Shimano IGH hub shell diameters
Hello,
Hubs: any 8-speed Shimano IGH, preferably SG-8R36, SG-S501
See attached figure.
Can you measure the diameter or circumference of the NDS & DS openings? Can live with an error of a couple of mm. Please indicate hub model, too.
Thanks.
Thanks.
Quoted: 4195 Post(s)
Liked 3,837 Times
What ya planning? Maybe a stub type axle? Trike? Andy (who has a SA AG hub on his bench right now)
AndrewRStewart
AndrewRStewart
Need to find max size of outside calipers that can fit either end of the hub.
Just discovered hub shells are not available as spare parts and want to be careful locating oil ports. Outside calipers are less expensive than vernier calipers.
Really Old Senior Member
They can be inside or outside.
No idea why you would mention Vernier then.
https://en.wikipedia.org/wiki/Vernier_scale
https://www.harborfreight.com/6-in-u...per-63664.html
"Outside calipers are less expensive than vernier calipers."
Perhaps I was too cryptic.
I meant outside calipers, without scale, are less expensive than vernier calipers (the usual calipers that look like a ruler).
I just needed to find a suitable point inside the shell and the corresponding point outside the shell.
Lost cause
Ignore list
Likes For grumpus:
Wish I had thought of it.
Thank you, so much.
For Alfine and Nexus 8-speed hubs, google shows around 92.6 to 93mm as PCD.
https://www.sheldonbrown.com/nexus8/pages/28.htm
https://www.kstoerz.com/freespoke/hub/168
https://www.kstoerz.com/freespoke/hub/169
Hub in photo (not mine) is Alfine SG-S500 or 501.
From the photo,
NDS opening is between 75 and 80mm
DS opening is between 16 and 18mm.
Accuracy is limited by the presence of grease and probably recessed DS opening.
Appreciate any physical measurements. No need to remove hub from wheel or wheel from cycle.
Use a pair of dividers for diameter or a string and scotch tape for circumference.
I'm also interested in oil port for my nexus hub, post some photos when you're finished, thanks , Marty
Senior member
Quoted: 942 Post(s)
Liked 656 Times
Also important to do it with the internal assembly removed because even minuscule chips from the drilling process will play havoc with the internals.
Quoted: 980 Post(s)
Liked 580 Times
Let me play the Devil's Advocate here.
The Nexus hubs are not sealed well enough to be filled with a substantial amount of oil, as (for example) the Alfine-11 is. There may not be a way for the oil added through a port to reach the non-drive-side bearing.
It's very easy to pop the gear cluster out of the hub once a year to dip in gear oil. This provides the opportunity to properly grease the bearings, as well as to inspect the mechanism for any developing problems.
(/DA Mode)
(/DA Mode)
If you cannot use a divider + ruler or a digital calipers to measure diameter or measure circumference with string + tape, you shouldn't even think of an oil port.
Search this forum + internet for photos.
