Canyon Endurance CF7 vs Grizl sl6
Bikes: Handsome xoxo, Serotta atx, Canyon Endurace CF8
Quoted: 904 Post(s)
Liked 1,883 Times
so I am 64yoa and used to be a serious rider ie raced on a team and did tri's and did double centuries, some state 40K time trial medals etc. My last bike before getting out of it was a 1994 ritchey road logic, I stopped for 20 years or so and this past July decided to get a bike just to piddle around on. I ended up getting hooked again and did around 3000 miles from July to Jan and since Jan 1 this year have done about 2400 miles (I live in Montana) most out doors. been doing a lot of 50-60 mile rides and thinking I am on the wrong bike for putting bigger miles on. I have a handsome xoxo with mustache bars 26" wheels etc (copy of a bridgestone xo1) so probably not the ultimate bike for wanting to do centuries on. My buddy says Canyon is about the best value going. the two mentioned in the title have kind of peaked my interest. Anybody have any comments on the two bikes mentioned? Lots of gravel roads around where I live so the grizl kind seems like a good choice but I also think maybe the endurance is a better choice.
ignominious poltroon
Quoted: 2229 Post(s)
Liked 3,412 Times
Get the Grizl. It won't hold you back on road, and it is more versatile.
Quoted: 4388 Post(s)
Liked 4,828 Times
I have an Endurace and it is great for fast century road rides. But if you intend to ride those gravel roads then I would get the Grizl and maybe a second wheelset for dedicated road rides. I do think Canyon produce excellent bikes and are very good value compared to most other major brands. The Endurace can also handle a bit of gravel on the right tyres, but you would be limited to around 32 mm tyre width, maybe a tad more. I think there is now a slightly more gravel oriented variant of the Endurace available too, which could be a great option.
Edit: Just had a look on the Canyon website and the Endurace CF7 All-Road is the new version I mentioned above and comes with 35 mm tyres. That could be a great choice for 50/50 road/gravel use.
Likes For PeteHski:
Quoted: 6178 Post(s)
Liked 4,796 Times
Canyon's of similar size tend to stretch you out more than other bikes. Not that that is bad or good. But if you get one, you should probably talk to Canyon and others about the fit and what will really be the correct size for you. Don't just assume that because your Ritchey Logic was a particular size that a Canyon in the equivalent size of either model will be the size you need.
I'd like to try a Canyon since I liked being stretched out on the old over size vintage bikes I used to ride, but since I haven't got any friends that have one around here to try one and Canyon only seems to sell online. So I'm a little hard pressed to want to buy a bike that I can't ride first. Maybe that'll change one day.
Quoted: 904 Post(s)
Liked 1,883 Times
Quoted: 904 Post(s)
Liked 1,883 Times
Liked 3,412 Times
The Grizl is a nice bike, so you can't go wrong either way.
Quoted: 904 Post(s)
Liked 1,883 Times
some stuff might be a little more washboard than this but not going to be dodging baby head size rocks.
Habitual User
Quoted: 4930 Post(s)
Liked 8,062 Times
IMO, you can't make a wrong decision between those 2 bikes, for the use you have described. Picking the right tires for your conditions will make more difference for your rides than the differences between the frames.
Liked 4,828 Times
I would probably lean toward the Endurace for a 70/30 road/gravel split on those roads. The 45 mm tyres on the Grizl will slow you down a bit on the road, but you could always change them for 35 mm or less. In that way the Grizl is more versatile, but unless you have some much rougher gravel paths it may be overkill. Either way I think you will be happy.
Liked 3,412 Times
The Grizl fit me fine (I test rode it last summer).
I think the endurance would not. Canyon has some unusual sizing, so make sure it will fit.
Habitual User
Liked 8,062 Times
Continental GP5000 TL 25mm @ 80psi = 9.9W
Schwalbe G-One RS Super Race 40mm @ 45psi = 14.5W.
Less than 10W (total for both tires) rolling resistance penalty on smooth surfaces. There are more factors than just laboratory RR results, but it's still closer than I expected. If you're not in a competitive situation, or otherwise concerned about maximum efficiency, the difference might not even matter to you.
Liked 4,828 Times
Reviewing the charts at BRR, comparing road vs. gravel tires, I was surprised to find that careful tire selection can really narrow the difference...
Likes For PeteHski:
Likes For Guff:
Quoted: 904 Post(s)
Liked 1,883 Times
I ended up going with an endurace cf 8. showed up today. I ordered it Wednesday so pretty impressed with how fast it got sent out. I think I am going to like it...a lot...
Likes For Guff:
