1989 Trek 950 22 frame
Old 05-24-23, 10:10 AM
Chriscraft760
Chriscraft760's Avatar
Bikes: Trek TX700 and 720
Quoted: 73 Post(s)
Liked 53 Times in 20 Posts
1990 Trek 970
What are these taller lugged frame Trek 950s worth. Ive seen a few of them but mostly in the 18 frame size.
Chriscraft760 is offline
Old 05-24-23, 10:05 PM
katsup
katsup's Avatar
Bikes: 1995 ParkPre Pro 825 2021 Soma Fog Cutter v2 and 2021 Cotic SolarisMax
Quoted: 606 Post(s)
Liked 554 Times in 314 Posts
The crankset is not original and looks horrible.
I'd say $250 in the Southern California market assuming the bike is rideable. The crankset may hurt the value, but you may find someone that doesn't care.
katsup is offline
Old 05-25-23, 07:07 AM
bikemig
bikemig's Avatar
Quoted: 5873 Post(s)
Liked 3,432 Times in 2,061 Posts
Agreed that the crank does not look good on this bike. It likely won't matter to someone who wants a rider but it will matter to anyone looking for an older Trek to fix up and ride. $150-$250 in my corner of the midwest.
bikemig is offline
Old 05-25-23, 08:42 AM
zukahn1
zukahn1's Avatar
Quoted: 765 Post(s)
Liked 1,694 Times in 609 Posts
I would agree on the $250 or so in value really nice bike. But there are just a lot of really nice late 80's and early 90's MTB hard frames out there for sale at fairly cheap prices great for buyers not so great for sellers. As said the crank set and pedals do seem to hurt the bikes cosmetics and the cheaper ladies seat on this nice big frame bike just looks out of place.
zukahn1 is offline
Old 05-25-23, 11:58 AM
Chriscraft760
Quoted: 73 Post(s)
Thanks for the replys and estimate.
if I decide to keep it I would definitely swap out the seat, crank and pedals.
Old 05-25-23, 12:10 PM
TugaDude
TugaDude's Avatar
Quoted: 586 Post(s)
Liked 612 Times in 447 Posts
That clear plastic guard may be easily disconnected, you might want to check that before changing the whole affair out. I think it looks fine underneath probably.
TugaDude is offline
Old 05-25-23, 04:44 PM
Chriscraft760
Quoted: 73 Post(s)
yes it has screws on the back.
this originally came with a Shimano Mountain LX HP Biopace. Are these cranks any good or should I look for the Shimano Deor LX that came on the 90 & 91 models?
Old 05-25-23, 06:04 PM
Mr. 66
Mr. 66's Avatar
Quoted: 1120 Post(s)
Liked 1,673 Times in 934 Posts
The cranks on there are just fine, but not matching would drive me bonkers... did they change the bb also?
Mr. 66 is offline
Old 05-25-23, 06:48 PM
Chriscraft760
Quoted: 73 Post(s)
Im not sure how to tell if they also changed out the BB.
Its a Shimano square taper for the triple crank thats on there. Would this BB work if I can find the correct mountain LX triple crank?
Old 05-25-23, 10:59 PM
katsup
katsup's Avatar
Quoted: 606 Post(s)
The BB has to be the right length for both cranksets if you want to keep it. A mountain LX is probably 122.5mm or 127mm length. No idea what the current crankset is using.
Any Deore or higher level crankset from the early 89-93 would look good. Doesn't have to be the mountain LX.
Here is the wife's '89 970 so you can see the comparison (stock crankset).
katsup is offline
Old 05-28-23, 04:58 AM
brewerkz
Bikes: '85 Schwinn Madison, '46 Higgins Ultralite, 1950s Wally Green, '85 Trek 660, '82 3Rensho Export, '90 Trek 970, '91 Schwinn Paramount, '78 Dawes, '78 Trek 730
Quoted: 68 Post(s)
Liked 229 Times in 90 Posts
Check your local market trends, these are $100-150 in my area - region is everything for local values (ones priced higher seem sit for sale)
brewerkz is offline
Old 05-30-23, 04:31 PM
Chriscraft760
Quoted: 73 Post(s)
I was able to find the correct 1989 Shimano Mountain LX crank on eBay with the 26-36-46 tooth rings.
Likes For Chriscraft760:
Old 05-31-23, 01:34 PM
zukahn1
zukahn1's Avatar
Quoted: 765 Post(s)
Great ,note the older hard allow or steel Biopace rings grip hard and can be chain eaters so you should upgrade put a new chain on the bike. I have steel Biopace small bail outs on a couple bike's they work great. Also you can pretty easy replace mix match rings on this crank and gear setup.
zukahn1 is offline
Old 07-06-23, 10:27 PM
Marcus.
In the market
Im in the market for one of these in the 22 size and dont care much about what components are on it. I really just want a frameset in decent shape to build up with modern components. This one looks great I bet it rides like a dream!
Marcus. is offline
