Turn a slammed race bike into an endurance bike without touching the stem
bike whisperer
Quoted: 1527 Post(s)
Liked 718 Times
...As long as you're a toe pointer.
Sheldon Brown's bike info ~~~ Park Tools repair help
Half-step triple, using double gear ~~~ 6400 STI rebuild walkthrough ~~~ Want 8/9/10s @126mm OLD? OCR. ~~~ Shimano cassette body overhaul ~~~ Ergopower Escape wear repair ~~~ PSA: drivetrain wear
List of US/Canada bike co-ops ~~~ Global list
Expired Member
Quoted: 3661 Post(s)
Liked 5,408 Times
#Moisture
Likes For shelbyfv:
bike whisperer
Liked 718 Times
Quoted: 6191 Post(s)
Liked 4,806 Times
Most road bikes with slammed stems or low stack are still endurance road bikes. Just because you can't endure the position has nothing to do with it. Mostly it's the angle of the seat tube that makes them an endurance bike. Everything else is fit from there.
And where in your video do they explain your title? I've not the time to watch a 12 minute vid for something that doesn't seem related from the get go.
Likes For Iride01:
Bikes: Schwinn Varsity
Quoted: 1931 Post(s)
Liked 742 Times
Could somebody translate the language for me. I don't understand what they are saying.
There has to be some kind of license or test before being allowed to use a video camera.
Quoted: 18883 Post(s)
Liked 10,646 Times
I ride a perseverance bike.
Likes For Seattle Forrest:
The author of this video claims a 3-4cm drop in saddle height is appropriate with a midfoot cleat. That sounds like too much to me. I do a lot of out of the saddle pedaling, so midfoot isn't for me.
FWIW, an endurance bike mainly has a taller head tube to produce a more upright position. The seat tube angle has no part in the difference. Fit is determined by reach and stack. The only thing that the STA affects is your choice of seatpost setback.
Liked 4,806 Times
In general, it was always the seat tube angle that distinguished cruisers, road bikes and time trial bikes. Cruisers being the least vertical and TT bikes the most vertical. Head tube length itself is more about the size of the frame, not endurance. Particularly the old style bikes with horizontal top tube. However stack is what plays a big part in giving you a more aero or aggressive fit, as to a less aero and less aggressive fit. You don't have to have much head tube to have a lot of stack on bikes.
Endurance is nothing to do with how well any particular position you can endure. Just because you can't endure a race fit doesn't mean it's not an endurance bike. Or how else would some people be putting 5K, 10K or 15K a year on them?
At the marketing level for bikes, once you eliminate all the possible things that make it unique, like race, performance, fitness, then endurance is all that is left. But all the others were endurance bikes too. At least by everything I was told and read for all these years starting back with my first Schwinn.
Quoted: 20810 Post(s)
Liked 9,456 Times
I guess all we can do is agree to disagree.
Likes For WhyFi:
A good example is the Trek Domane compared to an Emonda. The seat tube angle has nothing to do with the fit. The stack is the main dimension that stands out as different. The 52cm size that I would ride has about a 40mm difference in stack height, while the seat tube angle difference is trivial.
https://www.trekbikes.com/us/en_US/b...-etap/p/33140/
https://www.trekbikes.com/us/en_US/b...-lt-9/p/32579/
Bikes: SuperSix Evo | Revolt
Quoted: 733 Post(s)
Liked 815 Times
So loss of acceleration, unsteady sprinting or climbing out of the saddle, and not mentioned, but obviously increased toe overlap. No thanks.
Please back up this opinion with some links that compare the geometry of a race frame to an endurance model, in the same brand. About 95% of a longer head tube length goes directly to stack height. A relaxed fit is more upright with a taller stack and often a shorter reach. The steering trail might also be larger. Some brands add 20mm to the stack and others may add up to 40mm.
Not always. This is only possible if you have no spacers under the Domane's stem and a bunch of spacers under the Emonda stem. You're outta luck if you have spacers under the Domane's stem.
Quoted: 1067 Post(s)
Liked 259 Times
In my case the Domane is slammed but the Emonda doesn't need many spacers as they are both H2 and the geometries aren't that different.
Bikes: Focus Arriba, Specialized Roubaix Expert, Bianchi Impulso Allroad
Quoted: 109 Post(s)
Liked 82 Times
You are talking about the touch point dimensions, not changing the frame geometry. Rake/Trail, Wheelbase, Chainstay length are all different between your Emonda/Domane. Different geometry, and different handling characteristics... incremental, to be sure, but definitely different.
Likes For redcon1:
While it's possible to match certain fits between a racing and endurance model, you can't buy the same size domane and get the same fit as a slammed Emonda. Slammed is no spacers and a -17 stem. That's how I set up my previous Colnago frames with a 527mm stack, to get a 10cm saddle to bar drop. Just changing to a -6 stem raises the bars by about 2cm. I now have the smallest size Cinelli superstar frames, that have an 18mm lower stack. These frames are set up with a 30mm tall conical headset top, that drops the bars about 3mm lower, using a 10mm longer stem. I left the steering tube longer, to preserve resale value.
Endurance frames are intended to have a more upright fit, with less saddle to bar drop. Trek recommends a 52cm size for the same height range in both models, but obviously, the domane can't be set up as low as an emonda.
Quoted: 733 Post(s)
Liked 815 Times
Likes For Rides4Beer:
Liked 4,806 Times
I do have to admit that the overwhelming degree of specializing and categorizing things today is probably against me. But still I'll don't see a road race bike any less endurance than road bike frames only categorized as endurance.
What is or isn't endurance is the fit. A person that is properly fitted on either can be comfortable for a long time to endure the miles ahead. The moniker of endurance is another misleading term to me that make newbs and uninformed automatically think that an aggressive position is uncomfortable. Just as race itself makes many think that position isn't for them. So there gets to be a stigma with the terms that sub-consciously keep people away from one or the other for the wrong reasons.
Head tube length really only plays a part in stack as you go bigger in frame size of the same model bike. Endurance bikes in their geometry typically get part of their extra stack by having more BB drop. The less reach part also gets handled by head tube angle, where not much makes a big difference to reach and wheel base. Fork design also make head tube length not so important to stack. a fork with more crown and longer blades will let you get more stack with a more normal looking head tube size.
The old vintage frame geometries, had bikes with long head tube and high stack. But they were also very large for anyone bike frame. Bike manufacturers started changing geometries up when they noticed people had started shoving longer seat posts in them and using much smaller frames than suggested sizing so they could get the low stack they wanted for their size. And they road them on long rides that were called endurance rides. That is the time when road bikes also began to take on the same meaning and also became known as endurance bikes. Maybe just for me and my thinking only, but there it is.
I'll try not to change the worlds thinking on this so much any more, just so we get past this. But please don't tell me that endurance means I'll be more comfortable on long rides than a properly fitted road bike with a race fit.
A common mistake is thinking that BB drop affects the stack. It does not, since stack is measured from the center of the BB.
Bikes: 89 Paramount OS 84 Fuji Touring Series III New! 2013 Focus Izalco Ergoride
Quoted: 285 Post(s)
Liked 74 Times
But most marketed "endurance" bikes also feature more compliance, via wider tire, rubber suspension bits, etc. even if you can get identical fit.
scott s.
scott s.
Likes For scott967:
Quoted: 109 Post(s)
Liked 82 Times
The fact you can't see a difference is your problem - not everyone else's. The clear distinction exists--whether or not you acknowledge it, or even perceive it.
Quoted: 741 Post(s)
Liked 412 Times
Trek’s Project One used to allow buyers to choose a head tube height. People have different levels of flexibility and body dimensions. What one finds comfortable, another might not. I am not sure what the real argument is but a taller head tube does not automatically make a bike an endurance bike. Really, any bike you race is a race bike. I believe Thor Hushvold rode a Roubaix for awhile.
Liked 4,806 Times
How does that equate to I don't see a difference? If I was to go only for comfort above everything else, I'd leave some performance things behind. I don't see how being comfortable on multiple types of bikes is a problem. Whether it's me or you. Not being able to get comfortable on a bike is a problem. Might be your problem.
