Old tourer and tire size limits
Quoted: 3221 Post(s)
Liked 2,049 Times
I had the good idea to install larger tires on my '98 Miyata City Liner tourer. Ive been using Marathon Supreme in 32mm, wanted larger to handle gravel rail trails and roads, so purchased same tires in a 38mm.
Then discovered that my 20 year old SKS fenders would not work with the 38's. A bit of research shows me that SKS makes a lot of different fenders for assorted tire sizes and I apparently had legacy fenders for a narrower tire size.
Well, OK, I get a set of new fenders for 50mm tires. Front installs no issues, plenty of clearance. Rear not so great. Issue is the lower mounting point at the B-bracket as well as the seat stay mount are seemingly too limiting for these newer fenders and I've got tire rub on the fender. It seems like the lower and seat stay mounts are designed for narrower tires as well, almost like wide tires were just not used 25 years ago when this bike was designed.
Anybody ever encountered this ?
i'm sure many have had similar problems, and shirley have workarounds.
post some photos.
post some photos.
Quoted: 3454 Post(s)
Liked 1,454 Times
My light touring bike frame was advertised as having room for 45mm tires. It also was suggested that if I wanted fenders, a 45mm wide Planet Bike Cascadia fender was what they suggested. They never said that a 45mm tire does not fit in a 45mm fender, but I knew that. I am using 37mm tires inside Planet Bike 45mm Cascadia fenders. They are about the max that will fit, their website says that my Schwalbe tires are 2mm too wide but they work.
https://www.planetbike.com/cascadia-...s-700c-x-45mm/
That said, I do not know if those fenders will fit your frame and I do not know if they will fit your 38mm tires.
I have no connection to the company, only citing what I have on that bike.
this is pretty typical for bikes of that era, and some newer bikes too, the rear end is usually where the limiting factor is. I have the same issue with a very similar era mountain bike, it can just take 2.5 in tires in the front, but total no go at the rear end.
too late obviously for you, but taking the bike to a store to get an idea of what fender could fit would have been better. I personally wouldnt have tried 50mm fenders for 38s, but then again, you probably were always going to have issues with this frame and its constraints.
I don't have links, but I have seen people who have done workarounds, like Mr Sores mentioned. Try looking up examples of where fenders have been trimmed down, or even cut in two pieces to avoid or minimize the fender in the tight area--but I suspect you may be up against a given amount of space, but only you seeing it in person will know how much wiggle room you have to try different things.
You could at least take the bike to a store and see how 35mm (ish) fenders fit, or at least get a better idea of what room you'd be dealing with for finding workaround solutions.
if interested, put up a good clear photo showing how much room you have with the 38s on, showing all the clearances you are dealing with.
I assume you won't be able to return the 50mm fenders, so up to you if you want to attempt doing a carving job on them if you can find examples of what others have done, but this shirley will involve improvisation with mounting methods.
Partially Sane.
Bikes: Soma Saga, pre-disc
Quoted: 972 Post(s)
Liked 643 Times
Haven't encountered it yet, but might soonish. 🤔 I'm actually going to be pretty new to fenders, but I've seen the wisdom of using them long ago. 😉
My Soma Saga is supposed to take 700x47s, and I have a 700x 42 on the back so far. It looks like there's a lot of room, lol, but what do I know? 🙄😁
Liked 2,049 Times
The fender was not the issue, the bottom bracket mount was a problem, too close to the tire. I ended up mounting the fender on the b-bracket side of the mounting hole, and installing the mounting bolt from the front, the head of the bolt interfered with the tire if it was on the rear side. Theres just enough clearance for the tire. I suspect the tires of the day in 1998 would have been 32-35 mm tops, these are 38.
Liked 2,049 Times
Here's a few photo's. #1 attempts to show the fender at the bottom bracket mount, Not a ton of clearance and no way to install the bolt back to front, which is the easiest access method. i also installed some rubber spacers to position the fender away from the tire. #2 shows the bolt head on the b-bracket side of the vertical mount. I had to trim the fender to fit it forward of the mount. #3 shows that there is reasonable clearance at the brake bridge on the seat stays. #4 is the view of the lower fender mount at the b-bracket area. Miyata installed a bracket welded between the chainstays to have a vertical mount for the lowest fender mount position.
Likes For Steve B.:
Quoted: 1324 Post(s)
Liked 927 Times
For the place where the fender mounts behind the bottom bracket and onto the chainstay bridge, you can get a spring steel clip to put onto the fender and then that clip snaps over the chainstay bridge.
Cheers
Cheers
Quoted: 753 Post(s)
Liked 735 Times
Ya, it seems that you found a good method with the rubber spacers and trimming the fender to at least get it forward more.
It really does seem that the immovable object is the welded vertical bracket and that is the roadblock that you just cannot physically change the distance between this and your tire right?
At first I was. going to suggest using zipties to hold the bottom part of the fender in place, as 1- I have done this on a fender with one of those clip things the other guy showed, and it kept popping up and loose on my wifes commuter bike, so I drilled a small hole in the fender and could run two small zip ties through it and around the part of the frame with the hole in it to run a fender bold through (first wrapping it with electric tape to protect paint).
If this would gain you a mm or two maybe that could help, but it looks like the vertical bracket is the limit of clearance between tire and this bracket--plus you've already run the bolt from the other way, so I assume there is not any part of the bolt sticking out near tire.
other than removing this vertical bracket, I can't see how you can gain more clearance.
Am I understanding this all right?
The photos are good, its just not clear to me with the tire in place where the vertical bracket is, but seems that this is the roadblock.
Oh, do you have sufficient side clearances? Look up recommendations but I reckon you'd want a good 5mm for any out of true wheel situation from a broken spoke.
Cant tell from your photos.
cheers
Liked 2,049 Times
Can't say what the clearance is, might be about 5mm, it looks OK and a test ride showed no issues.
That is correct. That is the primary limitation to the tires, but as I found a workaround, all is OK. I would suspect that as this bike is Miyata's "City Liner" it might have been designed as a commuter, not a full blown tourer. It has all the needed eyelets for front and rear panniers as well as fenders and has a bracket on the drive side seat stay for a generator. It also has 44cm chainstays so makes a perfect tourer and is how I use it, the attempt to move toa big tire was the only issue I had run into And, Yes, Zipp ties would have worked as well, especially the heavy duty 1/4" versions.
Your workaround did the job, if ever you do use zipties on other bike bits, I'm always amazed how even the small ones can last and last and last. Super tough doo-dads overall.
I too have an old hybrid commuter that is like your bike, very versatile with eyelets and rides well with heavy stuff on the bike. These are great, useable, versatile bikes.
I guess if you really needed to, you could file down the vertical support a bit, to gain some tire clearance if need be.
Oh--I would highly recommend taking out the bolt and putting a good amount of heavy automotive brake grease or something on all of the threads, just to make it easier in the future to get it out again, as it will get wet all the time and rust. I have some copper whatchamacallit heavy grease (toothpaste consistency) for stuff like this, that holds up over lots of time and wet. I know some folks use wax on fender mounts too, just to avoid corrosion and stuck in bolts.
you could get a bracket for quicky-release type fenders......clamp attaches to the seat tube.
won't use the chainstay bridge at all, just plug the hole.
wallyworld sells one version. you could prolly find dozens in the local family-type bike shop junk bin.
https://www.walmart.com/ip/AOOOWER-B...c-T/1099782481
Liked 2,049 Times
Palmer
Quoted: 1659 Post(s)
Liked 1,808 Times
Oh, yeah. My 1982 Santana tandem was designed for 27x1 1/4 tires. There was no concept that one would fit anything larger. I converted it to 700C, but still couldn't mount anything larger than a 700x32. I have a 1984 Trek 620 frame here you might get a 700x38/no fenders in, but heaven help you if a wheel went out of true.
Likes For tcs:
Bikes: 1974 Masi GC, 1982 Trek 728 (aka 720), 1992 Trek Multitrack 750
Quoted: 118 Post(s)
Liked 219 Times
I do like the old steel tourers for their style, and often times, value. Usually much cheaper than a new equivalent tourer. I don't like the fact they are old though, having snapped 3 1980's steel mountain bike frames (all at different points on each frame) in the last decade.
To the OP; it is the nature of the beast with these older touring frames and tire size limitations, which is another strike against them (if you need or seek to use a fatter tire)
Likes For prairiepedaler:
Quoted: 118 Post(s)
Liked 219 Times
But cyclists back then rode millions of miles loaded down on 27 1/4 or 700x32 tires and somehow survived . With proper bike handling skills one certainly can ride the rough stuff with skinnier tires, one might just have to go a little slower on the really bumpy parts.
Quoted: 118 Post(s)
Liked 219 Times
A lot of folks rave about the 1982-85 Trek 720/728 as a prime example of the touring genre. This was Treks top of the line touring bike, full Reynolds 531 double butted (oh yeah), silver soldered, Campagnolo dropouts, a very nice production frame. But the 82 model was spec'ed with 700c x 32 tires. The later models came with 27 x 1/4. Which of course is laughable nowadays. But that's just the way it was back then.
source:
https://vintage-trek.com/images/trek/Trek3.pdf
https://vintage-trek.com/images/trek/85TrekTouring.pdf
source:
Bikes: 2013 Custom SA5w / Rohloff Tourster
Quoted: 1233 Post(s)
Liked 318 Times
Good job. I like the bolt head on the inside. For some bikes it gives a bit more clearance to get the wheel out. likely that old bike too.
Easier to clean and dry the puddle splatter. I live in an apartment, so I shove a rag in the gap, then the tire rolls the rag around.
