Campy Veloce circa 2000 BB Maintenance
Standard Member
Bikes: 1948 P. Barnard & Son, 1962 Rudge Sports, 1963 Freddie Grubb Routier, 1980 Manufrance Hirondelle, 1983 F. Moser Sprint, 1989 Raleigh Technium Pre, 2001 Raleigh M80
Quoted: 1296 Post(s)
Liked 940 Times
It's been on the bike since 2000, when it was installed new, and has not been serviced at all, and still spins very smoothly and nicely. I do about 600 miles per summer on this bike and that is all for the year. My L.B.S. says "Don't bother." I am not convinced that 20-year-old grease is optimum. In your opinion, should I get in there and inspect, clean and re-grease?
If I wanted to put new bearings in there, are they even available?
Bikes: lots
Quoted: 1958 Post(s)
Liked 2,932 Times
That's a cartridge unit, right? If so, your LBS is right. Just ride it til it's no longer smooth and then replace it. Might be good to look for one now. If it's a cartridge bb unit you can't service the bearings in any meaningful way.
Likes For cxwrench:
Quoted: 4197 Post(s)
Liked 3,849 Times
Let sleeping dogs lay... I agree with starting the looking for replacement now. Campy tapers are slightly different from the vastly more common JIS one. Once a replacement is in hand the most I would do ro thr current one is to remove and reinstall. This will best let you check general condition as well as there's no other issues (corroded in place, frame stuff you can better access from the shell). When the current BB is out you can decide to see if you can pull the cartridge bearing seals and inject more grease, or not. With a replacement on hand you can't do anything "wrong" to the current BB that would keep you from tiding. BTW which bike? Andy
AndrewRStewart
AndrewRStewart
Likes For Andrew R Stewart:
Likes For TPL:
Standard Member
Liked 940 Times
Standard Member
Liked 940 Times
Liked 3,849 Times
Undoubtedly the Campy BB does use balls, as most all do. But a cartridge BB usually has those balls in a bearing having the inner, outer races and balls assembled as a unit in a factory. These cartridge bearings often have a "rubber like" seal on one or both sides that can be pried off to expose the internals for service.
My earlier post suggested that these seals might be assessable and thus the bearing refreshed with grease. I do not suggest that the cartridge bearing be removed from the BB. Andy
AndrewRStewart
AndrewRStewart
