View Poll Results: how long does an application of drip wax last you?
<100km
2
5.26%
101-200km
6
15.79%
201-300km
13
34.21%
301+km
5
13.16%
don’t use it, feel like voting anyway.
12
31.58%
Voters: 38. You may not vote on this poll
drip wax longevity
Likes For spelger:
I like bike
Bikes: Roubaix Comp 2020
Quoted: 267 Post(s)
Liked 283 Times
Gee only minor splattering for me. If the solvent is filled even a small amount above the level mark it can make a mess but at level and with the sponge thing in it pretty much stays in the box. There is a tiny bit of spray coming out onto the back rim is about all I get, and I barely notice it. With lube in it I have minimal splattering/dripping if filled to the fill line. I was a bit over the fill line on my last lube and I had maybe 10 drops fall off the chain while it went around.
Method to My Madness
Bikes: Trek FX 2, Cannondale Synapse, Cannondale CAAD4, Santa Cruz Stigmata GRX
Quoted: 1939 Post(s)
Liked 1,463 Times
If one goes through the rigorous cleaning process in order to use drip wax, one might as well go for hot melt wax immersion.
Sock Puppet
Bikes: 2014 Cannondale Synapse Carbon, 2017 Jamis Renegade Exploit and too many others to mention.
Quoted: 1031 Post(s)
Liked 863 Times
Too much hassle and wasted time for something like a chain. My chain doesn't come off the bike until I am ready to replace it. Re-lube every 500 miles, wipe down, then wipe down again after first post-lube ride and it's clean enough. No need to overthink it.
Likes For Lombard:
climber has-been
Quoted: 3409 Post(s)
Liked 3,540 Times
I've been using the Pedro's Chain Pig (only when the chain is dirty). It's a one-handed tool, and it's quite a bit less messy. A substantial improvement.
Ride, Rest, Repeat. ROUVY: terrymorse
Quoted: 2332 Post(s)
Liked 2,097 Times
BTW....your chain maintenance is atrocious.
Bikes: SL8 Pro, TCR beater
Quoted: 981 Post(s)
Liked 582 Times
I switched from Muc-Off (regular dry one) to Squirt last year and I do get roughly twice as much distance between lubrifications with the latter. I am anal when it comes to chain lubrication so I lube it as soon as it becomes noisy.
50-75kms with Muc-Off
100-150kms with Squirt
Sock Puppet
Liked 863 Times
Well let's just say my "atrocious" chain maintenance procedures get me 8 to 10K miles per chain.
Sock Puppet
Liked 863 Times
Agreed, that Park Tool chain cleaner is a mess to use.
Likes For Lombard:
Quoted: 760 Post(s)
Liked 1,717 Times
Park Tools torque wrench is a re-branded Chinese tool. My small torque wrench finally died and I noticed when looking for a new one, they all seemed to be the same design and look, just different handles and some had different color schemes. Park Tools wanted 130 at the time and I found others for 35 - 50. The one I got was $45 and works like a champ and the torque values are spot on. A friend of mine is a master mechanic and has a calibrator for his shop, so he tested it for me.
Quoted: 1273 Post(s)
Liked 1,384 Times
so, i just checked my chain, which has 2,500 miles on it. the .5% percent of the checker is just barely sliding in, the .7% side won't go in. shimano advice is to replace a 12 speed chain at .5%.
not too impressed, my clean/lube routine must need some work.
Sock Puppet
Liked 863 Times
Check chain wear with a ruler:
Bicycle: Measuring Chain Wear using a 12-Inch Ruler
Quoted: 426 Post(s)
Liked 274 Times
Those chain checkers can give you readings that are wildly off.
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Sock Puppet
Liked 863 Times
Most rulers stop at 12 inches. I bought this metal 14 inch ruler so I could check for 12 and 1/16th to 1/8th inch.
Liked 1,384 Times
could a simple tool like that really be so poorly produced as to be wildly off? it’s just a piece of metal!
Quoted: 981 Post(s)
Liked 582 Times
That, or you're pushing too many watts in average . I got 9000kms out of my 11sp (5500mi) and it's between .5 and .75 according to my checker. Not sure when exactly it did reach .5.
Quoted: 2479 Post(s)
Liked 2,947 Times
The chain comes out clean and lightly but sufficiently lubricated, with no oil dripping from the chain. In fact, I've never had to clean any chain I've lubed that way, other than wiping it down after I remove the case and after the first ride.
so, i just checked my chain, which has 2,500 miles on it. ...not too impressed, my clean/lube routine must need some work.
Liked 1,463 Times
Versus those with three points of contact, e.g., Amazon.com : CC-4 - Chain Wear Indicator : Sports & Outdoors
The latter version is more precise.
Liked 1,384 Times
My environment in SE Georgia may be similar to yours with a lot of sand that makes its way onto chains. I remove my chains, use mineral spirits to wash them while off the bike, and relube (I use a wet lube - maybe I need a revision). Every time, I am surprised at the amount of sand I capture off an 11 spd chain. I replace at about 2500 miles at about 5% wear. I use a 6" vernier caliper to measure.
the conditions of most of my rides *seem* benign but there’s definitely coastal fog (which may be salty?) and a little wind blown sand.
looks benign!
but covered with sand 1/2 the time
heavy fog maybe 1/3 of the time through here, with correspondingly wet ground in the AM
Liked 1,384 Times
We need to differentiate between the chain checkers with two points of contact, e.g.: Amazon.com : Park Tool CC-3.2 Chain Checker : Chain Wear Indicator : Sports & Outdoors
i will say that after changing the chain, the drivetrain is much quieter. in fact i can’t hear it anymore, at all. tires are louder, so the chain was definitely a bit worn. hopefully not too much > .5
Liked 1,463 Times
Because the instructions are engraved right on the tool itself.
Sock Puppet
Liked 863 Times
how often do you take them off for the cleaning? i basically never take it off between replacements, maybe i’m just not getting it clean enough.
looks benign!
looks benign!
Quoted: 760 Post(s)
Liked 1,717 Times
