Help me understand tap sizes
Old 01-22-23, 02:21 PM
dukeofearl
Quoted: 62 Post(s)
Liked 84 Times in 39 Posts
i bought some taps to rethread french cranks to accept 9/16 pedals. i've bought a couple tap wrenches but they are too small. local hardware store doesn't have anything bigger.
end of taps measure between 1/4 and 1/2" and that's the size wrench i bought, but it's way too small.
dukeofearl is offline
Old 01-22-23, 02:50 PM
Bill Kapaun
Really Old Senior Member
Bill Kapaun's Avatar
Bikes: 87 RockHopper,2008 Specialized Globe. Both upgraded to 9 speeds.
Quoted: 1699 Post(s)
Liked 1,073 Times in 760 Posts
If you unscrew the handle, does the wedge block (for lack of a better term) move enough to insert the tap?
Maybe you'll need to pry it to initially break loose any "hindrance"?
Bill Kapaun is offline
Old 01-22-23, 03:04 PM
dukeofearl
Quoted: 62 Post(s)
i did unscrew it all the way and that's what you see in the photo. not even close. i also got the other style of tap wrench in the same size (shaped like a T) and it was also too small.
Old 01-22-23, 03:11 PM
dedhed
SE Wis
dedhed's Avatar
Quoted: 2542 Post(s)
Liked 3,019 Times in 1,832 Posts
12 or 8 point socket is what I use when I can't fit a handle in a confined location
a guide helps.
​​​​​​https://www.amazon.com/GATOR-TOOLS-V.../dp/B000ZN30U4
dedhed is offline
Likes For dedhed:
Old 01-22-23, 04:01 PM
John Valuk
Quoted: 71 Post(s)
Liked 149 Times in 94 Posts
I think that when the package states, 'For tap sizes #0-1/2"', it is referring to the size of the holes that the taps would be used for - and not to the square shank sizes. So, as small as a tap for a #0 hole, and as large as a tap for a 1/2" hole.
As one point of reference, you might look at some of the tap wrenches at McMaster-Carr. They show not only the range of tap sizes, but also the range of square shank sizes.
John Valuk is offline
Likes For John Valuk:
Old 01-22-23, 04:05 PM
3alarmer
Friendship is Magic
3alarmer's Avatar
Bikes: old ones
Quoted: 25354 Post(s)
Liked 9,268 Times in 6,454 Posts
...the handles are usually listed by the size of the tap they will accommodate. So you need to buy something that says it will handle a 9/16" tap (a size larger than 1/2". Look here for a large assortment of them on Amazon. You need something that states it will handle a 3/4" tap, which is usually the next size up, and a little more expensive. Unless you plan on using even larger taps some day. The bigger ones will usually adjust down to handle smaller stuff.
3alarmer is offline
Old 01-22-23, 04:30 PM
wheelreason
Quoted: 269 Post(s)
Liked 221 Times in 140 Posts
Help me understand Starbuck sizes.
wheelreason is offline
Old 01-22-23, 06:08 PM
HillRider
Quoted: 2025 Post(s)
Liked 1,085 Times in 733 Posts
They are like. olives. The very smallest size they sell is called "Large".
HillRider is offline
Likes For HillRider:
Old 01-22-23, 07:00 PM
dukeofearl
Quoted: 62 Post(s)
ah ok i had a feeling i was looking at the wrong measurement. well i should be set for taps when this is all done
Old 01-23-23, 10:31 AM
KerryIrons
Quoted: 429 Post(s)
Liked 532 Times in 292 Posts
I may be a bit of a troglodyte but back when I found myself re-threading a bunch of French thread cranks to English, I clamped the tap in a bench vise and then threaded the crank onto the tap. It was relatively easy to keep the crank arm horizontal with the tap sticking straight up. Lots of thread oil and never had any issues.
KerryIrons is offline
Old 01-23-23, 12:37 PM
freetors
Quoted: 45 Post(s)
Liked 22 Times in 16 Posts
A tap wrench (of that style) that accepts a 9/16" tap is going to be pretty big. Like 10" long or more. You'll know it when you see it.
freetors is offline
Old 01-23-23, 05:50 PM
Andrew R Stewart
Andrew R Stewart's Avatar
Quoted: 3968 Post(s)
Liked 3,328 Times in 2,016 Posts
I have a reamer that just barely fit the largest tap handle I had with a little grinding off of opposing corners of the reamer's "square". Now I have a bigger tap handle thanks to the local tool recycling non profit shop (where I have bought a belt sander and a 4x6 powered hack saw for really good prices) Andy
AndrewRStewart
Andrew R Stewart is offline
Old 01-23-23, 07:04 PM
unterhausen
Randomhead
Liked 3,238 Times in 2,232 Posts
I always used to use an adjustable wrench. You could get a Knipex pliers wrench if you want to be cool about it.
There is actually a little known "short" size. Supposedly they still have it. They used to keep the cups under the counter because they were embarrassed someone would want such a small quantity of coffee
unterhausen is offline
Old 01-23-23, 10:57 PM
FBinNY
Quoted: 5246 Post(s)
Liked 1,545 Times in 882 Posts
Sorry if this is z duplicate.
But tap handles are sized by.the thread diameter of the tap. So, you'll need to shop for one for a 9/16" tap.
In many cases, but not all, you might get by with a 1/2" handle if you grind two points off slightly to clear the frame. I've done this in a pinch, but would only consider it to save serious dough on a handle that would be the largest I expected to own.
FB
Chain-L site
“Never argue with an idiot. He will only bring you down to his level and beat you with experience.”, George Carlin
FBinNY is offline
Old 01-28-23, 09:44 AM
dukeofearl
Quoted: 62 Post(s)
Thanks for the advice. I didn't know how to measure a tap wrench, never done this before. But I decided to give it a try with a small wrench which worked fine. As you can tell from the photo, I'm tragically unorganized. If I bought another tap wrench I'd never be able to find it again anyway!
