trek 400 - need front wheel cones and ball bearings
So I'm rebuilding this bike for a friend.. the front wheel has a little grinding.. so I wanted to buy just the outer ( removable cones ) and a new set on ball bearings.. any Idea where I could obtain these?? John
Really Old Senior Member
Typically, you'll have ten 3/16" balls per side.
Shimano alone had dozens of different cones for their various hubs.
Without a brand & model# one wouldn't have a clue which cone you need.
Trying to find replacements for old cones can be near impossible to sometimes very expensive.
If you have actual grinding, I'd inspect the bearing race to make sure it's not pitted before i invested in cones.
Bearings are relatively cheap & generic. Grade 25 is what we usually use, but even lesser grades such as 100 or 200 are suitable. Typically the price difference doesn't justify the cheaper bearing balls.
Quoted: 743 Post(s)
Liked 832 Times
As a parts those can be difficult to source, a coop or a local shop that sells used bikes could have some old hubs for parting out or replacement set of wheels.
Quoted: 294 Post(s)
Liked 119 Times
https://wheelsmfg.com/products/hub-p...cones.html?p=2 is another place to start if no coop or old established
LBS is not available. Looks like many are out of stock but the profiles and measurements should be helpful.
FWIW, for casual riding, a bit of grittiness in a hub is of little real consequence. And as noted, sometimes it is
cheaper just to replace a wheel if a secondary or tertiary market for such exists in your area. Older wheels are
sometimes quite nominally priced or free. Just check the rim carefully for damage or humps/wobbles when spun.
Bikes: lots
Quoted: 1637 Post(s)
Liked 2,409 Times
Oddly enough a Trek dealer can provide you with all the information and probably even order the parts for you.
Quoted: 1861 Post(s)
Liked 821 Times
I had a 1983 model and the vintage Trek catalog says it came with "Atom alloy" hubs and 27" (ISO 630) wheels. I recall these hubs had conventional cup-and-cone bearings using 10 x 3/16" balls in the front hub and 9 x 1/4" balls in the rear freewheel hub. If the cones are pitted, I'd take them to an older bike shop and just look for a close match. A Trek dealer will probably no longer stock an exact match.
Likes For HillRider:
SE Wis
Quoted: 2143 Post(s)
Liked 2,167 Times
Liked 821 Times
Señor Member
Quoted: 2425 Post(s)
Liked 3,233 Times
Nine more posts, and you can upload pics of the cones. Doubt they're that bad.
