Garmin Cadence Sensor Rubber Rubbing Bootie
Grupetto Bob
Bikes: Bikey McBike Face
Quoted: 2512 Post(s)
Liked 5,430 Times
There is just no way to write the title without it sounding a bit off.
Since the weather in the Seattle hinterlands is getting cool - 40s and raining, it was time to don the neoprene booties. The rubber retaining strap, no matter where I move it on the crank rubs against the bootie (keep it clean) creating a wear spot. Was thinking instead of using the rubber strap, perhaps use something lower profile like the black twist-ties which come with electronic accessories. Not an elegant solution so am putting out to the brain trust on suggestions. Gracias
Road 🚴🏾♂️ & Mountain 🚵🏾♂️
Expired Member
Quoted: 3638 Post(s)
Liked 5,316 Times
The Wahoo can be mounted directly to the crank arm with double sided tape. Maybe that would work for the Garmin? Tape comes in a range of hold strengths.
Likes For shelbyfv:
Super Modest
Quoted: 10894 Post(s)
Liked 4,560 Times
I've used Gorilla double-sided tape before and it held well.
Keep the chain tight!
Likes For Trsnrtr:
I use a bit of the 3m tape. I didn't trust it to stay and based off a video I saw I put about an inch of mountain bike tube over the top. Holds it securely.
Likes For ratell:
Thread Killer
Bikes: 15 Kinesis Racelight 4S, 76 Motebecane Gran Jubilée, 17 Dedacciai Gladiatore2, 12 Breezer Venturi, 09 Dahon Mariner, 12 Mercier Nano, 95 DeKerf Team SL, 19 Tern Rally, 21 Breezer Doppler Cafe+, 19 T-Lab X3, 91 Serotta CII
Quoted: 3078 Post(s)
Liked 1,631 Times
You might try some 3M Dual Lock for the ease of removal and re-installation. Probably the low-pro SJ4580 is the way to go for maximum chainstay clearance.
Likes For chaadster:
Grupetto Bob
Liked 5,430 Times
My only concern about double sided tape is when it comes time to replace the battery which means scraping the tape off the door. Not a problem?
Super Modest
Liked 4,560 Times
I have just used electrical tape. The tape doesn't look any worse than the rubber strap.
Advocatus Diaboli
Quoted: 4717 Post(s)
Liked 1,526 Times
Sounds like a good excuse to get a Stages or some other type of power meter with built-in cadence.
