Is There a "Single Power Button" Lighting SYSTEM Available These Days?
Bikes: Cannondale Carbon Synapse Road, Cannondale T2000 Touring, Vintage Mongoose IBOC Pro MTB, Vintage Peugeot 12spd racer, Old rusty Schwinn Manta Ray I neglected as a child, Diamondback Haanjo EXP Carbon & Metro, Specialized Roubaix Pro, RaleighSC Tandem
Quoted: 225 Post(s)
Liked 39 Times
Having been hit during the night hours, I typically use two 750 lumen headlights combined with 3 Cygolite Hotshots in the rear.
The rear of my helmet also has a custom mounted Niterider Solas, used in extremely hazardous conditions.
If you've ever been rear ended and had spinal injuries, you'll understand that drivers need to be overly alerted to your presence.
They're programmed to look for cars, not bikes!
I do most of my errands on bike and often need to power down all my lights upon arriving at the store, etc......only to have to power all of them back on again, upon leaving.
I sometimes make several stops and as you can imagine, that's a lot of time spent pushing and holding down buttons!
I've been a little out of the bike lighting "loop" so I'm wondering if there is some sort of SYSTEM out there now, where all the lights are (or can be) rigged to one switch...???
Thanks in advance!
Thanks in advance!
Quoted: 680 Post(s)
Liked 948 Times
Yes buy a garmin or such then buy a bunch of ANT+ lights turn the garmin on and all the lights come on and garmin will notify you when batteries are low. the way the light can change with daylight and night changes too.
Palmer
Quoted: 1666 Post(s)
Liked 1,818 Times
Cateye Sync.
Another approach: dynamo hub and wired-in headlights and safety lights. Bike moves, lights come on. You can get the ones where the lights stay on for a while (stand lights) when you're stopped at an intersection.
ignominious poltroon
Quoted: 2239 Post(s)
Liked 3,434 Times
The main problem is that the Garmin and all of the lights are high-value theft targets.
