Nonago from a (faux?) Gios?
Bikes: 80s Alan Super Record, 79' Somec Special, 90s Rossin(?) Columbus Ego Triathlon, previously: Bianchi SBX Reparto Corse (stolen) and so on...
Quoted: 391 Post(s)
Liked 812 Times
I'm eyeballing with a fake Colnago which has drilled droupouts á La Gios (I must admit, they look crooked compared to other legit ones I have checked, but maybe my brain just doesn't want to believe it is real), GIOS lookalike seat stay caps, GIOS cast in the bb shell, Gios-looking BB-down tube lug, BUT...
- internal top tube cables, which look wrong (in 84' they ntroduced the plastic caps, and on modern ones one outlet points upwards, the other downwards if I saw it properly)
- no panto in seat stay cap (again since 84 those should be all over)
- fork is a definitely no-no, but that can be because it is a NoNago after all..
I'm asking the smarter than me, what do you think.... GIOS or not? I have no access to the bike, can't check for rifled tubes or measure anything, and don't want to ask a word beside he's willing to ship or not...
Thanks in advance for any constructive insights.
Lattz
Lattz
Quoted: 2588 Post(s)
Liked 4,824 Times
Looks like a legit Gios - perhaps a Professional, which had the rubber caps at either end of the internally-routed brake cable. Could be somebody did some brazing of those two metal bits when the frame got repainted. And, it probably got repainted due to the crash that took out the original fork.
IOW, frame is legit, with later metal/paint work. Fork is not.
DD
DD
Quoted: 391 Post(s)
Liked 812 Times
Thanks Drillium Dude first I also thought its the "plastic cap" Professsional but those seemingly all have GIOS in the seat stay caps. Whereas earlier than those models feature external cabling and no FD hanger. I it had an external cabling and someone converted it to be internal it would be no nonsense to convert back plus then it would need the coined fork which fly around for the price of a decent bike. I guess I'm going to sleep one or two on this. I was hoping someone ends my torture by quickly buying it but no one bats an eye.
Lattz
Lattz
www.theheadbadge.com
Quoted: 2421 Post(s)
Liked 4,390 Times
Bikes: A few too many
Quoted: 1364 Post(s)
Liked 2,180 Times
Lattz Looks like a Gios "frame" to me too....BB as well as the seat stays seem correct, but the rest is not. So for me it is a frame with parts to sell in order to hang the correct group on it......Can you get it at a good price?
Good Luck, Ben
the frame in question is newer, it has internal routing for the cables.
see any similarities
Same here
Look familiar?
https://www.bikeforums.net/classic-v...ave-i-got.html
https://www.bikeforums.net/classic-v...real-fake.html
Good Luck, Ben
Same here
Look familiar?
Voltaire
Voltaire
Likes For xiaoman1:
Quoted: 391 Post(s)
Liked 812 Times
Thanks for the comments, I guess,if it is original, it is a later (80-81) example from the older "Super Record" model line with the internal cable "feature" added later rather than a "Professional" since those should have pantographed seat stay caps as well (and most possibly lugs also). This idea is also backed by the separate chainstay bridge which is part of the BB cast on Professionals. One notable thing is on the first pic from xiaoman1 these kind of "crossed tubes" brake bridges (also on the one in question) are rarely seen, but exist(!) usually the rounded cube (like a roll die) ones are more common.
For EUR250 with most parts to be changed I can't call it a cheap one, considering I would end up with a frame without fork, and the forks are terrorist expensive for these. But I guess asking the guy if he is willing to ship it does not hurt, I can still say yes and no based on his answer. I knew about 2 legit Professionals both with Campy (one is period correct SR, the other is 1st gen. Chorus) for ~500 +shipping (if seller would ship) but those are out of my reach now. Super Records usually fly here in the ~1300ish range, so it is mostly a now or never thing, even if I'm not convinced I want to get into the hassle of finding a frame builder covering the holes, and sew up a few cable guides, then seek endlessly for a fork, so let's see what life brings
Thanks again!
Lattz
Thanks again!
Lattz
