Track Cycling: Velodrome Racing and Training Area Looking to enter into the realm of track racing? Want to share your experiences and tactics for riding on a velodrome? The Track Cycling forums is for you! Come in and discuss training/racing, equipment, and current track cycling events.
Skinny axle speed sensor?
Old 10-09-21, 03:36 AM
BennyBikes
Quoted: 10 Post(s)
I was hoping to put my Garmin wheel speed sensor on my track bike, but the axles are way too skinny.
does anybody have a recommendation for sensors that may fit?
thanks
BennyBikes is offline
Old 10-09-21, 05:15 AM
Poppit
Poppit's Avatar
Quoted: 111 Post(s)
Liked 5 Times in 4 Posts
Just twist the garmin strap a couple of times, it'll fit fine
Poppit is offline
Old 10-09-21, 06:54 AM
BennyBikes
Quoted: 10 Post(s)
good idea, but I just tried with 4 twists and it’s still pretty loose!
thinking the wahoo looks like it may go a little tighter as it specifically says for front wheels
Old 10-10-21, 05:35 AM
RobertPaulson
RobertPaulson's Avatar
Bikes: Dolan DF4, Tarmac SL7
Quoted: 12 Post(s)
Liked 10 Times in 9 Posts
the wahoo will fit that. just be aware the new wahoo speed sensors auto calibrate off a GPS signal and that can be problematic at indoor velodromes, its fixable but can be a faff to find the right menu field in some headunits
RobertPaulson is offline
Old 10-10-21, 05:43 AM
BennyBikes
Quoted: 10 Post(s)
thanks, I actually picked the wahoo up today!
needed a couple twists but is tighter than the Garmin
I’ve just set it to 700x23 manually in the Garmin head unit
BennyBikes
Quoted: 10 Post(s)
(2096mm)
Old 10-11-21, 07:00 AM
topflightpro
topflightpro's Avatar
Quoted: 1851 Post(s)
Liked 675 Times in 427 Posts
What about a piece of foam pipe insulation to widen the hub diameter?
topflightpro is offline
