not picky but yes a quick-link is a lot easier. Though I have put in plenty of pins over time and I don't really mind it at all but yes 3alarmer makes a decent point though I haven't had that problem yet.
Quoted: 1943 Post(s)
Liked 2,164 Times
As mentioned above, modern chains have pins that are peened; the ends are flared out.
It is impossible to pushed a larger diameter pin end through a smaller diameter chain side plate without reducing the flare.
Re-using that same pin will result in a weak spot in the chain and probably be susceptible to lateral forces from a poor shift.
In my mind a quick link will always be stronger.
John
John
Likes For 70sSanO:
Quoted: 1109 Post(s)
Liked 1,200 Times
Droid on a mission
Quoted: 317 Post(s)
Liked 280 Times
The quality of the tool has a lot to do with the success.
We will reuse the pin for single speed or 5/6/7/8 speed chain of non-peened rivets.
If it had peened rivets, we will use a quick-link or missing link connector.
Cheap chain tools don't keep the chain in a correct position for re-pinning.
Quoted: 2026 Post(s)
Liked 1,096 Times
"Peened" rivets (aka pins) are flared at the ends to make a strong connection in thin chains like 9-speed and above. Pushing them out breaks off the flair and reams out the hole in the side plates leaving a weak connection at that point if that pin is reused. A proper connection requires a quick link or a specific joining pin like Shimano provides. I do like quick links but have had no problems with Shimano's specific joining pins when used once as specified.
Likes For HillRider:
On older chains for 5/6/7 you could push the pin out fairly easily with the tool. With the new chains you have a hard time getting the pins out and it takes a good deal of force to get them out because they are flared as everyone here is saying. Shimano has one way of attaching chains, Campy has another, but I use KMC chains now with the master link which is so much easier.
Likes For zacster:
SE Wis
Quoted: 2745 Post(s)
Liked 3,390 Times
Likes For dedhed:
Quoted: 555 Post(s)
Liked 639 Times
So how do I identify a peened rivet chain?
Is it solid? hollow?
Mad bike riding scientist
Quoted: 6218 Post(s)
Liked 4,217 Times
But, frankly, using a quick link on any chain is just easier. It’s simple, works well, is strong, and doesn’t require all the fiddling of pushing a pin back in.
Stuart Black
Stuart Black
Likes For cyccommute:
New Shimano and Campy chains are designed to use a special pin, KMC chains are designed to use a quick link, I believe SRAM is too. I don't know about any other, nor does this apply to old style chains. I remember the first 9sp chain I installed and thinking, "what a PITA this is".
SE Wis
Liked 3,390 Times
https://www.campagnolo.com/US/en/Sup...onnecting_link
It makes me feel old that 10sp is an old technology now.
Quoted: 3504 Post(s)
Liked 2,924 Times
If you don't want to use a tool with your quick link, I can recommend Connex Quick Links. Ingenious design.
Quoted: 555 Post(s)
Liked 639 Times
Liked 2,924 Times
Likes For smd4:
