Spacer Material: Does It Even Matter?
Keeling over.
Bikes: 1990 Raleigh Flyer (size 21"); 2014 Trek 7.6 FX (size 15"); 2014 Trek 7.6 FX (size 17.5"); 2019 Dahon Mu D9; 2020 Dahon Hemingway D9
Quoted: 525 Post(s)
Liked 1,097 Times
So, let's say that you need to space a brake caliper away from an adapter or a mount because you'd like to use a larger rotor for whatever reason (say, from 160mm to 165mm or 170mm.) Would you rather use a spacer that's aluminum alloy, brass, or steel? Would you use one or the other just because you happen to have a few lying around? Does it even matter?
Likes For dsaul:
Likes For Crankycrank:
Quoted: 1935 Post(s)
Liked 1,194 Times
Titanium if it's going to show and you care about such things. Anything but cardboard will work just as well.
Depends on the metal it's bolted on to help avoid galvanic corrosion. You can also grease the thing to further prevent galvanic corrosion.
Quoted: 640 Post(s)
Liked 510 Times
Aluminum cans (beer, pop, whatever) makes great spacer and shim material, sometimes in multiple layers to get the thickness you need. It's very easy to work with - you can cut it to shape with an ordinary kitchen scissors, or any scissors other than one you want to keep really sharp (i.e. sewing, hair cutting, etc). A dab of super glue will hold layers together if you need to.
MotuekaCascadeChinook
Quoted: 4458 Post(s)
Liked 2,988 Times
I'd probably use what ever I had on hand. Just so I could ride sooner. If the looks bothered me or it started to corrode at some point in the future, then I'd deal with it then and use some other material that might work better in the long run.
Likes For Iride01:
Clark W. Griswold
Quoted: 2912 Post(s)
Liked 2,108 Times
I would just use the proper adapter generally from the manufacturer who made the brake caliper but North Shore Billet, Paul make really great stuff and work nicely. If I needed spacers I would probably use stainless steel spacers or aluminum if I had those on hand but generally I shouldn't have that issue if using the correct adapter.
Likes For veganbikes:
Bikes: '18 Redline Zander, '14 Surly Pugsley, '97 GT Vantara, '97 Trek MultiTrack 750, '70 Peugeot UO-18 Mixte
Quoted: 1325 Post(s)
Liked 605 Times
If you're spacing a brake caliper, I'd use only a monoblock spacer designed for this application. I think they're all aluminum alloy, but the material is less important than the structural rigidity here. The original post reads to me like individual spacers are being considered that would simply move the caliper further from the mount (such as small cylindrical spacers). This will create a lot of lateral load on the spacers and fasteners during brake application and I'd be concerned about failure here. Individual spacers will also likely not put the caliper in the best position relative to the rotor...most monoblock spacers rotate the caliper slightly in addition to moving it further from the mount, to ensure the swept area of the pads remains in good contact with the rotor's braking surface.
Likes For hokiefyd:
working on my sandal tan
Quoted: 3628 Post(s)
Liked 2,058 Times
Likes For ThermionicScott:
Bikes: n, I would like n+1
Quoted: 85 Post(s)
Liked 97 Times
Likes For jccaclimber:
Quoted: 409 Post(s)
Liked 303 Times
The wax in that paper is just like the shipping grease on a new chain. It should be carefully removed with the solvent of your choice in an ultrasonic cleaner, then replaced with a less dirt attracting high temperature brake specific lubricant. If the lubricant doesn’t cost 2x more than it should the you’re using the wrong one.
Likes For easyupbug:
Quoted: 85 Post(s)
Liked 97 Times
While most of my posts are quite serious, I hope nobody takes that particular one seriously.
As for the religious matter of factory chain lubricants, I defer to the ZFC report.
