First Time Chain Waxer Calling on Chain Waxing Gurus
Quoted: 2333 Post(s)
Liked 2,097 Times
I put three chains into my tiny crockpot every time I wax. Fits fine.
Jedi Master
Quoted: 20810 Post(s)
Liked 9,456 Times
Loads simpler. ... The initial cleaning was the most effort, took a few trips through the de greaser and a little scrubbing, but once I got through that, and you apply squirt, when I need to reapply, I can just wipe it down with a rag and reapply. No muss no fuss. After you do the initial cleaning a trip through some denatured alcohol is a good thing as well. Dries off very quickly.
Quoted: 1975 Post(s)
Liked 232 Times
Acetone isn't sufficient to strip all the grease, as others have said you need to use a different solvent first. Since you can't get oderless mineral spirits in CA, as others have mentioned use simple green or other degreaser but do not soak overnight, do 3 agitations, rinse fully with plain water, then do the acetone baths or alcohol.
Blast from the Past
Sounds like you have it down. Throw it in the wax, hang it up, loosen up the links and install. I would not expect any re-adjustments needed when you re-wax, has not been my experience over quite a few years and bikes. With one exception.
Got caught in some rain last Sunday. The entire bike was due for a cleaning so I pulled the chain (Dura Ace) off and re-waxed it while working on the rest. Got caught up in a nice Bourbon while waiting on the crock pot but eventually got the chain re-installed. Went out for a ride a few days later and my shifting was clunky & noisy. After some fiddling with the adjuster I found a compromise setting, a little noisy but worked. The problem was resolved post ride, I had installed the chain backwards, lol.
Likes For Voodoo76:
Method to My Madness
Bikes: Trek FX 2, Cannondale Synapse, Cannondale CAAD4, Santa Cruz Stigmata GRX
Quoted: 1947 Post(s)
Liked 1,468 Times
To allow the chain, which is at ambient temperature, to reach the temperature of the melted wax (210 *F). Now that the wax has taken the shape of the crock pot, next time I will just heat both wax and chain at the same time.
After studying chemistry some more, I learned that acetone is too polar to work as a good solvent for bike lube, so that was quite a bit of residual oil and/or grease. I have managed to order odorless mineral spirts from an arts and crafts supply store.
Liked 1,468 Times
Can't buy a gallon of Coleman Fuel in California? Now, I understand the campfire cooking on the Pacific Crest trail.
The best way to get rid of the factory lube is to first ultrasonic it with Simple green, water. Then, one or two soaks in wide mouth plastic juice bottle filled with white gas aka naptha or Coleman fuel. I shake and then let it sit. I let it dry. I start up the crockpot. Put the chain in there for an hour or two. Getting the wax into the chain links and pins is not that easy. When I remove it, I lay it flat and "blow dry" off the excessive wax pin by pin using a heat gun on a lower setting. After 200-250 miles, I will apply Smoove or Squirt, to each roller and pin. After around 5-700 miles and if the chain is not dirty, it is removed and put directly into the molten wax. I rarely strip it again.
Thank you everyone for all the comments. I now realize I need to wipe off the outside of the chain as I am pulling it out of the crock pot.
Likes For SoSmellyAir:
Quoted: 9653 Post(s)
Liked 6,365 Times
Liked 6,365 Times
Liked 2,097 Times
Bikes: yes, i have one
Quoted: 1138 Post(s)
Liked 1,182 Times
my life is a bit simple because i have only one bike so only one chain. actually, two chains: one on the bike and the other at the bottom of a frozen solid chunk of wax in my crock pot. while heating up the chain i am cleaning the one on the bike, once clean a quick chain swap, crock pot off until the next wax session, plenty of time during the cool down phase to get all that waxy goodness where it needs to be. also only use pure gulf wax, no additives.
never had shifting problems and i do not wipe down after pulling out of the hot wax. i never measure temp and i certainly get way more than one or two rides out of a waxed chain. probably on the order of 400 miles or so.
waxing is certainly more work than just adding some wet or dry lube but i don't mind it and i like the cleanliness and no more tatts. i find i really don't need to clean the chain between waxing sessions since i don't ride in crappy weather and only on solid tarmac.
Liked 9,456 Times
I've never wiped. If you're pullng it out hot, it's not going to be caked or anything and excess will drip.
Liked 1,468 Times
Liked 1,468 Times
Liked 2,097 Times
That is what I have gleaned from various instructions too, that dipping a chain at ambient temperature into the Crock Pot cools the immediately surrounding wax which deters flow into the chain until the whole system warms again. Mojo31 210 *F is not necessary but that is already the low setting in my Crock Pot.
An hour is probably too long but someone said 10 seconds. I suspect the ideal is in the middle somewhere. I usually have enough to do that and hour isn't a problem.
For me, chain friction is more about chainrings and cassettes....and losing anymore of my puny power.
Advocatus Diaboli
Quoted: 4733 Post(s)
Liked 1,532 Times
I don't know why, but I'm picturing a darkroom film squeegee about right for a fresh hot drippy waxed chain.
Likes For Sy Reene:
Liked 9,456 Times
Quoted: 1186 Post(s)
Liked 289 Times
It doesn't stay cold for long when it goes in the crock pot. After 10 seconds the chain is up to a high enough temperature that the wax remains liquid on the chain when it's removed. I think that's all you need. There's no magic temperature - it just needs to be above the melting point of wax (~155F).
Likes For gregf83:
Liked 289 Times
I grab the link pins with a pair of needle nose pliers and swish them in the liquid was for 10 seconds or so. Both the pliers and link quickly get above the melting point temp of was.
Liked 2,097 Times
Liked 232 Times
Liked 1,468 Times
Wednesday afternoon progress update. Saw quite a lot of black gunk on the chain, cassette, jockey wheels, rear derailleur, right chain stay, and chain rings, and almost decided right then to quit waxing. Thankfully, it turns out that this black gunk is waxy, not greasy, and quite easily brushed off with stiff brushes. Boiled the chain in water and Dawn three times to remove the residual black wax, then dragged it over a Sonicare toothbrush with Dawn, rinsed clean with water, then baked in oven at 220 *F to dry. After cooling, the chain was agitated for 10 minutes in, and then left immersed in, odorless mineral spirits but the solvent did not darken; I sure hope this means that the chain is finally clean enough for my next attempt at waxing.
The problem with immersion waxing is that wax is only needed at the pivot points, not in the spaces between the rollers at either ends of a link. How do I minimize the latter? The first time, I unplugged the Crock Pot and waited 10 minutes before I pulled the chain out. Tomorrow, I will unplug the Crock Pot and then pull out the chain right away to let more wax drip off.
Liked 9,456 Times
MSW says to go for 200°, so that's what I do. When I pull my first chain out (which heated with the cold wax) and pop in the second, cold chain, there's a definite sag in the temp of the wax. It usually takes about 10 minutes for wax to get back up to temp after popping in a cold chain. I figure that that's enough time to melt the wax in the rollers and seep in. If less time works for you, that's cool, but I'm not exactly being put out by coming back 10 minutes later.
Jedi Master
SoSmellyAir Sounds like you're not getting your chain clean enough in the first place. Maybe get a new chain and follow the MSW chain cleaning instructions. You only have to do it once per chain, then just throw it in the pot after that. After I clean the chain, I pour the OMS into a plastic bottle through a coffee filter in a funnel and use it over and over.
