Compass tires/Rene Herse vs Panaracer
Hi,
As i have recently discovered, that the tire manufacturer for Ultradynamico tires is Panaracer (Correct me if i an wrong), i was wondering if the same holds true for Rene Herse tires.
Given that they are bananas expensive for the hobby rider, would there be a reason to consider them over my current favourites Panaracer Gravelkings other than curiousity, if they were produced by the same company anyways (i.e. Panaracer)?
KR
WH
KR
WH
Bikes: Handsome xoxo, Serotta atx, Canyon Edurace CF8
Quoted: 458 Post(s)
Liked 994 Times
yes Panaracer makes Rene Herse tires but that does not mean they are exactly the same. I personally run both ie Rene Herse RTP and Naches Pass tires and Panaracer Pasela and tservs and can not really tell great difference between them as far as how they feel when riding..looks are obviously different.
Thread Killer
Bikes: 15 Kinesis Racelight 4S, 76 Motebecane Gran Jubilée, 17 Dedacciai Gladiatore2, 12 Breezer Venturi, 09 Dahon Mariner, 12 Mercier Nano, 95 DeKerf Team SL, 19 Tern Rally, 21 Breezer Doppler Cafe+, 19 T-Lab X3, 91 Serotta CII
Quoted: 2453 Post(s)
Liked 1,540 Times
Yes.
I have tires from all of those, and they are obviously different. If only looking at tread pattern, one can see that’s true, but there are other construction differences as well, for example, the Herse extralight casing is observably different from the Panaracer Gravelking slick.
As for whether differences make Herse and Ultradynamico worth considering, well, that depends on what kind of cyclist you are. Some cats roll around on department store rubber their whole lives, blissfully ignorant of the possibilities.
Likes For chaadster:
Fair enough. But would it make a noticeable difference to the curious cyclist? I do run my Panaracers tubeless and the price of admission is steep.
Money no object, yes i defo would run them immediately. However, if i were to run them with inner tubes, would i even benefit from thei "supposedly" supple casing?
Cheerfully low end
Quoted: 592 Post(s)
Liked 957 Times
Otto
Quoted: 2377 Post(s)
Liked 1,698 Times
I think it's worth asking how sensitive you are to various tires' construction? If the lightest Gravelking feel like the heaviest Schwalbe Marathon to you, you're not likely to notice how nice the Compass tires might be. OTOH if a Gravelking SK is intolerably heavier and slower than the straight Gravelking, then you might appreciate the Compass tires. I won't go so far as to say the difference between tires is all a placebo based on marketing, but riders' expectations seem to factor heavily into their experiences.
Disclaimer: my Barlow Pass pair is still in the box since Christmas, waiting for a chance and some decent weather to ride some gravel.
Quoted: 4014 Post(s)
Liked 2,771 Times
In reverse order, until late last year the Compass tires were mostly tube-ful; people trying tubeless reported the sidewalls were too porous, or had to be refilled with sealant shortly after installation. The marketing materials and people who believed them were still full of praise for the casing. So go ahead and try it with a tube (if you decide to try them at all).
52psi
Quoted: 777 Post(s)
Liked 749 Times
I cringe and grumble every time I have to replace my Rene Herse tires.
And then I buy them.
Yes, they're that good.
(I run Stampede Pass 700x32, ultralight casing, skinwall, with tubes.)
Likes For Fahrenheit531:
ignominious poltroon
Quoted: 1927 Post(s)
Liked 2,882 Times
I have them on most of my bikes, with no regrets (other that the hole in my wallet).
They are quite open about the fact that Panaracer makes them to the Rene Herse spec.
Other tire manufacturers are beginning to emulate them, so there might be deals to be had.
They are about the same price as better mountain bike tires.
Liked 2,882 Times
Advocatus Diaboli
Quoted: 4596 Post(s)
Liked 1,454 Times
Yes.
https://www.excelsports.com/panarace...ad-tire-2-pack
Liked 2,771 Times
I've wondered though how much difference between a Rene Herse Cayuse Pass and a Panarace Agilist. Can still get the 2-packs of the Agilists for $78 at Excel
Fat n slow
Quoted: 2904 Post(s)
Liked 1,802 Times
Going TL or with Tubes? The biggest thing keeping me from getting a set is a fear of blowoff on hookless rims
Quoted: 1295 Post(s)
Liked 1,298 Times
Another option is Soma tires, also made by Panaracer. They have sales regularly where you can buy their tires for a good discount. I bought some Soma Supple Vitesse SL tires for something like $25 each. I have never ridden on Rene Hearse tires but I can say those Soma tires were very supple and comfortable indeed.
Likes For icemilkcoffee:
Thread Killer
Liked 1,540 Times
The 2pk price does seem quite nice for a superlight road tire…if one is running tubes. I don’t, but there’s a TLR version, too, however I’ve had Panaracer Race Evo A tires in the past and was not a fan of those, so I’m a little reticent to go back to the well with Panaracer, but admittedly, that experience was probably 15 years ago, so change is reasonable to expect.
Clark W. Griswold
Quoted: 3917 Post(s)
Liked 3,383 Times
Panaracer makes a lot of tires for a lot of different companies but not all of them are the same. A company will likely say this is what we want and they make it. Ronnie Romance probably wants a different tire than Jan Heine in some way or another but they both know they want Panaracer quality.
Likes For veganbikes:
Quoted: 2153 Post(s)
Liked 2,428 Times
Good Quality tires (expensive) are IME the single most effective thing you can buy to improve comfort and handling on a bike.
this is one area where you get what you pay for and should look for sales as there are often deals to be had
here is my experience with 28mm tires, tubes road bike, 230 lb rider, ride at higher tire pressures (i.e 95 psi for gravel kings)
Rene herse: have a pair of the 28mm chinook pass, but have not mounted yet, waiting for new bike these will go on. but comparing to gravel kings, the build is different.
all in 28 mm
Conti gp5000: great tire, super ride and handling. I had really good luck with only one flat in 2000 miles, until I hit metal that sliced through the tread
Vittoria Corsa G+: ok tire, super ride and handling, but i was averaging a flat every 110 miles, so they had to go
Gravel Kings: great tire, surprise to me in that the ride and handling was close to the GP5000. I have these on 2 bikes, one of which I rode in the 2021 Cino......worked really well there also
of course tubular ride better than these
in multiple threads over the last few years, the consensus has been: darn the rene herse/compass tires are expensive, but the do work as well as they are hyped
all in 28 mm
Quoted: 2329 Post(s)
Liked 2,081 Times
Quoted: 930 Post(s)
Liked 1,165 Times
one weekend we fitted his bike with 23mm Michelin Super Comp HD’s and latex tubes and he thought he had gone to Heaven
he insisted the combination of Campy hubs and the Super Comp’s enabled him to coast uphills lol
Quoted: 930 Post(s)
Liked 1,165 Times
I have Maxxis DTH on one bike - Panaracer Pasela on another bike ... also have a pair of Schwalbe Billy Bonkers set aside
Quoted: 458 Post(s)
Liked 994 Times
not sure what you are asking but RH has rat trap passes, Naches Passes and elk passes as well as humptulips ridge.
Sock Puppet
Bikes: 2014 Cannondale Synapse Carbon, 2017 Jamis Renegade Exploit and too many others to mention.
Quoted: 1028 Post(s)
Liked 856 Times
I have run both the Panaracer GK Slicks and the Rene Herse Extralights which are supposed to be ooooooh so smooth. I honestly cannot tell the difference other than the Rene Herse tires make my wallet lighter.
