What's the fastest you've gone on your bike?
#126
Interesting to check this stuff out. From Omnicalculator, I get 3,872W required in the drops at 76 mph down a 12% grade. Coasting down a 12% grade gets me about 53 mph. Coasting down a 24.2% grade gets me to 76 mph. Not sure how accurate that is, but I don’t doubt the numbers can get big easily, depending on weight, grade and speed.
Otto
Otto
#127
Quoted: 696 Post(s)
Liked 910 Times
Warp .0000000000001.
#129
Cheerfully low end
Quoted: 644 Post(s)
Liked 1,044 Times
So here's what I want to know about these posts. How are you getting any watts at these speeds? I mean, just on my little rides where I'm going down my 2% grade with a tailwind, I might push 40mph. But at that speed, pedaling has no input. My wheels are turning faster than I can pedal.
The equation just looks at conditions (wind, grade up or down, riding surface) and bike/rider data (total weight, frontal surface area, tire rolling resistance) and then figures out the power the rider needs to supply to make the equation work. On a down hill grade, the answer could be negative meaning that is the braking power needed to stay that slow and not reach terminal velocity. Typically it’s positive and means pedaling is needed.
Example, I can run the calculator to see I can coast my road bike down a 12% grade at 53.5 mph. That means I put in all the factors, and get roughly zero watts needed. In theory, if I pedaled at 300 watts, I should be able to nudge up to 56 mph and hold that for a while since I can sustain that power a long time.
However, as you point out, I likely don’t have relevant gears at that speed to let me add any power. Even at my top gear and spinning at 130 rpm, the bike is already going faster, so I just spin up and coast.
In theory, a really big chainring and really small cog or a compound drive with an internal gear hub as well could offer the ridiculously high gearing needed to spend your energy making tiny speed increases rather than just relaxing and enjoying the thrill of coasting down.
Otto
#130
Bikes: Lemond Zurich/Trek ALR/Giant TCX/Sette CX1
Quoted: 553 Post(s)
Liked 747 Times
The 76mph down hill is very suspect on a road bike. On a -15% grade, you need a 60x10 gear ratio at 160 rpm just to keep up. And at sea level you also need to ADD 3330+/- watts to the equation. 1/2 of that a 5k elevation - about 800watts at 10k.
Assuming a road bike was being used - this feller would need huge gear ratios and have the ability to put down some serious power at 160RMP while controlling a bike at 76mph. Or he had a 50mph wicked fast tailwind.
#132
Quoted: 553 Post(s)
Liked 747 Times
Alone I will crank up to 26 mph, not easy for me, settle in for a bit and do an all out sprint. Max flat ground speed was close to 31mph@1140w. I wonder what a launch,, if I could keep up with the lead out, would do…
Ive even tried to slow roll up to speed and I poop out between 30-31, even when trying to be aero as my big body will allow.
Im always amazed to see solo riders finish a long stage on a 34+ breakaway.
#133
Maybe a little different for me, since now I only ride single speed analog and e-bikes, which in both cases limit me to the single gear ratio.
Every ride, get up to about 38-40mph. Max speed 53 mph, down a mountain. Got to really crank up the RPMs, then get in an aero tuck, since I’m geared out.
#134
Cheerfully low end
Quoted: 644 Post(s)
Liked 1,044 Times
Weight has a significant impact. On a 30 pound total bike weight, my 180 pounds gives a terminal velocity of 53.5 mph on a 12% grade. If I weighed 250 pounds, my terminal velocity rises to 62mph.
I would need a 24% grade to reach 76 mph (and boy would that be hair-raising), while a 250 pound rider needs about 18%.
Oh my… two 200 pound riders on a tandem would need to brake slightly on a 12% grade to stay at 76 mph.
Otto
Likes For ofajen:
#135
Grupetto Bob
Bikes: Bikey McBike Face
Quoted: 2568 Post(s)
Liked 5,599 Times
#136
Quoted: 3942 Post(s)
Liked 7,284 Times
Realistically we are discussing terminal velocity and coasting at such high speeds. That will be dictated by total weight, grade and rider position.
Otto
Otto
#138
Quoted: 6939 Post(s)
Liked 10,944 Times
I’m a bit amused by all these armchair physicists… None of whom were actually there.
#139
Cheerfully low end
Quoted: 644 Post(s)
Liked 1,044 Times
It’s also not uncommon for a long descent to have a somewhat steeper section based on terrain that would increase the max speed. A quick dip to 14% makes a difference in max speed.
And these online calculators are just using standard formulas but any real life situation will be different in some way. A particular effective tuck posture could have a significant impact.
Otto
Likes For ofajen:
#140
Cheerfully low end
Quoted: 644 Post(s)
Liked 1,044 Times
Otto
Likes For jadmt:
#142
Liked 10,944 Times
Yeah, just doing things for my reference first. I don’t know what Koyote weighs nor the relevant elevation but if I were cycling at, say, 8000 feet my terminal velocity on a 12% grade increases to 61.5 mph. For a 220 pound rider it increases to 67 mph. For a 250 pound rider it’s 71 mph. For two 200 pound riders on a tandem, it’s 88 mph.
Otto
Otto
#143
Grupetto Bob
Liked 5,599 Times
And then again there is the terror of high speed wobbles. Must be something better than bracing the top tube with knees and raising your bottom off the seat.
Road 🚴🏾♂️ & Mountain 🚵🏾♂️
Likes For rsbob:
#144
Habitual User
Quoted: 4926 Post(s)
Liked 8,060 Times
At 60mph, I was sitting on my top tube, with my chest on my stem (the now-illegal position in UCI racing). Maybe I could have gained a bit more speed if I didn't have my hands out in the wind on the drops, in easy reach of my brake levers.
#145
Bikes: !982 Trek 930R Custom, Diamondback ascent with SERIOUS updates, Fuji Team Pro CF and a '09 Comencal Meta 5.5
Quoted: 1299 Post(s)
Liked 739 Times
53mph on fresh, flat pavement, Disneyland Anaheim Parking lot, 1971, Mitzutani Super-lite Factory race bike, 120 lbs in the 19mm tubulars(sew-ups). no aero-aids... I was "clocked" by the security guard
72mph coming downhill from Govt,. Camp, Oregon on Hwy 26, Fresh pavement. Same year, same bike
i was 12 at the time
#146
Bikes: Handsome xoxo, Serotta atx, Canyon Endurace CF8
Quoted: 904 Post(s)
Liked 1,881 Times
#147
Grupetto Bob
Liked 5,599 Times
#149
Along for the ride
Quoted: 109 Post(s)
Liked 211 Times
But the fastest I've gone on a non-motorized "vehicle" was a descent I used to do from a water tower on my Flexy Racer. The Flexy Racer is a head-first sled on wheels with almost zero brakes. It was just so stupid fast. I only did it 3-5 times ever; I would shake from the adrenaline before the ride, and for a while thereafter! My parents' street was on a good hill; my sister's boyfriend clocked me at 45mph on his motorcycle. This was child's play by comparison to the water tower hill; could have done it blindfolded and backwards. Had several friends positioned at the intersections where cars were thought to be a probable issue. So insanely fast. Given how my vision blurred as tears streamed sideways from my eyes, I'm thinking I was pushing 70. Can't believed I lived to tell the tale.
Sure wish I had been clocked on that one!
Likes For retswerb:
#150
Liked 739 Times
Interesting article about unassisted top speeds by pro-riders and on the velodrome. https://biketoworkday.us/how-fast-can-you-go-on-a-bike/
