Shimano or Microshift derailleur
Hi there was wondering which brand would be better Shimano or microshift? And its an 8spd cassette long cage.
Clark W. Griswold
Quoted: 3422 Post(s)
Liked 2,728 Times
Both are going to be pretty equally low end at the 8 speed range. The only way I would say one 8 speed is marginally better is if you were swapping to Microshift Acolyte but that is modern groupset and not just an S group 8 speed so it is compatible with it self as it uses different cable pull ratios.
The only reason to swap a derailleur on a new bike with 6-8 speeds would be to replace it because the old one is not usable at all anymore. Generally in that case I would use the same derailleur I had unless for some odd reason I could get an upgrade for less then the same derailleur or somehow they gave you a nice frame and nice suspension and other parts but really cheaped out on the groupset which is rare to non-existent.
Bikes: lots
Quoted: 1954 Post(s)
Liked 2,925 Times
^This^
Likes For cxwrench:
Quoted: 369 Post(s)
Liked 574 Times
I just replaced a front, 3 spd Shimano front road derailleur which was an old model prone to breakage, with a Microshift front derailleur. The Microshift works very well, I would not hesitate to purchase one again. Appears to be well made. Of course, with the temps here of late, my wife hasn't put miles on her bike. I know you're talking rear der., but if it's made as well, should be fine.
Steel is real
Bikes: 1992 Giant Tourer,1992 Merida Albon, 1996 Scapin, 1997 Kona Kilaueua, 1993 Peugeot Prestige, 1991 Raleigh Team Z (to be upgraded),1998 Jamis Dragon(to be built),1992CTWallis(to be built),1998Vetta Team (to be built)
Quoted: 75 Post(s)
Liked 148 Times
I would rather have gotten an older 8 speed LX or XT front derailleur shimano from ebay much better than microshift.
