Classic/Vintage Tourers?
Old 01-12-22, 11:38 AM
  #76
robow
robow's Avatar
Quoted: 511 Post(s)
Liked 198 Times in 134 Posts
I always carry a couple extra presta valve stems with me while on tour. Occasionally those things can get bent if not careful while pumping up your tires, especially when in a hurry and using a small frame pump. Again, just one of those little things that take up no space and yet without, can make for a miserable day.
robow is offline
Old 01-12-22, 12:19 PM
  #77
Tourist in MSN
Quoted: 2722 Post(s)
Liked 892 Times in 728 Posts
Originally Posted by Trakhak View Post
Edit: yes, the exception where long valve adapters might not work properly is in using them with Schrader pressure gauges.
Yup, that has been a problem for me. And after I filed down one adapter I decided to just file the rest down too. I have a digital Toppeak gauge that is supposed to work with both Shrader and Presta, but using it in Presta mode it loses a lot of air from the tire, so I decided to only use it in Shrader mode.
Good point on the Presta not having a spring like a Shrader, the air pressure should be enough to open the valve when pumping it up.
Tourist in MSN is offline
