Is repairing a broken lugged steel frame a viable option?
Bikes: 85 Trek 400, Trek 7000ZX , Schwinn Circuit
I have used Franklin Frames before and he does really good work at a reasonable price. He is an older frame builder that is close to Columbus Ohio. You could even ship the bike to him and he will fix it up and send it back to you. 7179 Reform Rd, Newark, OH, United States, Ohio
(740) 763-3838
franklinframe@windstream.net
(740) 763-3838
Quoted: 486 Post(s)
Liked 429 Times
It's unlikely a simple sleeve will work, as the fracture is probably where the butt ends, so you'll be working with two different internal diameters. Also you'd want to silver solder it, and it won't be easy to get the inside of the tubes as clean as you need for that to work reliably. It's not difficult for a competent frame builder to replace the whole tube, but if the downtube is corroded or fatigued the top tube may not be far behind, and if you replace both of those you're paying for half a frame anyway so you might as well get a new one.
Quoted: 2337 Post(s)
Liked 2,820 Times
external sleeve.... look at the post in C&V where a well respected frame builder showed examples for such a fix. bronze brazing rod, not silver due to lower temps
Quoted: 586 Post(s)
Liked 612 Times
There is also the issue of liability to consider. I don't know that frame builders carry liability insurance, but they should!
As much as I like to save and/or repurpose things, I'd be looking for a new frame. If you miss sitting on the bike seat, turn it into a stool as suggested above. They are actually pretty cute.
Liked 2,820 Times
check this thread about 2/3 the way down where Doug Fattic shows details of an external sleeve repair. intteresting
https://www.bikeforums.net/classic-v...iviera-gt.html
Quoted: 486 Post(s)
Liked 429 Times
