exploding shift cable
Bikes: 2016 Masi strada vita due, 2019 Kona Dew Plus
Quoted: 268 Post(s)
Liked 80 Times
so, replaced the cable on the Masi FD. All installed/adjusted, just have to trim the cable & crimp on the cap. I cut the cable w/cable cutters ..... the cable looks like inverted Christmas tree
what to do? should I care?
Quoted: 645 Post(s)
Liked 797 Times
Looks like crap, but won't have any functional effect. I still trying to get my head around the cable routing arrangement Ive never seen anything like that
Quoted: 2593 Post(s)
Liked 1,922 Times
Not much you can do beyond wrapping the "Christmas tree" with electrical tape to reduce the chances of getting a grease injection in your leg.
You may want to splurge and dedicate two cable ferrules to the replacement cable, when that time comes. Put one ferrule on as soon as you make the initial cut to prevent it unraveling. Then when you've got the cable attached, do the final cut and crimp on the second ferrule..
Likes For streetsurfer:
Quoted: 3487 Post(s)
Liked 2,905 Times
That happened as soon as you made the cut?
Quoted: 4221 Post(s)
Liked 2,942 Times
Some heat-shrinkable wrap (squeeze it together and slide it into one of the sleeves/tubes of heat shrink wire wrap and then heat it up to shrink) might be a good safety precaution to keep from getting stabbed.
Likes For himespau:
Bikes: n, I would like n+1
Quoted: 127 Post(s)
Liked 133 Times
Sometimes some gentle twisting will realign they strands and put things back as they should be. I’ve never seen that happen the instant I cut a cable, though I have seen it after a few rides if not taken care of.
As long as you don’t need to unclamp and adjust the cable you should be ok with any of the previously listed solutions to contain the birds nest. If you do end up having to unclamp it, that would be a good time to replace it.
SE Wis
Quoted: 2740 Post(s)
Liked 3,385 Times
A couple drops of super glue then cut
Likes For dedhed:
Bikes: lots
Quoted: 1958 Post(s)
Liked 2,932 Times
Liked 2,905 Times
Quoted: 6172 Post(s)
Liked 4,789 Times
That is the most contorted routing I've ever seen too. Perhaps all the bending so close to the end had different stress in each strand that just simply needed to relieve itself... quickly.
Likes For Iride01:
Mad bike riding scientist
Quoted: 6200 Post(s)
Liked 4,198 Times
There are worse ones out there. Shimano has some bottom pull that can be converted to top pull that seem to wrap around the derailer about 4 times.
Stuart Black
Stuart Black
Quoted: 268 Post(s)
Liked 80 Times
Yep. As soon as I cut it, it 'exploded' to the shape you see. I couldnt believe it.
FWIW, the new cable the shop gave me was not given to me in a brand name package. Im sure shops buy their cables in quantities of 50 or 100. They gave me one of those.
Liked 4,198 Times
What kind of “cable cutter” did you use?
Stuart Black
Stuart Black
Bikes: lots
Liked 2,932 Times
Let me repeat: IT HAPPENS. Twist it together and put a crimp on it. This is not a problem at all, just deal with it and move on. If you can't twist it together and put a crimp on it then replace the cable.
Get a better, sharper tool to cut your cables. Dull cutters will fray those cables every time.
Bikes: lots
Liked 2,932 Times
I use Knipex side cutters to cut cables and brake housing. I only use 'cable cutters' for shift housing. Works very well. The ones I have are at least 5 years old and get used every day. They cut beautifully.
