handlebar tape recommendations
Bikes: '23 Poseidon Redwood, '07 Specialized Roubaix Comp Triple, '12 Gravity Fixie, '21 Liv Rove 4, '06? Giant EB Spirit
Quoted: 345 Post(s)
Liked 237 Times
I bought and installed some Profile Designs handlebar tape without adhesive. Took me a few tries but I think I can do it correctly now. The tape feels fine and is good quality.
My concern even after wrapping tightly from the inside out (starting at the bottom of the bars) is that I get slight shifting when in the drops.
The previous tape had adhesive and didn't move even with a gel insert underneath (I left this gel for the drops only so I am not sure if this is the reason for the shifting - it doesn't do this on the tops.
Would I be better off with an adhesive lined tape or should I remove the gel inserts and try again?
Also, what do you recommend? I don't need anything really high end like lizard skins but would like it to last, not move and be washable.
I've searched on forums and see that Deda is recommended as is the "gel" type tapes.
Thanks again for the help
Quoted: 345 Post(s)
Liked 237 Times
Looks like it was the gel inserts. I removed them and its stable now. I suspect if I had adhesive lined wrap it would have been ok with the gel. Good to know.
Profile Design wrap is quite good btw. Don't know how long it will last but so far so good.
My previous wrap, Specialized Bar Phat lasted 13 years! Would have gotten that if Amazon had carried it.
Thread Killer
Quoted: 3133 Post(s)
Liked 1,701 Times
Wow, 13 years is longer than I’d expect bar tape to last. Hopefully your new stuff lasts as long, too.
Method to My Madness
Bikes: Trek FX 2, Cannondale Synapse, Cannondale CAAD4, Santa Cruz Stigmata GRX
Quoted: 1943 Post(s)
Liked 1,464 Times
I second the Profile Designs Drive tape sold by Amazon.com. It is comparable to Fabric Knurl, which is more expensive (and only sold by third party sellers). Profile Designs Drive has slightly better grip. Fabric Knurl has slightly better cushioning, maybe because it is adhesive lined so I did not have to stretch it as much during installation.
South Carolina Ed
Bikes: Holdsworth custom, Macario Pro, Ciocc San Cristobal, Viner Nemo, Cyfac Le Mythique, Giant TCR, Tommasso Mondial, Cyfac Etoile
Quoted: 344 Post(s)
Liked 291 Times
You could just unwrap what you got, wrap some double-sided "scotch" tape where you think you need it, and then re-wrap with your existing tape.
fwiw I buy the $2-$3 dollar tape on Ebay which comes in a lot of colors, wraps easily, stays tight, and holds up well.
Sunshine
Quoted: 10954 Post(s)
Liked 7,483 Times
Bar tape is like gloves or socks- wash it every now and again and change it here and there perhaps? Bars can corrode from sweat that gets thru the tape too, so the internet says.
Quoted: 345 Post(s)
Liked 237 Times
Observation
I find that having gel in my gloves it’s good enough. No need to also have it in the bar tape. Ymmv
Clark W. Griswold
Quoted: 4348 Post(s)
Liked 3,985 Times
Lizard Skins 3.2 DSP is my favorite and 13 years is WAY TOO LONG for bar tape. You should take it off regularly (at least every 2-3 years depending on your usage) and you would need to, so you can replace cables and housing (which also are wear items and should be replaced with some regularity). The reason to remove the tape is to check your handlebars for corrosion. You could have a ticking time bomb underneath and wouldn't know it but that bar tape is soaking up your corrosive sweat and holding onto it quite nicely to attack the typically aluminum bars underneath.
Likes For veganbikes:
Likes For Andy Somnifac:
Quoted: 20810 Post(s)
Liked 9,456 Times
I'm a big fan of Bontrager Grippytack - great feel and it looks nice with the peek-through color. Installation can take a bit more work and care, you need to give it a good stretch to make sure it lays flat as you go around the curves, but I think that it's worth the trouble and expense.
Bikes: Merlin Extra Light, Orbea Orca, Ritchey Outback,Tomac Revolver Mountain Bike, Cannondale Crit 3.0 now used for time trials.
Quoted: 126 Post(s)
Liked 55 Times
Lizard Skin
Likes For Sojodave:
Advocatus Diaboli
Quoted: 4733 Post(s)
Liked 1,532 Times
Likes For Sy Reene:
Bikes: Speedvagen Steel
Quoted: 429 Post(s)
Liked 248 Times
Or you can go full on leather by Busyman Busyman Bicycles
Custom patterns and colors, mine is going on three years now
I've been using 3MM Fizik Tempo Microtex Bondcush Classic for a while now. Fizik offers a ton of different, confusingly named tapes but this one is my favorite:
- perforated glossy leather-like appearance that looks good on any of my bikes
- very, very durable finish, basically looks new until you get sick of it / want to check your bars
- doesn't absorb sweat or rain
- grippy
- easy to wrap tightly
- available in a ton of different colors
- grippy
Bikes: State Bicycle Co. Undefeated Track SS/FG, Lynskey Helix-Bronze
Quoted: 115 Post(s)
Liked 204 Times
Ciclovation Aurora Purple
Supacaz Prizmatik
Supacaz Oil Slick
Likes For primov8:
Bikes: 89 Paramount OS 84 Fuji Touring Series III New! 2013 Focus Izalco Ergoride
Quoted: 285 Post(s)
Liked 74 Times
Like the feel of the lizard skin but doesn't wear well for the price, so switched to fizik.
scott s.
scott s.
Quoted: 763 Post(s)
Liked 1,731 Times
Likes For jaxgtr:
Quoted: 345 Post(s)
Liked 237 Times
https://profile-design.com/collectio...ducts/bar-wrap
Bikes: Tcr advanced sl & Protos
Quoted: 116 Post(s)
Liked 60 Times
I just put on some Selle tape that was 17$ marked down from 40+$ on competitive cyclist.
It’s pretty close to the feel of lizard skin. Not quite as tacky, but very close.
Likes For Greatestalltime:
