Crack on seat tube lug
Would it be safe to ride this frame with this crack on the seat tube? I am going to use a pretty long seat post, on the long term, brazing the crack would be the best idea.
Bikes: lots
Quoted: 1953 Post(s)
Liked 2,923 Times
I can't see that being much of a problem. Just keep an eye on it.
Likes For cxwrench:
more daylight today!
Quoted: 4993 Post(s)
Liked 3,500 Times
Makes me wonder if your seat post is the right size, or did some previous owner jam something down the tube that wasn't the correct size and later corrected it.
But otherwise, I don't see any immediate fear. Just keep an eye on it as @cxwrench said.
If the crack turns horizontal and starts running around the circumference of the tube, then that will get to be a problem faster.
Quoted: 3722 Post(s)
Liked 2,763 Times
I would extend the slot down to close to the lug's bottom edge and round off the bottom of the slot. Seat posts can be harder to make tight is the slot is short. I like a slot at least an inch long. A warding file is what I use. Andy
AndrewRStewart
AndrewRStewart
Likes For Andrew R Stewart:
Liked 3,500 Times
But since I got rid of my older bikes, I can't double check that.
To be honest I don't know how long It's been there, maybe previous owner ignored the minimum insertion line, seatpost size 27.2.
This is from my Razesa pista, like Andrew said , the sloth is longer, the one of the cracked frame is really short , I didn't though much about it.
Quoted: 674 Post(s)
Liked 685 Times
That slot should have looked like this from the start. It looks like the builder filled the hole in the lug with brazing filler material and then made the slot too short.
Likes For dsaul:
Thanks for the editing, that actually makes sense , is kind of funny that the crack ends like is turning into a circle, just like it was supposed to be.
Quoted: 870 Post(s)
Liked 401 Times
Second, even if it did propagate, that crack isn't likely to cause a catastrophic failure anyway.
Here's an extreme example of a seat tube slot crack gone wild. A folding bike I bought in 2006 developed cracks extending circumferentially from the stress-breaker hole at the bottom of the slot. This seat tube was exposed to at least four cycles of latch opening/closing every work day for several years. I failed to notice it in time to increase the radius of the stress-breaker, and it eventually circled the top part of the seat tube at the weld joining the seat tube to the frame tube. This left the latch and its collar attached to the seatpost. It didn't interfere with riding the bike, as my weight held the seatpost in place and the crack didn't propagate anywhere else. Of course, if I lifted the bike by the saddle, the seatpost would come out. A couple of home-made aluminum stays connecting the seatpost clamp to the frame took care of this. I've ridden this bike for ten years since this repair without any problems. See the attached image.
My "winter" bike, with the jury-rigged stays to hold the seatpost in place when lifting the bike by the saddle.
That's a pretty cool Mad Max solution , I hope I don't have to do anything like that though, I have seen a lot of aluminum frames cracked at the seatube, not so many steel frames.
Likes For Gods lonely man:
Bike Butcher of Portland
Bikes: It's complicated.
Quoted: 4246 Post(s)
Liked 4,129 Times
Not a frame builder or pro mechanic, so my opinion is likely not worth much. Maybe @gugie could offer some advice - he's built and modified frames, and is by reputation very good at it. He's a regular in the C&V forum but this might pique his interest.
Likes For gugie:
señor miembro
Quoted: 2798 Post(s)
Liked 3,999 Times
I'd drill a hole (two, actually) at the bottom of the crack to prevent spread. Start with a tiny hole and then go one bigger.
Likes For SurferRosa:
Quoted: 466 Post(s)
Liked 414 Times
↑↑↑ This as the forward edge of the crack is a massive stress riser which is relieved but drilling the leading edge out.
