Fork mount pump?
Bikes: Subject to change at any given moment but currently is...... Colnago Mapei, Colnago C40, Wilier Triestina Carbon, Wilier Triestina Ramato, Follis 472, Peugeot PX60, Razesa, Orbea Terra, Soma Pescadero and 1/2 owner of a Santana tandem.
Quoted: 322 Post(s)
Liked 775 Times
Fork mount pump?
I’m looking for a fork mounted mini pump for my 2011 Orbea Terra gravel bike. It does not have any sort of mounting bosses or such, and what pumps I’ve found so far seem to be designed for that type of mounting.
I’m not certain how I’ll mount it as I doubt zip ties will be effective but hopeful one of you folks has some ideas?
Quoted: 6882 Post(s)
Liked 10,875 Times
I've neither seen nor heard of such a thing.
Likes For Koyote:
Quoted: 18320 Post(s)
Liked 15,300 Times
Is this a joke? The fork seems like a really bad place to mount a pump.
Bikes: 2023 Cervelo Soloist 2007 Specialized Tricross 2017 Colnago CRS 2001 Schwinn Homegrown
Quoted: 10 Post(s)
Liked 65 Times
You can get something like a Lezyne Pocket Drive and carry it in your jersey pocket.
Quoted: 497 Post(s)
Liked 622 Times
I don't know.
Bikes: '90 B'stone RB-1, '92 B'stone RB-2, '89 SuperGo Access Comp, '03 Access 69er, '23 Trek 520, '14 Ritchey Road Logic, '09 Kestrel Evoke, '08 Windsor Tourist, '17 Surly Wednesday, '89 Centurion Accordo, '15 CruX, '17 Ridley X-Night
Quoted: 306 Post(s)
Liked 823 Times
or if you're riding with a small pack, like a hydration pack, put a Road Morph in there. You'll have an upgraded pump with a built-in gage.
Likes For RB1-luvr:
Grupetto Bob
Bikes: Bikey McBike Face
Quoted: 2512 Post(s)
Liked 5,430 Times
I would think the last place one would want a pump to come loose and end up in your spokes is the front wheel. Why are you specifically looking for a front wheel mounted pump?
Road 🚴🏾♂️ & Mountain 🚵🏾♂️
Likes For rsbob:
Thread Killer
Bikes: 15 Kinesis Racelight 4S, 76 Motebecane Gran Jubilée, 17 Dedacciai Gladiatore2, 12 Breezer Venturi, 09 Dahon Mariner, 12 Mercier Nano, 95 DeKerf Team SL, 19 Tern Rally, 21 Breezer Doppler Cafe+, 19 T-Lab X3, 91 Serotta CII
Quoted: 3078 Post(s)
Liked 1,631 Times
Liked 15,300 Times
And it wouldn’t surprise me in the least to learn that at least some pumps carry a warning not to mount it on the fork. Common sense is not always common.
Quoted: 94 Post(s)
Liked 282 Times
Would these work for you? I have the pump. Its very nice. I added to a bike with mounts but intend to get another with the mount below for a bike without the nut-serts. You can also mount a bottle cage on top of the pump bracket. I have.
https://www.amazon.com/zonkie-Bike-B...LBV&psc=1&th=1
https://www.amazon.com/Tiakia-Bicycl...7HP4FKFP&psc=1
Likes For streetsurfer:
Quoted: 1936 Post(s)
Liked 2,150 Times
I have not seen a pump mounted on a fork, but I have seen pumps mounted on a seat stay. I don’t consider either ideal, because of the potential for the pump bumping loose, especially on rough terrain, and lodging between the wheel and the fork blade, or chain stay.
The big difference is what happens to the rider when the wheel suddenly stops. Neither is good, but when a front wheel suddenly stops the rider doesn’t.
John
John
Bikes: There is always room for one more.
Quoted: 179 Post(s)
Liked 366 Times
If you really must mount your pump to the fork, you can use zip ties and a fourth hand tool like the one shown below to attach your pump mount. The fourth hand tool can get the zip ties extremely tight. I've used this method to mount bottle cages and pump mounting brackets very securely many times. However the only things I ever mounted to a fork this way is are sensors for wheel mounted cyclometer magnets.
https://smile.amazon.com/IceToolz-Fo...%2C1213&sr=8-9
Don
Don
Quoted: 5220 Post(s)
Liked 3,564 Times
FWIW I had 1 pump mount that I liked very much so I bought 2 more for my other bikes. I just have to remember to move the pump to whatever bike I'm riding. the bracket I like sits under my water bottle cage on the down tube. the pump clips in but there's also a velcro strap to keep it attached to the mount.
something like this
looks like you're not the only person to mount a pump on a fork
https://bikepacking.com/gear/crankbr...v-pump-review/
https://www.printables.com/model/195...29-mm-diameter
good luck!
something like this
good luck!
Liked 3,564 Times
Likes For Germany_chris:
Likes For noimagination:
Thread Killer
Liked 1,631 Times
The problem of pumps falling off was solved back in the ‘80s.
Grupetto Bob
Liked 5,430 Times
Thread Killer
Liked 1,631 Times
The craziest part is that I also know that Velcro was used in outer space two decades before that, flying on Gemini missions. Why did it take more than 20 years after that for cyclists to figure out the pump strap? Well, this thread suggests that we’re, quite literally, not rocket scientists…
Likes For chaadster:
Liked 10,875 Times
Quoted: 3192 Post(s)
Liked 2,461 Times
Seems like Team Cinzano used a pump that would insert onto/into a fork BITD. I'll have to look it up to see what brand it was. It was most likely a Silca.
Likes For seypat:
Mounting on the fork where it could either get bumped loose despite safeguards and wedge in the front wheel, or catch on something and yank the bike from under you? Or just twist around and take out half of your front spokes? None of those outcomes seem desirable. It sure sounds safer to co-mount it with a bottle cage. I have a few of those and they work just fine.
Liked 2,150 Times
Well it doesn't take a rocket scientist to realize that using velcro on a tapered object doesn't seem to work all that well. Maybe in space with no gravity, but hardly on an application where the fork blade cross section tapers and gets smaller towards the hub. Not quite as severe as using velcro on a funnel.
There is a reason people don't install front panniers with velcro.
With that in mind, having actual fork attach points would probably work fine since the pump can't slide down and then rotate into the wheel.
John
John
