Post Your Titaniums
#3051
Bikes: Pinarello; Canyon; Lauf
Quoted: 75 Post(s)
Liked 48 Times
Yes, I bought the LS Ultimate Gravel because it's made in the US and I didn't want to support Taiwan which is where all of my carbon bike frames are made (Pinarello, Canyon, and Lauf). Plus the fact that all these companies are from other countries: Italy, Germany, and Iceland.
Likes For cj3209:
#3052
Quoted: 567 Post(s)
Liked 563 Times
I also went through original and replacement decals from Litespeed on my 2004 Firenze. I just talked with SSSInk who makes the decals and was told Litespeed got away from the large panel decals due to the failures but if your clear coat over the decal and when applying use only water to clean the tubing they will last as long as any other decal. I hope they are correct as the third will be my last LS decals.
#3053
Ride more, eat less
Quoted: 713 Post(s)
Liked 733 Times
I never bothered trying to get original decals.
I figured that it is titanium, ultimate utilitarian frame material, not sure much need to keep it looking sharp,
just ride it and put it away set & dirty. 17+ years old and still the same magic carpet ride, money well spent; likely keep riding until I can't pedal anymore.
That's the beauty of titanium, I'm thankful for its minimal maintenance required to operate; leaves me more time to ride instead.
Likes For QuikRick:
#3055
Bikes: Grazzini,Litespeed,and Pinarello
Quoted: 33 Post(s)
Liked 92 Times
#3056
Quoted: 567 Post(s)
Liked 563 Times
Yes, SSSink replaced the second set as it was less than a year old and totally cracked; they supplied the originals and still do all LS decals. I have installed a lot of decals so did not read the directions and am sure I used alcohol as a last step to clean the tubes which SSSink said is a no no. The new ones look great but it has only been a couple of months and I have not clear coated them as suggested. The tech help line at LS is good they got me in touch with the right guy at SSSink.
#3057
Quoted: 33 Post(s)
Liked 92 Times
#3058
Bikes: 2014 Cannondale Supersix EVO 3, 2015 Trek 520, 2017 Bike Friday Pocket Rocket, 2022 Moots Vamoots Disc RSL
Quoted: 285 Post(s)
Liked 267 Times
Ordered a Moots Disc RSL Vamoots with anodized gold labels in late October. No decals or paint on the bike frame, but the Enve wheels will have matching gold decals. I can't wait for my April- May delivery.
#3059
Quoted: 75 Post(s)
Liked 48 Times
I ordered a Litespeed Ultimate Gravel Di2 Ultegra with upgraded HED carbon wheels and a T47 threaded BB last month. Should get here in a few weeks.
#3060
My Lynskey came in 12/02/21, order placed 11/05/21. The product is actually very nice glad I went with Di2, need to put in some miles but from what I have noticed the various shifting modes can be very intuitive depending on terrain. My initial impression is the bike is very industrial, business like.
What I really like is the Garmin Edge 830, Di2, integration, no more looking back at the cassette or chain ring (D-fly module). I know that's not really something reflective of the actual bike frame but its part of the final build.
Cadence sensor, has little clearance between the chainstay and and left crank arm but, if moved all the way up toward the BB it works.
A special thanks to Rick,Texbiker.net for his YT channel and content, specifically on this bike in a real used scenario and 1lieutenant for posting pictures and his story, I even asked to have lynskey mod my frame the same as his by routing the hydraulic lines through the frame but they wanted 660 bucks, too costly for just aesthetics.
So,far only a small little shakedown ride 20miler, The fixing bolt on the Lynskey seat post to saddle loosened and the stem top cap also loosened, which is odd since they were both secured and torqued.
I'm definitely smiling, its a nice bike for sure.
Likes For texbazII:
#3061
Quoted: 75 Post(s)
Liked 48 Times
I forgot about the Di2 little battery box on the handlebar. My road bike has Di2 and the battery must be in the seatpost because I don't see it. I think my upcoming Litespeed also has the Di2 battery in the seatpost which is what I prefer.
#3062
Bike looks fantastic! Maybe a bit of loctite would help with the loosening bolts.
When I spoke to Lynskey and placed the order I asked about the junction box A and the D-fly module. Could I pay extra for the in handlebar junction box and the D-fly., they said they don't do either because the handlebars don't come with holes in them. Maybe later on I can upgrade the bars and incorporate the junction box.
#3063
The Grape Ape
The Grape Ape, a Lynskey Pro 29 with as much titanium as I could get on without my wife losing her mind about an eeWings crank.
Does it do anything a Karate Monkey wouldn't do for a lot less? Absolutely not. But it's shiny af and it makes me want to ride every damn day. Plus, I only turn 50 once, and it's a lot cheaper than a Ferrari or a divorce!
Bearclaw boost fork
Carver ti Prybars
"Do Not Die In Bed" in orcish
Lynskey stem
XT, Hope everything else.
Spank saddle
Bearclaw boost fork
Carver ti Prybars
Lynskey stem
Spank saddle
Likes For cormacf:
#3064
Quoted: 75 Post(s)
Liked 48 Times
Thanks cj3209 appreciate it. The component under the stem is a (3 port) Junction box A SM-EW90. Gets its power from the battery in the seat post. Your road bike depending how old it is might have a EW-RS910 in the handle bar. One suggestion, If you want Bluetooth and ANT+ com with your head unit like Garmin,wahoo,then you might want to start looking for a Shimano wireless module P/N EW-WU111 they are getting very scarce at the moment.
I have a feeling my Litespeed bike will have the Junction box A SM-EW90 on my handlebar, just like yours. Oh, well.
#3065
Cormacf, Nice build, and definitely as much Ti as you get. Diggin that DEAN seatpost man they are expensive.
#3066
Sunshine
Quoted: 10947 Post(s)
Liked 7,474 Times
'03 Litespeed Classic
Bought this a few days ago from a forum member and threw on pedals and a saddle to figure out if it will be a keeper. I hope it is, but I think it will ultimately be a bit too short. It's shorter than my main road bike that is a proper fit and slightly lower than my backup road bike too.
For now it'll live on the trainer for zwift so I can figure out how it feels.
If I keep it, new tires and saddle will get slapped on for sure.
Likes For mstateglfr:
#3067
Bikes: No. 22 Bicycle Great Divide, Lynskey R260, Salsa Colossal Ti, Litespeed T5, Lynskey Peloton, Bianchi Vigorelli, CAAD 10, Giant FastRoad CoMax 1, C-Dale Quick 1
Quoted: 50 Post(s)
Liked 36 Times
Likes For malcala622:
#3069
Thread Killer
Quoted: 3129 Post(s)
Liked 1,698 Times
#3070
Here’s my late 90’s GT Edge. Ultegra 8 speed. I just put the tri spokes on for the pic. The tires are dry rotted so these haven’t been ridden in years.
#3071
Very nice indeed. This bike was quite the fusion of technology at one time and still looks as remarkable today.
Tete de Course
Tete de Course
#3072
Bikes: 02 Cervelo P2K, 07 Cervelo P2SL, 07 Cervelo Soloist, 09 Cervelo RS, 96 Quintana Roo Kilo, 80 Chicago Schwinn Letour, 12 Motobecane Nemesis, 97 Kona AA, 97 Cannondale f700
Quoted: 11 Post(s)
Liked 35 Times
Colnago Monotitan
Lemond Carbon/Titanium "Spine Bike"
#3073
Klaatu..Verata..Necktie?
Quoted: 10397 Post(s)
Liked 11,857 Times
I just picked up a 1995 Litespeed Ultimate from Ebay. It will require a complete rebuild, but the frame and fork are in great condition! I just have to figure out whether to build it the way I dreamed of back in the 90s, or a more modern build, since the frame is kind of timeless. While I decide, I've got bits enough to make a useful, fun bike out of it while I accumulate the bits...
I've stripped the decals, which were from a later era, and I've got a new set from Litespeed to go on.
Likes For genejockey:
#3074
Bikes: Moots Vamoots RCS, Serotta Ti, Felt F55, Surly Ogre
Quoted: 37 Post(s)
Liked 38 Times
#3075
Liked 11,857 Times
Update on the 1995 Ultimate above - I built it out as the bike I lusted after back in the 90s - 7410 Dura Ace, the last of the 8 speed DA, the first generation of STIs, and the gorgeous 7410 crankset, which to my eye is the prettiest crankset ever made! I discovered that, because Litespeed had curved the seat tube to allow shorter chainstays, the actual angle of the seat tube is a lot slacker than the 73 degrees you get by measuring from center of BB to center of seat cluster, which meant that I had to get a zero setback seatpost and STILL slide the saddle all the way forward in the clamp. I kept the Chorus headset, because it's there, and it's pretty, and it works. I added a Nitto Dynamic stem and Soma Highway One bar. Also, what looks like, but really isn't a matched wheelset. But they look good together and roll great! So far I've got just over 200 miles on it, and I'm loving it! Long term, I might swap out the 27 year old Dura Ace for something more modern, with more speeds and a wider range of gears than the 12-25 it's currently running, but I'm happy with this build at the moment!
How It Started:
How It's Going:
How It Started:
How It's Going:
