Frame Question for Fuji Mechanics or Experts
Back on the saddle again.
Bikes: Ultegra 6800 with cracked frame
I am looking at purchasing a Fuji 2.1 SL frame only for a couple hundred bucks.
Issue is, there are no shifter components for it, it is just a bare frame. As you can tell from this listing, it used Ultegra Di2 for the shifters with Rim brakes.
https://www.bicyclebluebook.com/valu...condition=GOOD
I was wondering how hard would it be to put my Ultegra 8000 group set on this thing. It has mechanical shifting, not electronic.
Does this frame share the cable routing for the front and rear derailleur as a non-Di2 frame would have?
The only worry I can guess at would be the cable routing under the BB and back thru the frame for the front derailleur.
Am I crazy for wanting to try this update?
Quoted: 4342 Post(s)
Liked 1,528 Times
If you go closeup on the picture you'll see gray ports near the headtube for cables. Most frames of this type can be built mechanical or Di2. Especially back in 2016.
The problem you are likely to run into is finding all the hardware that allows the cables to go in and out of the frame. You can certainly coble something together, or find a Fuji dealer that has some sitting around, but it may be frustrating.
But if the price is right, maybe you're up for it.
Likes For Kontact:
Bikes: !982 Trek 930R Custom, Diamondback ascent with SERIOUS updates, Fuji Team Pro CF and a '09 Comencal Meta 5.5
Quoted: 1299 Post(s)
Liked 739 Times
That bike is meant for a full-race bike with a light weight rider...Are you a light weight Racer able to handle a twitchy race bike on downhills? 73* is a Steep head angle. they are known for a cramped, low rider position too... not an option for most older riders, IMO.
If YOU are up to riding a quick steering bike like that, I'd question why you're asking us for info.. Is the deal local or an internet purchase? Buying a super thin CF frame over the internet is risky. I'd want to carefully inspect the frame before purchase..... in the sun... with a magnifying glass.
it should build up into a sub-17 lb. rocket ship...
Liked 1,528 Times
https://archive.fujibikes.com/2016/Fuji/sl-21
The two most predictive indicators of handling are the wheelbase and the trail.
None of this is true. 73 is a very standard road bike headtube angle, and is only used in the 54 and larger sizes for this model. Handling is primarily dictated by trail, and the fork offset of 43mm combined with the 73 HTA yields a stable 59mm of trail. For larger frame sizes, 73 is pretty slack. 61cm frames are often 74 degrees (and still stable).
Thanks for the info.
Quoted: 513 Post(s)
Liked 445 Times
Your second-hand frame might be some missing ferrules and cable stops, but if you're up to hunting around I see no reason why it shouldn't work. Best of luck, and don't be afraid to ask questions as you get into it.
Liked 739 Times
i should have left you blocked. bye.
Liked 1,528 Times
https://www.spectrum-cycles.com/geometry.php
By all means, be angry at me that you are repeating nonsense.
Likes For Kontact:
