Rotor Alignment on Thru Axle
Old 08-11-22, 09:41 AM
Hypno Toad
meh
Hypno Toad's Avatar
Bikes: 21 CoMotion Java; 21 Bianchi Infinito; 17 Breezer Radar Pro; 15 Surly Pugsley; 13 Felt Z85; 11 Globe Daily; 09 Kona Dew Drop; 96 Mondonico
Quoted: 1074 Post(s)
Liked 936 Times in 487 Posts
EDIT: If the only reason you plan to post on caliber vs caliper .... feel free to move along, it's been covered below. I left the OP as posted so the relevant posts in this thread make sense in context, but enough has been said on the topic... and the issue has been resolved (see post 8).
I've been riding with disc brakes for nearly 20 years, I'm very familiar with re-aligning calibers. But here's my rub (see what I did there ) my 2021 Bianchi Infinito is my first bike thru axle bike and I thought the joy of a thru axle was the rotor/caliber would always be aligned. However, after a bike cleaning, the caliber is rubbing the rotor on the outside. The rotor is true, and I've removed the wheel, recleaned dropouts, and reinstalled ... still out of alignment.
I'll re-align the calibers later today, no big deal, but I just didn't expect I'd need to do this with a thru axle ... did I have unrealistic expectations?
For reference, the bike has 2,500 miles on it
Hypno Toad is offline
Old 08-11-22, 09:53 AM
surak
surak's Avatar
Quoted: 802 Post(s)
Liked 655 Times in 383 Posts
Did you push the pads out before reinstalling the wheel? Even a little bump on the brake lever could've moved the pads inward.
surak is offline
Old 08-11-22, 10:07 AM
Hypno Toad
meh
Hypno Toad's Avatar
Good question! I did a full brake service, removing pads and exercised the pistons (I had a lazy seal issue). The pistons were fully pushed back before installing pads and wheel. It seems possible that the caliber mounts where just loose enough for the force of pushing the pistons could have move the caliber. Visual inspection makes it look like the caliber body is too far in-bound, lot of pad showing on the outside and very little to the inside.
reference - lazy seal fix:
Old 08-11-22, 11:09 AM
Rolla
Guest
Quoted: 1346 Post(s)
Liked 3,262 Times in 1,437 Posts
Might it have been rubbing prior to the removal and cleaning?
Rolla is offline
Old 08-11-22, 11:25 AM
Koyote
Quoted: 5966 Post(s)
Liked 9,029 Times in 3,906 Posts
https://youtu.be/vQXFFgRButo
Sometimes when it seems like the pads have been pushed all the way back in, they're not quite there. And yeah, as I'm sure you know, once in a great while you might have to re-align the caliper -- which is a two-minute job, max.
Koyote is offline
Likes For Koyote:
Old 08-11-22, 12:45 PM
WhyFi
WhyFi's Avatar
Quoted: 20610 Post(s)
Liked 9,279 Times in 4,595 Posts
Some TAs do better than others and there's also a little bit of variance with torque; I've been using axles from Robert Axle Project, which need to be fastened with hex bits to a specific torque spec, and they've been great.
WhyFi is offline
Likes For WhyFi:
Old 08-11-22, 01:54 PM
MoAlpha
Bikes: Shmikes
Quoted: 8826 Post(s)
Liked 4,769 Times in 2,543 Posts
I've had that happen. Nothing goes together exactly the same way twice in this universe.
MoAlpha is offline
Likes For MoAlpha:
Old 08-11-22, 02:05 PM
Hypno Toad
meh
Hypno Toad's Avatar
welp ... my issue was really silly-basic, when I went to loosing the caliber mounts, the top bolt was barely holding. I must have shifted the caliber mounts when working the pistons. It's all aligned and torqued down and happy again. Note to self: check the mounting the bolts when servicing the brake system.
Leave it to this Toad to overthink an issue while missing the basic solution.
Likes For Hypno Toad:
Old 08-11-22, 02:18 PM
redlude97
Quoted: 1969 Post(s)
Liked 228 Times in 169 Posts
*caliper
redlude97 is offline
Likes For redlude97:
Old 08-11-22, 02:27 PM
rsbob
rsbob's Avatar
Quoted: 1452 Post(s)
Liked 2,689 Times in 1,547 Posts
Have the same ride and out of a moment of stupidity and complete inattention hit one of those blue reflectors in the center of the road indicating a fire hydrant. Ever since I get that annoying ting sound when the rotor strikes the pad. Have watched the vids on how to true a disc but the tolerances are too small even when I use the business card trick to reseat the caliper. Frustrating.
Road and Mountain 🚴🏾‍♂️
rsbob is offline
Likes For rsbob:
Old 08-11-22, 03:25 PM
cxwrench
cxwrench's Avatar
Bikes: lots
Quoted: 1954 Post(s)
Liked 2,925 Times in 1,488 Posts
20 years and you haven't realized they're CALIPERS, not calibers? If your caliper is indeed rubbing on the rotor your brake is wayyyyy out of adjustment. You sure it's not just the pad? The wheel will go into the bike exactly the same every time so there's something else happening here. Either the brake is getting set up incorrectly or it's not tight. Neither is possible for me to see through the internet. Also this is a mechanical question and should be posted in the proper section, not here in GS.
cxwrench is offline
Old 08-11-22, 03:31 PM
Hypno Toad
meh
Hypno Toad's Avatar
I'll come to you for spell checking before I post anything, thank you for your help.
And also you very accurate, the pad is rubbing and the caliper is out of alignment.
But if you read the thread, the issue was resolved without you input.
Old 08-11-22, 05:47 PM
Hypno Toad
meh
Hypno Toad's Avatar
Originally Posted by redlude97 View Post
*caliper
I'm embarrassed. But it's a life-long thing, I grew up with dyslexia. Too often I can't see the error until long after ... But that's also how I get better at proofing my own stuff.
Old 08-12-22, 04:39 PM
redlude97
apologies if my comment was taken to be as snarky as the one that directly followed, was not meant to be. Cheers
Old 08-15-22, 03:01 PM
Hypno Toad
meh
Hypno Toad's Avatar
You're all good!
There is another comment in this thread that was bordering on trolling ... but it was some very weak tea stuff, so NBD.
Old 08-15-22, 09:09 PM
50PlusCycling
50PlusCycling's Avatar
Quoted: 346 Post(s)
Liked 333 Times in 196 Posts
No pulsing in the brake lever when stopping? You can make a runout tool with a piece of metal wire, wrap it around the fork, then bend the wire until the tip almost touches the rotor, if the wire touches the rotor at any point while the wheel is turning, it isn’t true. I had a similar issue with one of my bikes, it turned out that there was a high spot on the hub flange where the rotor is bolted on. A little filing got it back into spec.
50PlusCycling is offline
Likes For 50PlusCycling:
