Tube exploded while filling!
Quoted: 37 Post(s)
So, I put a brand new tube into my tire. Filled it up to about 20 psi. Checked the rim all around. Bead was securely in the rim on both sides. White stripe around tire was even to the rim all around. So then I continued to fill it with my electric pump.
My tires (Schwalbe Marathon Plus) have a max of 60 psi, which I always fill it to without problems. However, I was a little past 55 psi when I heard a loud "bang" and all the air gushed out.
Looking at the tube, it was torn open by about a foot on each side of the valve.
Any idea what could have caused it?
I will say that I was going to add sealant to it, but I couldn't get the valve core out. Even used a metal tool, rather than a plastic one. But the tool wouldn't go all the way down into the stem, like something was stuck in there. However, the tube was able to receive air, so I decided to fill it up and ride with it until I could get a new tube.
Puzzling.
Puzzling.
Quoted: 3733 Post(s)
Liked 2,792 Times
I would wait on sealant filled tubes till you get tire mounting down pat. A foot long tube slash is nearly always from a portion of the tire bead not staying overlapped with the rim, the resulting hernia sees the tube balloon out through the gap and finally tear/explode.
There are a few common reasons why the tire bead might not be secure within the rim. The tube can get caught between the rim and tire bead, the valve base can prevent the bead from fully overlapping with the rim, the rim and/or tire might be made "off spec" and are not of matching diameters. All three reasons can be prevented from ending up as you did if the tire bead fit to the rim was done a few times during the inflation, catching the bulging off rim tire bead before the tube blew through the gap.
Besides checking the tire's seating a few times during the inflation one can try to see if the tube is caught under the tire bead before inflation by after mounting the tire/tube going around the wheel and prying the tire back away from one rim side and looking in the rim/tire to see if the tube is visible. The valve base needs to be pushed back up in the rim to allow the tire beads to slide down and fully overlap the rim's sides. Inflate a touch and check the fit as you did. Add 10 psi and recheck. Add 20 more and recheck. I would test inflate the tires about 10%-20% more than they will be used at (WRT the max allowed) to insure the tire is seated well and not creeping up off the rim. Andy
AndrewRStewart
AndrewRStewart
Liked 2,792 Times
I should have also mentioned another common reason why on inflation a tire can slip off the rim and the tube go boom. If the tire's pressure is low enough and the tire can "float about" the rim if the tires on the ground the weight will push the tire's top up out of the rim. If inflation is noy done slow and tire seating is checked a few times this lead to blow off. Andy
AndrewRStewart
AndrewRStewart
Likes For Andrew R Stewart:
It is possible you got a bad tube.
Our shop recently, past spring, had a batch of faulty tubes. We bought perhaps 50 tubes and while repairing flats they would burst at the valve. We thought it was us but after it repeated for 10 or so tubes in the same place it was clear it was the tubes. Likely just a problem at the factory. We received credit and that was that. We checked the other tubes and some were faulty the rest were fine. These were 700c tubes with a presta valve.
It can happen.
Make sure when changing a tube to check the rim strip to assure it is still doing its job. Check the tire carefully for the possibility of a sharp shard embedded that will cause a puncture somewhere down the road. Check the tire condition for wear, cuts, etc. Make sure the tube is not pinched under the bead when installing the tire.
It can happen.
Likes For Kai Winters:
Liked 2,792 Times
No, this flies in the face of reality. The tire didn't get pushed off the rim by the tube blowing out. The tire first was not seated fully and as it crept up off the rim the tube then expanded out that gap and very soon burst. Please understand what is the correct timing of events to better understand how to avoid then again. Andy
AndrewRStewart
AndrewRStewart
more daylight today!
Quoted: 5007 Post(s)
Liked 3,514 Times
My first thought was that when you put the tire on that you had part of the tire bead pinching the tube and it simply failed because of that. However you say that your tire came off the rim so that makes me wonder if the replacement tire is just the wrong BSD. Especially since you allude to having witnessed the tire being evenly mounted all the way around based on the white striping.
Still I suppose if it was the former issue and just the tube pinched between tire bead and rim that it might come unmounted during the failure. However the only times I've ever had a tire come unmounted is when way way overinflated to around 150 PSI or when I didn't actually have the witness line properly witnessed and that also involved being near the max recommended pressure of the tire.
Despite what ever the cause, it's basically poor practices. So pay closer attention next time.
Likes For Iride01:
Quoted: 1405 Post(s)
Liked 1,402 Times
The blowout was almost certainly not caused by a defective tube. Even a defective tube would have simply lost pressure, rapidly or otherwise, without dislodging the tire.
If your rims are hookless, they're more prone to allowing blowoffs than any rim with hooked sides.
A modern tubeless and hookless rim is pictured at right below, but many older bikes, especially those with 27" wheels, had hookless (a.k.a. straight-sided) rims.
Quoted: 264 Post(s)
Liked 284 Times
Likes For KerryIrons:
Quoted: 37 Post(s)
It can happen.
It can happen.
This tube was also a couple of years old, and had been sitting in my closet the whole time. I wonder if that had anything to do with it? Shouldn't have, but who knows.
Thanks again.
Quoted: 37 Post(s)
If the tire had come off the rim, causing the tube to expand and pop at that point, wouldn't the tear have been on the side of the tube, in the part that came out?
Also, I was watching the tire the whole time, and did not see anything coming out of the tire. Granted, I only saw one side of the tire. But, still, it appeared to be well-seated.
Quoted: 37 Post(s)
Thanks for the info about hookless rims.
Quoted: 37 Post(s)
Another way to think of this is that a length of the tube was caught under the lower bead of the tire. As the tube inflated, it pushed the bead up and dislodged it from the rim with the resulting blowout. Operator error is the most likely cause. Always inflate the tube just a little bit before installing to prevent this from happening.
Even though I checked the bead initially (at about 10-20 psi) I'll start rechecking again after a bit more air is in place.
Thanks.
Quoted: 17010 Post(s)
Liked 3,853 Times
However, I think the VALVE may be key here. The tire was probably partly sitting on top of the valve.
There are two theories of mounting the tube.
- Start at the valve and work away from the valve.
- Start opposite the valve and work towards the valve.
I prefer to start at the valve. Get the tire partly on, push on the valve some to make sure it is above the tire, and then work around.
Others believe it is safer to do the valve last, less chance of pinching that last few inches of tube. Nonetheless, once you reach the valve, the procedure is similar. Push the valve down to make sure it gets past the tire. Then pull it up.
If the valve is crooked, also make sure it is straight (often by twisting the tire around slightly).
Then inflate.
Liked 3,514 Times
However I know from experience that you can use tubes way older than 2 years. The badly stored tube is probably a rare exception.
One of the common tube failures I use to have before I finally learned the last few lessons my tires wanted to teach me was that I simply let the tube get pinched as I was trying to get the bead of the tire over the rim. Maybe you did that too.
There are several variation on how that might happen, but all result in a flat and all with a tear like you seem to describe. All were from my carelessness and being inattentive to things.
Tubes can dry out over time and the possibility of bursting especially at a seam, joint, etc. is increased.
Generally bewildered
Quoted: 1108 Post(s)
Liked 300 Times
Suggest that you read all of the tips about ensuring that a tire is seated, and remains seated, during the entire inflation process. I'm not casting any aspersions on your abilities or observational powers - we've all blown up a tube when the tire sneaks off the rim. It's just that, if you focus only on a "tube problem", and ignore the tire seating problem, you probably will go through a lot of "bad" tubes....
Quoted: 37 Post(s)
Granted, I was only looking at one side of the tire. But that was the side of the tire which came off the rim. So if the tire came off the rim first, allowing the tube to balloon out, it seems I would have seen it, since I was looking at the tire the whole time, no?
Also (and, again, not arguing, just trying to understand): if the tube ballooned out and then popped, then wouldn't that have been where the tear was, where the ballooning happened? But the tear was along the seam, at the very outside of the tube, not on the side of the tube.
Thanks!
Liked 300 Times
I'm not doubting that this is what may have happened. I'm only questioning why, if the tire slid off the rim, allowing the tire to balloon out and pop, that I didn't see it do it, since I was watching the tire the entire time. (The tire was off the bike in the back of my minivan while being inflated, and I was sitting next to it, holding it.)
Thanks!
Thanks!
Glad you weren't hurt. Good luck
