Does 1mm really matter?
Old 01-24-23, 05:21 PM
Albion
Albion's Avatar
Bikes: 1980 Fuji Gran Tourer SE, 1974 Araya, 1986 Team Fuji
Quoted: 41 Post(s)
Liked 35 Times in 19 Posts
Hi fellow C&V viewers, I am refurbishing my lovely old '74 Araya and have a couple of questions for which any input would be gratefully received:
  • The front derailleur seems to be impossible to adjust correctly, including throwing the chain, so I am looking at replacing both front and rear with the most appropriate NOS I can find (non-indexed, rear "hook"). Before writing, I checked the chainrings for any bends, horizontal alignment of the rear derailleur using a hexagonal rod in the pivot, usual alignment checks, also had a friend with more experience than I check and ride but changing the front chainring still sees the chain come off. Any thoughts on what I should look for with a semi-decent chance of success in finding that represents the art for a 1970s - 1980s machine?
  • I'll also be replacing the 48 year old brake and shifter cables with Jagwire. But I can't locate 4mm cable end ferrules for the shifter runs. I have seen "5mm to 4mm" but this seems to be a bit of a cop out. Any thoughts where brass 4mm shift cable ferrules can be bought? I am aware that I can buy black nylon ones from Jagwire that are twice the length and maybe even anodized aluminum parts in garish colors but they just offend the eye and I would prefer to retain a semblance of originality.
As always, many thanks in advance for your advice - it's always most welcome.
Has this front derailleur had it?
Or the rear one?
Really?
A bike is the closest I can get to a magic carpet . . .
Albion is offline
Old 01-24-23, 05:41 PM
icemilkcoffee
icemilkcoffee's Avatar
Quoted: 1557 Post(s)
Liked 1,733 Times in 973 Posts
4mm cable end caps:
https://www.ebay.com/itm/122884424525
(you have to select either 4mm or 5mm with the drop down box)
icemilkcoffee is offline
Likes For icemilkcoffee:
Old 01-24-23, 05:52 PM
Albion
Albion's Avatar
Quoted: 41 Post(s)
Thank you!
Hi Icemilkcoffee, thank you so much! I immediately ordered a couple of packets. And this was after an extended search, using all the search term variations I could think of - but still didn't find them. For others like me, here's what he directed me to:
Albion is offline
Likes For Albion:
Old 01-24-23, 05:55 PM
ehcoplex
Bikes: '38 Schwinn New World, ’69 Peugeot PX-10, '72 Peugeot PX-10, ‘7? Valgan, '78 Raleigh Comp GS, ’79 Holdsworth Pro, ’80 Peugeot TH-8 tandem, '87 Trek 400T, ‘7? Raleigh Sports, ‘7? Raleigh Superbe, ‘6? Hercules
Quoted: 761 Post(s)
Liked 1,563 Times in 757 Posts
I don't think you should give up on those Suntour mechs yet- they're pretty bulletproof and shouldn't be giving you so much trouble. That FD is 'high normal', which means the spring want's to pull it to the large ring- you know that, right? (sorry, no intention of being condescending- just checking) Are you losing the chain to the inside, when shifting from big to small, or to the outside when going from small to big ring? Give us some more info, maybe we can collectively get you sorted out!
ehcoplex is offline
Likes For ehcoplex:
Old 01-24-23, 06:07 PM
panzerwagon
Garage tetris expert
panzerwagon's Avatar
Bikes: A few. Ok, a lot
Quoted: 387 Post(s)
Liked 692 Times in 329 Posts
FD passes at least the eye test. Random ideas:
- From the marks on the seat-tube, it appears to have been installed differently in the past. Are you sure installation is correct? (a) clearance directly above big ring, (b) cage angle.
- Lubricate all derailleur hinges (check movement by hand once cables are disconnected).
- Incorrect or worn chain?
Good luck, love those components.
panzerwagon is offline
Likes For panzerwagon:
Old 01-24-23, 06:13 PM
alcjphil
alcjphil's Avatar
Quoted: 1818 Post(s)
Liked 1,693 Times in 974 Posts
From the angle of this photo it is difficult to tell if the derailleur is too high above the large chainring. I think it might be. A photo taken at the same level as the derailleur might show this better
alcjphil is offline
Likes For alcjphil:
Old 01-24-23, 06:17 PM
52telecaster
ambulatory senior
52telecaster's Avatar
Quoted: 1955 Post(s)
Liked 3,661 Times in 1,679 Posts
I would also say the suntour mech is good stuff.
52telecaster is offline
Likes For 52telecaster:
Old 01-24-23, 06:28 PM
Albion
Albion's Avatar
Quoted: 41 Post(s)
Hi Echoplex, I really appreciate your input. The chain tends to come off more usually when moving to the larger front chainring with the chain dropping onto the crank arm (urgh). There is one difference I have noted, compared with my '80 Fuji, and it's the rear derailleur tension - when rotating the cage plate near the idler pulley the twisting force required is about half (I have just ordered a spring scale to check more exactly). Might there simply not be enough tension in the chain to keep it seated on the front chainring? If so, it's within my ability to take the rear changer apart and increase the tension by half a turn (say).
Albion is offline
Likes For Albion:
Old 01-24-23, 07:55 PM
CroMo Mike
All Campy All The Time
CroMo Mike's Avatar
Bikes: Listed in my signature.
Quoted: 177 Post(s)
Liked 114 Times in 63 Posts
I'm not familiar with that front derailleur but it looks like the linkage is out of sorts.
My C&V Bikes:
1972 Bottecchia Professional, 1972 Legnano Olympiade Record,
1982 Colnago Super, 1987 Bottecchia Team C-Record,
1988 Pinarello Montello, 1990 Masi Nuova Strada Super Record,
1995 Bianchi Campione d'Italia, 1995 DeBernardi Thron
CroMo Mike is offline
Old 01-24-23, 08:03 PM
ehcoplex
Quoted: 761 Post(s)
Hmm, could be. But could be a number of other things, too. Old/worn chain can cause issues, too. This past summer I had a heck of a time getting the Simplex FD on my Pug to shift well and to not drop the chain (granted, I'm using an FD designed for a double on a triple..)- in the end bending the front edge of the FD's outer cage inward just a little bit, and doing a lot of fine tuning of the limit screw and I finally got it shifting great. Do you have a bike stand? I think that's probably essential- trying to get derailleurs properly adjusted without one is seriously frustrating!
ehcoplex is offline
Likes For ehcoplex:
Old 01-25-23, 07:54 AM
ehcoplex
Quoted: 761 Post(s)
I think the V-Compe FD is actually alloy body with a steel cage. Maybe not high-end, but decently regarded- though the high-normal takes getting used to, and some folks don't like it. Albion , you might want to start a new thread specifically to get the FD issue sorted out- there's tremendous knowledge here, but this thread title may not get the eyeballs you need to solve this. Also, a straight on photo of the FD & crankset (and also of the whole drivetrain) might be helpful. I think it takes quite a lot of use/abuse to render old Suntour mechs unusable- I'd be really surprised if, with some effort, you can't get this one working properly.
ehcoplex is offline
Likes For ehcoplex:
Old 01-25-23, 08:15 AM
Mr. 66
Mr. 66's Avatar
Quoted: 1140 Post(s)
Liked 1,736 Times in 957 Posts
I think that fd has a cable stop. The housing is one more spot that may need lubricant.
Some of those old systems would use a lot of overhift and trim back into place. The last times I've had those cranks I had chain suck in between the chainrings. Nice solid rings but the spacing is more than most all, they take a lot of fd movement for shifting ups or downs.
Mr. 66 is offline
Likes For Mr. 66:
Old 01-25-23, 09:04 AM
Maohaus
Bikes: Fuji, Colnago, Trek, Raleigh, Motobecane, Araya, Famolare, Elgin
Quoted: 58 Post(s)
Liked 69 Times in 38 Posts
I am very interested in the Araya bicycles. Would you be willing to share some more photos and information about your Araya? Would love to know the model, frame material, which bike shop from which it came etc. Thanks, Mark
Maohaus is offline
Likes For Maohaus:
Old 01-25-23, 09:13 AM
1989Pre
Standard Member
Bikes: 1948 P. Barnard & Son, 1962 Rudge Sports, 1963 Freddie Grubb Routier, 1980 Manufrance Hirondelle, 1983 F. Moser Sprint, 1989 Raleigh Technium Pre, 2001 Raleigh M80
Quoted: 1296 Post(s)
Liked 940 Times in 490 Posts
Increase chain tension with "b" limiter screw on rear derailleur.
Unless you climb the rungs strategically, you’re not going to build the muscle you need to stay at the top.
1989Pre is offline
Old 01-25-23, 09:14 AM
smd4
Quoted: 3502 Post(s)
Liked 2,917 Times in 1,771 Posts
How so?
smd4 is online now
Old 01-25-23, 09:17 AM
Maohaus
Quoted: 58 Post(s)
I should mention that it is not at all unusual or incorrect to slightly bend the inside plate of the front derailleur to assist it lifting the chain to the large chainring. If you bend it ever so slightly inward, you may be able to back off the outboard adjustment screw. We did that routinely when I was a mechanic in the shops in the early 70's and 80's.. By the way, I always use a Crescent wrench to make the gentle bend.
Maohaus is offline
Likes For Maohaus:
Old 01-25-23, 10:16 AM
ehcoplex
Quoted: 761 Post(s)
Yup, those high-normal FDs require a length of cable housing- it's actually the housing itself that moves the derailleur pivot. I just took a look at the Suntour SL FD I've got on my tandem and I think it's basically the same as the Compe-V, just with a different cage (alloy, different styling). Dialed in, it works really well for me.
ehcoplex is offline
Old 01-25-23, 04:01 PM
dddd
Ride, Wrench, Swap, Race
dddd's Avatar
Quoted: 1565 Post(s)
Liked 1,295 Times in 865 Posts
Great suggestions, the old front derailers thankfully have a good length of forward protrusion where the tips of the cage can be bent inward to better control a narrow chain (these were designed for use with 8mm wide chain!).
The Suntour V-GT rear derailer features adjustable cage pivot tension! One has to unscrew the stopper pin on the cage with a screwdriver, then unwind the cage enough to reposition the end of the spring one position tighter (under the big/heavy chrome cap with a 6mm hex socket in it). Then you re-secure the cap, wind the cage back up, and reinstall the stop pin (add grease while you're in there).
If you tighten the B-tension screw to effect greater chain tension, the shifting will become sadly unresponsive, and may increase the risk of throwing the chain into the spokes. Remember that these derailers were designed for laterally-stiff bushing-type chains, so the shifting response is already challenged just by using modern chain (which are much more flexible than even the bushingless Sedisport chain).
I really prefer using index-shift cable housing for ALL rear derailer use. It really improves responsiveness, especially with friction shifters!
A supply-chain problem arises though when a 4x5mm ferrule (not 4x6mm) is needed to fit modern 4mm shift housing and still fit into the narrower ~5mm housing stops on old frames (and even on old stem shifters and rear derailers).
Shift cable housing really always needs to be well-captured by a ferrule, or by a deep, squared-bottom, 4mm port in the component.
But brake cable housing can be run without any ferrule if it simply fits ok in whatever stop that it rests against.
I occasionally find 4x5mm metal ferrules, my Schwinns needed them, don't know where to find more though.
A stepped ferrule is often the next-best answer, each situation is different, these differences are sadly not the best feature of old bikes!
dddd is offline
Likes For dddd:
Old 01-25-23, 08:10 PM
CroMo Mike
CroMo Mike's Avatar
Quoted: 177 Post(s)
Originally Posted by smd4
How so?
It looks like the upper and lower pivot arms are out of their "bearings" in the clamping body (moved rearward) and the limit screws are therefore not contacting their spots on the pivoting part of the upper pivot arm?
Image from Velobase:
My C&V Bikes:
Old 01-25-23, 08:25 PM
smd4
OK, I see what you’re saying now. That pic helped.
Yeah, it might be tweaked.
smd4 is online now
Old 01-25-23, 08:30 PM
SpedFast
Just Pedaling
SpedFast's Avatar
Bikes: YEP!
Quoted: 331 Post(s)
Liked 519 Times in 346 Posts
Nothing wrong with your front derailleur that can be seen by the pics, just find someone to set the limiter screws correctly. They're the 2 little screws on top. I have the same setup on one of my older bikes and let me tell you, those old Suntours are bullet proof. Good luck
SpedFast is offline
Old 01-25-23, 08:47 PM
CroMo Mike
CroMo Mike's Avatar
Quoted: 177 Post(s)
Here's his derailleur. Note that the limit screws hit the shaft, not the arm.
My C&V Bikes:
Likes For CroMo Mike:
Old 01-25-23, 09:01 PM
smd4
That could be the molded-in aluminum stop we’re seeing, in an odd light.
smd4 is online now
Likes For smd4:
Old 01-25-23, 09:31 PM
ehcoplex
Quoted: 761 Post(s)
Yeah, I think that’s the molded in stop. Here’s a pic of the SL on one of my bikes (I think the only real dif is the cage is alloy on the SL)-
I suspect the mech wouldn’t function at all if the arms were slid back on the shaft..
ehcoplex is offline
Likes For ehcoplex:
Old 01-26-23, 02:55 PM
Albion
Albion's Avatar
Quoted: 41 Post(s)
Araya
Hi Maohaus, here's what I know about my old Araya:Araya made a short foray into complete bikes before returning to rims alone. Mine was literally pulled out of caleche (hard, Arizona clay) from a hoarder's back yard. Sadly the model name faced the sun and was on a soft, black stencil or decal and it was mostly gone when I bought the bike.
The BB shows C432754, nothing on the dropouts. Hummer advised, as part of a discussion with the learned T-Mar: “The serial number on your Araya is an Araya serial number, not Bridgestone. In 1977 Araya started to put an ‘ARY’ prefix on their serial numbers. Araya frames built prior to that had serial numbers without the prefix. The letter "C" at the start of the serial number is for the month of frame manufacture, C = March. The first digit "4" is for the year of frame manufacture, 4 = 1974.”
T-Mar also provided date information on the rear derailleur: ". . . the date code (on the RD) is QB, which represents, February 1974, which should make the frame a 1974 model."
I hope this is of interest!
Nothing special but fits like a glove . . .
Basic frame work . . .
Albion is offline
Likes For Albion:
