Riding on sandy roads
Old 07-31-21, 03:29 PM
dvai
Quoted: 106 Post(s)
Liked 4 Times in 4 Posts
Commonly, you see roads or trails by a lake or sea. They are covered or partially covered by sand.
I wonder how much damage to the drivetrain this could cause. To some degree, you will get some on the drivetrain and fine sand usually gets everywhere - much worse than dirt.
Any experience?
dvai is offline
Old 07-31-21, 04:50 PM
terrymorse
climber has-been
terrymorse's Avatar
Quoted: 3401 Post(s)
Liked 3,531 Times in 1,776 Posts
The only sand I worry about is the stuff on the curves that makes descending more exciting than it needs to be.
Drivetrain? Feh. Maybe some sand would make it wear slightly more quickly. Nothing to lose sleep over.
Find something else to worry about.
Ride, Rest, Repeat. ROUVY: terrymorse
terrymorse is offline
Likes For terrymorse:
Old 08-01-21, 03:01 PM
Inusuit
Bikes: 1995 Specialized Rockhopper,1989 Specialized Rock Combo, 2013 Specialized Tarmac Elite
Quoted: 213 Post(s)
Liked 588 Times in 278 Posts
I ride where I ride. Components are replaceable.
Inusuit is offline
Likes For Inusuit:
Old 08-01-21, 03:05 PM
Quoted: 18391 Post(s)
Liked 15,465 Times in 7,306 Posts
I ride around the NJ shore several times a year. In fact, I just finished a long weekend tour that had me on sandy roads. I’ve never found it to be a problem.
But stay out of thick sand buildup. Great way to crash.
Likes For indyfabz:
Old 08-01-21, 05:28 PM
ofajen
Cheerfully low end
ofajen's Avatar
Quoted: 644 Post(s)
Liked 1,044 Times in 667 Posts
Welcome to my world. All my rides involve some portion of trail surfaces with large and small crushed stone, stone dust, dirt, sand, rock, and just about everything else. I suppose there is a bit of increased drivetrain wear, but I’m still replacing chains at 3000 miles or so. So it’s fine.
Do watch for hitting a sudden patch of very loose sand or similar material when cruising on firmer surfaces at speed. It’s like someone slammed on your front brake without letting you know in advance.
Otto
ofajen is offline
Likes For ofajen:
Old 08-01-21, 08:10 PM
MinnMan
MinnMan's Avatar
Bikes: 2022 Salsa Beargrease Carbon Deore 11, 2020 Salsa Warbird GRX 600, 2020 Canyon Ultimate CF SLX disc 9.0 Di2, 2020 Catrike Eola, 2016 Masi cxgr, 2011, Felt F3 Ltd, 2010 Trek 2.1, 2009 KHS Flite 220
Quoted: 4344 Post(s)
Liked 2,992 Times in 1,849 Posts
Yeah, I went down on some sand along a trail when I was in Cape Cod a few years ago. The first bad part was that it was near a parking lot, so all kinds of civilians saw me do it. The second bad part was that I was banged up and it was rather unsightly. Nothing serious, but a fair amount of blood. I found a life guard station and they helped me out with their first aid kit.
In all, it was a totally embarrassing experience. Beware of sand.
Drive train? Well, it was a rental.
MinnMan is offline
Old 08-01-21, 09:46 PM
Symox
Bikes: '23 Poseidon Redwood, '07 Specialized Roubaix Comp Triple, '12 Gravity Fixie, '21 Liv Rove 4, '06? Giant EB Spirit
Quoted: 345 Post(s)
Liked 237 Times in 151 Posts
i think the sand might polish the components before it wears them out
Sand is usually softer than aluminum or steel drivetrain parts. Maybe a jockey wheel might see more wear, but they are cheap
Symox is offline
Old 08-01-21, 10:14 PM
MinnMan
MinnMan's Avatar
Wholly untrue. Quartz is far harder than aluminum or virtually any steel.
MinnMan is offline
Likes For MinnMan:
Old 08-01-21, 10:34 PM
Symox
Quoted: 345 Post(s)
Thanks for the correction - i learned something
Symox is offline
Old 08-02-21, 01:14 AM
Badger6
Obsessed with Eddington
Badger6's Avatar
Bikes: '16 Spesh Diverge, '14 Spesh Fatboy, '18 Spesh Epic, '18 Spesh SL6, '21 Spesh SL7, '21 Spesh Diverge...and maybe n+1?
Quoted: 532 Post(s)
Liked 621 Times in 368 Posts
Any experience?
You know some people ride on gravel, intentionally, right? Agree with the others, the wear will be unnoticeable, so long as you keep your drivetrain maintained (clean and properly lube it regularly). I'd be more worried about the sudden handling issues that sand causes under a bike.
Badger6 is offline
Likes For Badger6:
Old 08-02-21, 07:02 AM
rumrunn6
rumrunn6's Avatar
Quoted: 5222 Post(s)
Liked 3,574 Times in 2,338 Posts
recently did 2 extended rides in seaside areas. took a close look at my chain the other day thinking I might give it a quick wipe but saw many small particles of sand sticking to it. I think I will remove it & give a a more thorough wiping. not sure yet if it requires what I normally do on an annual basis
rumrunn6 is offline
Old 08-02-21, 07:10 AM
Andy Somnifac
Andy Somnifac's Avatar
Bikes: Too many.
Quoted: 92 Post(s)
Liked 174 Times in 86 Posts
As others have said, the danger from sand is crashing, not component wear (to any appreciable degree to be worried about).
Andy Somnifac is offline
Old 08-02-21, 09:38 AM
woodcraft
woodcraft's Avatar
Quoted: 1814 Post(s)
Liked 923 Times in 569 Posts
BITD, I got my first top tier bike used, and it came from a sandy area.
When I tore it down for service, it was a gritty mess- especially the headset. Not sure if related, but the bearing races were brinelled or more likely false-brinelled. I rotated the races to keep things going.
woodcraft is offline
Old 08-03-21, 09:21 AM
Ghazmh
Ghazmh's Avatar
Quoted: 694 Post(s)
Liked 910 Times in 487 Posts
Don’t go into the corners too hot!
Ghazmh is offline
Old 08-03-21, 10:16 AM
Bigbus
Very Senior Member
Bikes: Giant Quasar & Fuji Roubaix
Quoted: 413 Post(s)
Liked 343 Times in 244 Posts
Everyday I ride on sand and except for the deep stuff it's no trouble. Gotta watch the corners though. With that said, I use wax on my chains so less sticks to them, but the only real issue is when it's raining or has rained and a fine slurry is splashed everywhere on and inside the components. It doesn't help that this slurry is heavily laden with sea salt. I hose everything after every ride when it's wet out (lots of heavy morning mists) and do a complete over haul of bearings etc at the end of the rainy season. HTH
Bigbus is offline
