Stuck pedal
Abuse Magnet
Bikes: '91 Mtn Tek Vertical, '74 Raleigh Sports, '72 Raleigh Twenty, '84 Univega Gran Turismo, '09 Surly Karate Monkey, '92 Burley Rock-n-Roll, '86 Miyata 310, '76 Raleigh Shopper
Quoted: 151 Post(s)
Liked 174 Times
Stuck pedal
I recently scored an '86 Miyata 310 that some genius was trying to turn into...I dunno what.
Among other things on it are some crappy and mismatched MTB pedals, one of which I can't bust loose at all. Worse, the spindle is soft...wrenches, vise grips, and other pliers are just rounding it off, can't get a grip on it at all. It's the left pedal, and yes, I'm turning it the right (left) way. I've tried penetrating oil, a heat gun, etc...all the normal stuff, and I'm making no headway at all.
It's occurred to me to try and drill it out, but I don't want to bugger up the crank arm, since it's an original Miyata part and not easily replaced. Any advice would be appreciated.
Bikes: 2016 Fuji Tread, 1983 Trek 520
Quoted: 675 Post(s)
Liked 741 Times
I'd disassemble the pedal leaving only the spindle, put a few drops of DOT 3 brake fluid on the joint (keep it away from paint!), and get my 12" pipe wrench on the remains of the spindle. With the left crank arm forward, parallel to the ground, wrench handle facing to the rear, put one hand on the pedal and one hand on the wrench, and put all your weight on it.
If that doesn't work, pull the crank arm and drill it out. The good news is a regular right twist bit will help unthread it.
Likes For andrewclaus:
Quoted: 114 Post(s)
Liked 119 Times
I fought a stuck pedal once, and won by removing the crank arm, placing the arm in a vice (use wood and/or rags to prevent damage to the crank arm finish), pedal pointing up ward (so you're not relying on friction from clamping force to secure the crank arm). then apply sufficient leverage.
Likes For MudPie:
Abuse Magnet
Quoted: 151 Post(s)
Liked 174 Times
I'd disassemble the pedal leaving only the spindle, put a few drops of DOT 3 brake fluid on the joint (keep it away from paint!), and get my 12" pipe wrench on the remains of the spindle. With the left crank arm forward, parallel to the ground, wrench handle facing to the rear, put on hand on the pedal and one hand on the wrench, and put all your weight on it.
...and I'm leaving the pipe wrench in my bike toolbox. Dang.
Likes For arex:
Quoted: 675 Post(s)
Liked 741 Times
Excellent! Thanks for the feedback too.
Pedal forward, wrench handle back, using body weight (works the same both sides of course) is a great trick to know.
señor miembro
Bikes: '70s - '80s Campagnolo
Quoted: 3880 Post(s)
Liked 6,468 Times
Mother Nature's Son
Quoted: 852 Post(s)
Liked 1,433 Times
Likes For delbiker1:
Quoted: 1438 Post(s)
Liked 1,092 Times
Now that you have gott4en that one loose, don't forget to apply grease or anti-seize to the threads of the new one. I use Tef-Gel for such things.
Rhapsodic Laviathan
Rhapsodic Laviathan
I just had this same problem, having to cut up the arm to get my old Primo pedal back. The bare aluminum threads, and bare steel threads galvanized together.
"Right-Right, Left-Left". Glad you got it off. Better to ask, than to fight it off.
Glad that the pedal was removed without damage to the crank! Have you checked to be sure that a “proper” pedal is able to be threaded onto the crank arm? Always hard to say what “Bubba” did to get the cheapo MTN bike pedals mounted. I suppose it’s possible that some level of thread locker was used.
Congrats on the Miyata score! Nice bikes. I have two, an ‘84 Seven Ten and an ‘85 Two Ten. Trying to keep them mostly “period equipped”.
Abuse Magnet
Quoted: 151 Post(s)
Liked 174 Times
Quoted: 5224 Post(s)
Liked 3,581 Times
do you have a pedal wrench? if not, they're good to have around. w/ 3 bikes, riding year 'round, it seems like every few months, I'm changing or swapping pedals. anti seize yes, but there's some technique to that
Quoted: 5 Post(s)
If it is relevant for someone else, the best way to remove the pedal is while you have both crank arms on the bike. Take a piece of rope and wrap the opposite crank arm together with chain stay tube (many turns). Then a good wrench and a pipe, if needed, and the pedal will go off. This method never failed in my life and I have removed hundreds of stuck pedals. The downside is that most of the time thread in aluminium crank is damaged. But this will get your pedals off.
/R
/R
Quoted: 5 Post(s)
