Totally Tubular
Totally Tubular
Old 05-13-07, 08:02 PM
  #251
Old Fat Guy
Liked 10 Times in 6 Posts
Originally Posted by Road Fan
I use a two-coat procedure, either the one recommended by Lennard Zinn, or the one printed on the wrapper for Vittoria tires. Both work well. I do not clean old cement off of rims.
Road Fan
+1
Old Fat Guy is offline
Old 05-21-07, 08:13 AM
  #252
sekaijin
sekaijin's Avatar
Bikes: 2000 Litespeed Classic, 1984 Schwinn LeTour, 1998 Gary Fisher Marlin, 1969 Hercules, 1977 Sekai 5000 Superlite, 1993 Koga-Myata TerraLiner, 2013 Trek Farley.
Fixed my first tubular flat
So, I hung my bike up after a ride and noticed a thorn lodged in the front tubular. Pulled it out and pfffft .... well, at least I was lucky enough to make it home without flatting on the road.
The tire was already pre-treated with Tufo sealant per waytoomanybikes's advice, and I added another half-tube (the small size tube) of sealant. It seems to have worked!
The puncture was on the side of the front tire - at the edge of the tread, almost on the sidewall - so I hung the bike by its rear wheel from a ceiling hook, added the sealant, inflated, and turned the front wheel at 90 degrees so it could spin parallel to the ground like a record on a turntable. That hopefully helped the sealant settle into the sidewall zone of the inner tube.
Before starting I actually masked the fork and downtube because I was worried about sealant spraying out. Didn't happen at all.
Quick, easy job except for the need to wipe up a few stray drips of sealant. Still waiting for the ultimate proof since I have not ridden on it yet since the fix. But the tire is inflated at full pressure and holding air.
If this holds, I am a Tufo sealant believer.
sekaijin is offline
Old 05-21-07, 10:26 AM
  #253
DiabloScott
It's MY mountain
DiabloScott's Avatar
Bikes: Klein, Merckx, Trek
Quoted: 4338 Post(s)
Liked 2,980 Times in 1,617 Posts
Do you have a removeable core or did you figure out how to get it in there without removing the core?
I had a tire that spewed sealant stuff all over the bottom of my down tube - it would lose a little air, seal, spew some more, seal again, it was amazing how much came out and the tire was still rideable but the seal never really held. I'd like to try the Tufo stuff if I can get it in there without breaking off the valve closure nut.
DiabloScott is offline
Old 05-21-07, 10:42 AM
  #254
sekaijin
sekaijin's Avatar
Removable core. Without one, wouldn't you risk the sealant drying in the core and clogging the valve?
sekaijin is offline
Old 05-21-07, 11:19 AM
  #255
DiabloScott
It's MY mountain
There are some kinds of sealants that allow injection through the valve - Seal & Flate, Pit Stop, Presta Seal... in my experience, they don't work as well as Slime or <maybe> Tufo sealant.
Old 05-21-07, 11:25 AM
  #256
sekaijin
sekaijin's Avatar
No experience with those others, only Tufo which was recommended to me and my LBS stocks it ... they could be as good or better than Tufo, no idea.
sekaijin is offline
Old 05-23-07, 11:19 AM
  #257
sekaijin
sekaijin's Avatar
Two days later, I've ridden the bike about 50 miles including some hill training, and the flat fix seems just fine. I am happy.
sekaijin is offline
Old 07-05-07, 02:55 PM
  #258
piwonka
park ranger
Bikes: recumbents
i have glued a few tires. even if i get the tires on straight there seems to be a little lump around the valve stem area. i was told this is common and one thing you can do, is make a small recess in the rim at the valve stem hole.
any comments on this?
piwonka is offline
Old 08-04-07, 02:32 AM
  #259
Stefi
I'm completely new to tubulars and this morning I naively thought I'd be able to put the tire on! Ha! There's no chance. It really seems like its the wrong size tire, I've triend yanking and stretching but there's no way of getting it onto the rim. I;ve read the advise on this thread and you all say leave to stretch on the rim ——— but how do I get it on there???! Thats the problem!
Any other suggestions on how to stretch the tire??
Thanks
Stefi is offline
Old 08-04-07, 04:16 AM
  #260
East Hill
Lanky Lass
East Hill's Avatar
Location: Take a deep breath, and ask--What would Sheldon do?
Bikes: Nishiki Nut! International, Pro, Olympic 12, Sport mixte, and others too numerous to mention.
Quoted: 5 Post(s)
Liked 6 Times in 6 Posts
Thanks
I sat down in the middle of the floor, braced my feet against the inside of the tyre, held onto the tyre with all my arm's strength, and straightened out on the floor.
Mr. East Hill thought I was mad. But I did eventually get the tyre on the rim. I left the tyres alone for about a week before I tried gluing.
East Hill
___________________________________________________
TRY EMPATHY & HAVE LOVE IN YOUR HEART, PERHAPS I'LL SEE YOU ON THE ROAD...
East Hill is offline
Old 08-04-07, 04:33 AM
  #261
Stefi
Well you're a better woman than me, I've tried everything, the things just aren't stretching! It goes about half way arounf the rim only!
Stefi is offline
Old 08-04-07, 05:48 AM
  #262
East Hill
Lanky Lass
East Hill's Avatar
Quoted: 5 Post(s)
I think having to deal with 140 pound containers on a daily basis helps a lot .
That's approximately 63.5 kg...
East Hill
Old 08-04-07, 06:05 AM
  #263
USAZorro
Señor Member
USAZorro's Avatar
Quoted: 1491 Post(s)
Liked 1,090 Times in 638 Posts
Thanks
Try putting it on somewhere that's uncomfortably warm. The rubber will become more pliable.
USAZorro is offline
Old 08-04-07, 06:19 AM
  #264
East Hill
Lanky Lass
East Hill's Avatar
Quoted: 5 Post(s)
Oh, that reminded me: I did this in front of a very hot fire in December. That probably helped .
East Hill
Old 08-06-07, 09:24 AM
  #265
sekaijin
sekaijin's Avatar
OK, here’s my totally tubular tale du jour.
To give away the ending: 1) tubulars good! 2) put sealant inside!
I went for a 50 mile ride with a couple friends in hilly rural country on Saturday morning.
It wasn’t supposed to rain till evening. So we were surprised when the rain arrived around noon. We took a different route back that looked a little shorter on the map. To our great dismay we hit an unpaved road, and rode about 2 miles on gravel – not rounded rocks but good jagged stuff. It was tricky going. One guy swerved and fell, skinning his elbow and knee.
So there I was, riding my lovingly restored vintage steel lightweight in the rain, trying to stay upright while slogging through gravel and mud on my tubulars. Not what I had in mind!
Somehow we got through the gravel and the rest of the ride without a flat.
The next day, I noticed my rear tire was a little soft. Hmm, must be either a slow leak or a puncture that “healed” from the Tufo sealant I’d put in the tubes. (Thanks to waytoomanybikes for suggesting it here)
I’m thinking it was the sealant, because Monday morning (today) the tire felt the same. I added some air and rode it to work. It seems fine.
Second time this season Tufo sealant has come through for me … I’m sold on it.
sekaijin is offline
Old 08-06-07, 09:46 AM
  #266
OLDYELLR
My bikes became Vintage
OLDYELLR's Avatar
Quoted: 12 Post(s)
Liked 8 Times in 8 Posts
Since two main reasons for running tubulars is light weight and liveliness, what effect does putting sealant inside them have?
OLDYELLR is offline
Old 08-06-07, 11:00 AM
  #267
sekaijin
sekaijin's Avatar
I haven't ridden skinny road clinchers in 10 years, so I don't have a good feel for the comparative weight and liveliness.
But tubulars and their rims are pretty light. And they don't require much sealant inside (a liquid ounce or two?), so I figure the effect is slight. Certainly less than the effect of changing a tire at the side of the road.
sekaijin is offline
Old 08-28-07, 07:25 AM
  #268
sekaijin
sekaijin's Avatar
Time for a new pair of tubulars ... does anyone have comparative experience with Bontrager's Race Lite vs. Race X Lite Pro? Which should I get, is the Pro worth twice the price?
sekaijin is offline
Old 01-04-08, 11:54 PM
  #269
shakeNbake
Mooninite
shakeNbake's Avatar
Bikes: $53 Walmart Special
Liked 2 Times in 1 Post
Hey guys,
I've decided to dabble into the dark arts (tubulars), so I bought a pair of used Mavic GP 4. Now the question is, should I clean the old glue off the rims?
shakeNbake is offline
Old 01-05-08, 08:42 AM
  #270
sykerocker
sykerocker's Avatar
Bikes: The keepers: 1958 Raleigh Lenton Grand Prix, 1968 Ranger, 1969 Magneet Sprint, 1971 Gitane Tour de France, 1973 Raleigh Tourist, 3 - 1986 Rossins, and a '77 PX-10 frame in process.
Quoted: 221 Post(s)
Liked 237 Times in 129 Posts
I've got a couple of quick (and possibly horrifying to some forum members) way of getting the job done. Then again, I've always valued results, not subtlety:
1. Bring the wheels to work and use the parts cleaner.
2. Steal a little kerosene from the shop heater, soak a rag and wipe it down.
3. If all else fails, a rotary wire brush (SOFT!) on a power drill will take down anything.
That red glue on the right rim has always been fodder for the rotary wire brush.
Syke
“No one in this world, so far as I know — and I have searched the records for years, and employed agents to help me — has ever lost money by underestimating the intelligence of the great masses of the plain people. Nor has anyone ever lost public office thereby.”
H.L. Mencken, (1926)
sykerocker is offline
Old 01-05-08, 08:50 AM
  #271
OLDYELLR
OLDYELLR's Avatar
Quoted: 12 Post(s)
Just chisel the bigger lumps off with a screwdriver. I've re-glued ones that had thicker glue on them. Wire brush too often and you won't have any rims left.
OLDYELLR is offline
Old 01-05-08, 10:22 AM
  #272
piwonka
park ranger
Bikes: recumbents
if the glue is hard you can scrape it off. if it's soft you can just put a coat of glue over it. maybe pick off the larger clumps of glue.
piwonka is offline
Old 01-05-08, 11:20 AM
  #273
Old Fat Guy
You realize that you are missing the spoke eyelets in a few places, don't you? Those may be difficult to replace.
Old 01-05-08, 12:09 PM
  #274
iab
iab's Avatar
Quoted: 3015 Post(s)
Liked 3,802 Times in 1,408 Posts
I'm thinking those may be the valve holes. And for cleaning, if the glue isn't completely dry, it will just fill your wire brush and make it worthless. Also for "wet" glue, mineral spirits works much better than xylene.
iab is offline
Old 01-05-08, 01:12 PM
  #275
Old Fat Guy
Yes, I think you're right, valve holes, duh!
