PSA: Do not buy these vintage aero bottles
Quoted: 1561 Post(s)
Liked 1,734 Times
Just in case anyone else thought, like me, that these no-name reproduction(?) aero water bottles from Ebay would be just the thing to complement your aero tubing or Lo-pro bike:
They leak. I tightened it as tight as possible, and it just leaks out a different side of the cap. Also- the quality of the plastic molding is pretty crude. Just don't.
Likes For icemilkcoffee:
Liked 1,734 Times
Ok, for the thousands of silent forum readers following along , here is the closure to my story. I tried sanding down the mouth of the bottle to smooth out the flashings but it still leaked. Then I lucked out and got an original OGK bottle
The real OGK bottle has a much nicer slick/shiny finish and the base is Pearl looking plastic. AND it doesn’t leak.
So the moral of the story is don’t buy the cheap Ebay copy. Buy the real deal.
Quoted: 4510 Post(s)
Liked 6,377 Times
Ride, Wrench, Swap, Race
Quoted: 1565 Post(s)
Liked 1,295 Times
That's assuming that the cap is configured to hold an O-ring to good effect.
Making injection molds to high standards is quite expensive, so Chinese vendors selling lowest-cost items will have almost certainly not made such an investment.
I did once fix a leaking vintage bottle top using a thin gasket pirated from some sort of liquid container top (like windshield fluid or anti-freeze). I did the same trick to stop a snap cap on my truck's charcoal EVAP canister from leaking vacuum air, added some gasket sealant as well and it's been good for the last 24 years now.
Likes For dddd:
Quoted: 359 Post(s)
Liked 582 Times
This one looks iffy, too.
You have to be thirsty with this one. Taste is awful.
I actually need one of these.
This one had a rubber nipple with a slit in it.
You basically bit it. Gross, even at speed.
Quoted: 2588 Post(s)
Liked 4,824 Times
Are any of us still fast enough to justify the need for any of these?
Just wondering
DD
Just wondering
DD
Likes For Drillium Dude:
Quoted: 116 Post(s)
Liked 374 Times
Likes For BMC_Kid:
Quoted: 359 Post(s)
Liked 582 Times
Aero bottles are likely more of a fashion item. I’m sure they make a difference for a top level TT or tri, but I’ve yet to see a triathlon podium order determined by such a slim margin that all that made a difference in the middle stage.
Quoted: 3810 Post(s)
Liked 6,687 Times
Personally, I think those bottles are ugly af. That was a best forgotten era in cycling history (except for the Huffy Aerowind; that’s cool af).
Likes For nlerner:
Quoted: 534 Post(s)
Liked 415 Times
Attempts to reduce air drag on a tiny area as a water bottle makes no sense when the rider themself is a giant wind sail.
So instead I'm going to compensate by deleting my helmet and my hair for aerodynamicy and weight saved.
Quoted: 4722 Post(s)
Liked 3,036 Times
Likes For T-Mar:
Bikes: too many
Quoted: 411 Post(s)
Liked 234 Times
I had the Campy aero bottle bitd. I couldn't keep my hands on it... I never had a water bottle that I dropped so much and then ran over with my bicycle. Maybe I had a drinking problem. That's not cool. Of course, your mileage may very.
Quoted: 1639 Post(s)
Liked 829 Times
Another aero bottle to avoid is the one from Cobra, unless you just want it for display.
The plastic chemical odor and I suspect, taste that comes from those bottles is as bad as it can get.....
The NOS one I found for my Medici is so bad that it just always sat it in its box in my stash since I bought it years ago.
72 Line Seeker
83 Davidson Signature
84 Peugeot PSV
84 Peugeot PY10FC
84 Gitane Tour de France.
85 Vitus Plus Carbone 7
86 ALAN Record Carbonio
86 Medici Aerodynamic (Project)
88 Pinarello Montello
89 Bottecchia Professional Chorus SL
95 Trek 5500 OCLV (Project)
72 Line Seeker
84 Peugeot PSV
84 Peugeot PY10FC
Bikes: too many
Quoted: 411 Post(s)
Liked 234 Times
https://www.velonews.com/news/news-w...d-legs-faster/
Likes For uncle uncle:
Liked 6,377 Times
An O-ring sized just a bit big to fit snugly in the inside corner of the cap along with smoothing the lip of the bottle would likely drastically reduce or eliminate the leaking.
Everybody has a decent O-ring selection at home, right?
https://www.harborfreight.com/hardwa...-grommets.html
Bikes: A few too many
Quoted: 1364 Post(s)
Liked 2,180 Times
Best, Ben
Voltaire
Voltaire
Quoted: 963 Post(s)
Liked 1,628 Times
Bravo!!! She is Ridding...
Bike Butcher of Portland
Bikes: It's complicated.
Quoted: 4678 Post(s)
Liked 5,795 Times
Do not buy vintage aero bottles.
FIFY
FIFY
Quoted: 1221 Post(s)
Liked 629 Times
Edited to say the eBay link shows them as NOS not repro?
Liked 4,824 Times
I've always wondered why I see so many negative refs to BPA when it comes to vintage bottles. I mean, check this out: BPA Facts
Or this: BPA Report
The truth is out there
DD
Or this: BPA Report
DD
