Affordable lighter steel road bikes with 27” wheels
Bikes: 2015 Felt Z75 Disc, 2008 Fuji Cross Comp, 2010 Trek Navigator 1.0, 1974 Raleigh Sports, 1974 Schwinn Le Tour, 1981 Schwinn Super Le Tour, Surly Cross Check, 2021 Giant Talon 2
Quoted: 202 Post(s)
Liked 71 Times
I’m curious what vintage drop bar road bike make/models out there can commonly be found very affordable, are lighter, steel, and still using 27” wheels? Any affordable gem brands/models out there from a performance perspective?
check out the Frugal Average Bicyclist
Frugal Average Bicyclist – The goal here is to help you keep cycling on a budget.
2k miles from the midwest
Quoted: 525 Post(s)
Liked 931 Times
Schwinn LeTour's are common, affordable, decent steel, and use 27"s
Likes For Dylansbob:
Quoted: 786 Post(s)
Liked 520 Times
Mid-range Motobecanes are fab. Something like a Grand Touring, or Grand Jubile, Grand Record. Great riding bikes, with 27" wheels standard, and they sold enough of them that you can pick one up for a couple hundred if you are lucky, and handy in servicing an old bike. And if you want to upgrade to 700c wheels at any point, just add longer reach brakes.
Likes For jeirvine:
Quoted: 3464 Post(s)
Liked 2,829 Times
27” wheels were almost entirely a steel frame pairing, save maybe a Cannondale touring bike early on.
they will sell most often at a discount due to the limited current tire choices.
maybe a USA market Motobecane, but then you have French threads and dimensions.
there is no 27” bike shop. Keenly look.
Bikes: A bunch of old bikes.
Quoted: 278 Post(s)
Liked 871 Times
The Schwinn Le Tour's as mentioned above could be a good choice. The trick is which Le Tour. The Super Le Tour had the 4130 steel "lighter" frame by the late 70's. The standard Le Tour did not get the 4130 frame until 83.
Watch carefully which 27 inch wheels, the steel rims are quite heavy and resist braking when wet.
Likes For daverup:
Ride, Wrench, Swap, Race
Quoted: 1565 Post(s)
Liked 1,295 Times
Some of the "clear-anodized" alloy rims were deadly when wet, at least before that shiny, hard anodizing layer wore off. I've deliberately ridden through mud on a few bikes so as to "machine" the anodizing off and/or to smooth out an uneven rim joint. These rims from before the machined-sidewalls era of course.
Quoted: 4722 Post(s)
Liked 3,036 Times
There are lots of mid-range Japanese manufactured bicycles from the early 1980s that fit the bill, such as the Bianchi Sport SX, Centurion Elite, Centurion LeMans RS, Fuji Del Ray, Fuji Royale II, Maruishi RX-7, Miyata 710, Nishiki International, Raleigh Competition, Shogun 600, Takara Tribute, etc. These bicycles typically used a double butted CrMo or CMn main triangle with 27" rims to hit the sub-25 lb mark at a reasonable price. However, be aware that many migrated to 700C during the mid-1980s, so there are specific years to find the desired combination.
Likes For T-Mar:
Phyllo-buster
Quoted: 2298 Post(s)
Liked 2,054 Times
You can reach back into the 70's too. Most Fuji's has 630 wheels in the mid 70's.
Likes For clubman:
SE Wis
Quoted: 2746 Post(s)
Liked 3,390 Times
Define "affordable"
https://milwaukee.craigslist.org/bik...327028341.html
https://milwaukee.craigslist.org/bik...328951598.html
french and all that entails.
https://milwaukee.craigslist.org/bik...328869578.html
https://milwaukee.craigslist.org/bik...322507416.html
https://milwaukee.craigslist.org/bik...328086704.html
Not steel but...
https://milwaukee.craigslist.org/bik...327030643.html
Too big for you but...
https://milwaukee.craigslist.org/bik...329341705.html
Not steel but...
Likes For tendency:
Quoted: 202 Post(s)
Liked 71 Times
like $150 or less that won’t get sold immediately at that price.
Quoted: 786 Post(s)
Liked 520 Times
Since you're in Wisconsin, you probably have a lot of old steel Treks around. You should be able to find maybe a Trek 400 for under $200 if you're patient.
https://milwaukee.craigslist.org/bik...305312917.html
https://milwaukee.craigslist.org/bik...326611317.html
https://milwaukee.craigslist.org/bik...305143693.html
Quoted: 637 Post(s)
Liked 1,281 Times
Quoted: 525 Post(s)
Liked 931 Times
I wouldn't worry about what the brand name is on the bike, I'd just learn how to spot a decent frame. i.e. dropouts, craftsmenship, seatpost diameter, etc.
Extraordinary Magnitude
Quoted: 2608 Post(s)
Liked 1,699 Times
"resist braking" tee hee...
Commence to jigglin’ huh?!?!
Friendship is Magic
Bikes: old ones
Quoted: 26413 Post(s)
Liked 10,379 Times
They have excellent geometry, and the combination of a butted main triangle, with whatever they used to build the rest of the frame, makes for an excellent bicycle.
You can improve the performance considerably by rebuilding the wheels with modern, 27", Sun rims. But that's an extra expense, and will drive the total cost of your project upward.
Edumacator
Quoted: 2439 Post(s)
Liked 3,122 Times
Quoted: 2363 Post(s)
Liked 1,749 Times
"East side guy" on Milwaukee CL has several, as expected, including an early Trek or two. First link in post 9 has 700Cs, but look for ads with that background and "(East Side)" for the location.
https://milwaukee.craigslist.org/bik...316736562.html
https://milwaukee.craigslist.org/bik...326509382.html
Matched pair of SS Bridgestones, not your garden variety "steel" bike:
https://milwaukee.craigslist.org/bik...327683838.html
https://milwaukee.craigslist.org/bik...327683659.html
Liked 2,829 Times
And those are rare, I passed on one, OS tubed Paramount, just could not get past the paint. was that white with the purple and other paint "worms".
Was in the same city as work.
I don’t understand seeking a bike with 27” wheels, when 700c has some distinct advantages, ie. more tire clearance, greater tire selection. That’s not to say I wouldn’t buy or ride a bike with 27” wheels, but I am curious about why that would be a preference.
Liked 2,829 Times
My hunch is an expectation that the 27" wheels will make the price more agreeable.
Bikes: Davidson ’81
Quoted: 120 Post(s)
Liked 229 Times
Only 2 weeks ago I bought a ‘78 Motobecane Grand Record for $80.
Double butted Vitus 172, 1st gen Cyclone GT derailleurs, power ratchet shifters, 27” aluminum Rigida rims on Maillard 700 hubs.
I have no use for 27” wheels, though. Tire selection and availability is pathetic and the tires on there now are decrepit. Have a set of 700c MA2s laced to Phil hubs to use instead for now. Eventually I may try to build a 650b wheelset with the Maillard hubs.
Likes For C9H13N:
That said, the aforementioned '86 Miyata 710 (purchased for $130) is my only 700c bike. All my others are 27s. I have no problem with 'only' having Pasela PT/TGs...
Yes, the selection of 27" tires isn't what it used to be. AND one has to be careful with unhooked 27" rims that should ONLY be used with wire beaded tires. Bontrager/Trek, Vittoria and Pasela are all available in wire bead. I won't even consider the Chin-sen and other 'cheap' (< $15) tires because those are poorer quality, heavy, and ride like truck tires.
Quoted: 202 Post(s)
Liked 71 Times
But here is a question. Will early 700 bikes fit wider tires? Or are most stuck with 23mm? I prefer the smooth ride of wider tires.
Aren’t 27” bikes a bit more vintage also?
Quoted: 202 Post(s)
Liked 71 Times
Are downtube shifters usually a good hint it’s a better bike?
